![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Drives a 2012 IOM 2SS/RS 6M Join Date: Nov 2008
Can someone tell me how much do factory polished SS wheels weigh........
Bump..............................
![]() Drives: 2013 Camaro 2SS 1LE Join Date: Jan 2011
Front weigh 30.3 Pounds each rim and rear weigh 32 pounds each rim
ADM LSA Supercharger Conversion, ADM air intake ,Stainless power 1 7/8 long tubes w/hi-flow cats, Chunnningham Motorsports stage 2 cam and custom Dyno tune from Starkweather Performance.
624 RWHP, 524 RWTQ |
WHEELS / TIRES
2010 OEM Wheels / Tires Specs LSLTSS/ LT-RSPerformance Parts WheelsWheel size / material:18 x 7.5" / steel (photo)18 x 7.5" / aluminum (photo) 19 x 8" / aluminum (photo)20 x 8" / aluminum (front) (photo) 20 x 9" / aluminum (rear) (photo)21" / chrome (photo / photo) 21" / painted (photo / photo)Wheel weight:14.95Kg/32.9lbs each. = 59.8Kg/131.5lbs Total.18 x 7.5": 10.47Kg/23lbs each = 41.88Kg/92.1lbs Total. 19 x 8": 13.09Kg/28.8lbs each = 52.36Kg/115.2lbs Total.13.79Kg/30.3lbs each = 27.58Kg/60.7lbs (front) 14.55Kg/32lbs each = 29.1Kg/64lbs (rear)14.31Kg/31.5lbs each = 28.62Kg/63lbs (front) 16.42Kg/36.1lbs each = 32.84Kg/71.5lbs (rear)TiresP245/55R18 all-seasonP245/55R18 all-season P245/50ZR19 all-seasonP245/45ZR20 summer (front) P275/40ZR20 summer (rear)245/40ZR21 summer (front) 275/35ZR21 summer (rear)Recommended Tire Pressure36 psi (250 pKa)36 psi (250 pKa)36 psi (250 pKa)36 psi (250 pKa)Tire weight30lbs each30lbs each 34lbs each32lbs each (front) 36lbs each (rear)30lbs each (front) 35lbs each (rear)Offset:+38mm+38mm+35mm (front) +40mm (rear)+35mm (front) +40mm (rear) 18-inch steel heritage wheel
SS/ LT-RS Wheel Weight- 13.79Kg/30.3lbs each = 27.58Kg/60.7lbs (front) 14.55Kg/32lbs each = 29.1Kg/64lbs (rear) Tire Weight- 32lbs each (front) 36lbs each (rear) Via Camaro Wiki, This is a more simple version of last post. Tried to copy and past, at it failed.
#6 | |
#7 |
No Problem.
| Wanted: 20" set of factory wheels and tires, central IL. if possible | wbyman | Wheels / Tires | 19 | 04-16-2011 12:47 PM |
| Where to buy a set of used factory 20" wheels and tires | wbyman | Wheels and Tires Talk Sponsored by The Tire Rack | 5 | 02-23-2011 12:42 PM |
| Problems with Savini - beware | Darth_Emma | Vendor and Seller review / feedback / experiences | 115 | 12-22-2010 10:51 AM |
| Wanted to buy: 20" OEM Factory Chromed wheels | prostock69 | Wheels / Tires | 13 | 07-28-2010 01:07 PM |
| My Experience with Iconz Wheels. | EDISKRAD EHT | Vendor and Seller review / feedback / experiences | 40 | 05-13-2010 10:18 AM |
