Old 01-31-2012, 07:01 PM   #1
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
Padre & APF's D1SC+A6+GT9+WG+JBA.ST's = 619rwhp
Max trim = 619/572 @ 11psi (+195rwhp)
Daily Trim = 593/535 @ 9psi (+169rwhp)
Special thanks to John Lee at Atlanta Performance And Fabrication and Josh and Skipper and Brandon. We got her done!
Details: 2011 L99/A6 Camaro, <10k miles.
Bolt-ons: JBA Shorties, JBA catless midpipes, Meziere Electric Water Pump.
Drivetrain: 3.45 gears (swapped from an M6), 3200 FTI/RX Torque Converter, 18" TSW Rims with 305 MT DR's (20x9" stock rims/275 tires on all corners, daily trim).
Valvetrain: Lingenfelter GT-9 cam, Comp 675 Duals.
Blower: Procharger D-1SC, with Turbonetics Wastegate mod.
Fuel pump: drop-in Aeromotive Stealth for Gen5 Camaros, with return fuel system and 80lb injectors.
Best w/ cam: 11.633 @ 118.01 w/ 1.605 sixty.
Top run (26) is as installed, about 11psi, 16* timing.
Middle run (28) is when we dialed back the boost, 9psi, 16* timing.
Bottom run (16) is the base run with the GT9 cam.
Max boost was not a problem, but we didn't want to stay there. I should be able to run that more safely when I've got race gas, but on pump gas I had no Knock Reduction.
Startup requires waiting for the pump to prime, and the Aeromotive pump is noisy and noticeable, but I'm told it's not half as bad as the older external Aeromotives. But at max boost, we were somewhere around 75% Injector Duty Cycle. Startup also requires the stock Camaro battery. None of this lightweight Braille stuff. Getting the blower turning over is noticeable, but fine.
The Wastegate mod is what makes it unique. You can tell from the dyno charts that it is effective. With my newfound torque and a base 3200 stall, the motor's going to rev to 3500 before things get going anyway.
But I'm at 400tq at 3.5k and 500+ after 4k rpms. Pulls hard to 6800/7000, but we might want to pull it back to 6500/6700.
I'd say we're still on the learning curve with how the Wastegate behaves. Perhaps in the future we put an EBC on it and gives us a little more dialability at the track, which is my eventual goal.
Did I mention, all this through JBA Shorties? For the sake of the dyno, we put on JBA catless midpipes, and I'll probably keep them on for the racing season.
Right now, I just need to relearn how to drive the beast.
Oh, and I will be tracking it as soon as a nearby track opens.
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 01-31-2012, 07:01 PM   #2
Padre
Padre's Avatar
Padre
Old 01-31-2012, 07:02 PM   #3
Padre
Padre's Avatar
Reserved for comments.
Old 01-31-2012, 07:09 PM   #4
2010 4 DW
Drives: White 2010 RS/SS
Very nice numbers!
Cant wait for the track times to come.
2010 4 DW is offline   Reply With Quote
Old 01-31-2012, 07:43 PM   #5
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
Again Congrats did you go with the 4" pulley and the 44mm wastegate?
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 01-31-2012, 07:50 PM   #6
SlowSS
SlowSS's Avatar
Drives: 2013 Camaro 2SS/RS 1LE
Vey nice! Hope to see it in person soon!
SlowSS is offline   Reply With Quote
Old 01-31-2012, 07:54 PM   #7
Padre
Padre's Avatar
Yep. Though we used a Turbonetic Wastegate and not the Tial (availability issue only).
We changed springs on the Wastegate from the 8psi to 5psi. The minium boost with the 8psi was like 11.5psi. Using the 5psi gives us a good "bottom" to work from.
An EBC is what I'll need at the track to switch between daily, pump gas, and high octane tunes.
And we didn't see any knock anywhere anytime. So I feel safe.
Padre
Old 01-31-2012, 08:01 PM   #8
navyblueSS
Drives: 2002 Camaro SS
Very nice!
2015 1LE - CAI intake, TSP longtubes,
NPP, Futral Motorsports tuned, BMR 1"lowering springs, BMR trailing arms
navyblueSS is offline   Reply With Quote
Old 01-31-2012, 09:11 PM   #9
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Congrats! I know you have been waiting some time to get this done!
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 02-01-2012, 12:21 AM   #10
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
I'm impressed. Gt9 cam didn't shock me to be worth some ponies. The jba's are interesting for sure. I thought abut keeping my stock manifolds and doing the test pipes they make. Where did you do the gate...down in the bumper on the charge inlet to the fmic?
-John S.
Old 02-01-2012, 09:17 AM   #11
Padre
Padre's Avatar
Yes, the wastegate is on the driver's side, behind/below the foglight. It is easily reachable so we can adjust the screw, which we were able to do on the dyno to make easy adjustments.
I don't imagine I'll be adjusting the Wastegate at the track. Next up will be a Greddy Profec B Spec II in the cabin to adjust on the fly.
It'll be nice at the track: "Hmm, which would I like? 620, 600 or 580?" <Click> Vrooommm...
Padre
Old 02-01-2012, 09:54 AM   #12
Jchaluja
Jchaluja's Avatar
Drives: ZL1 Camaro
very nice setup...smart!
Jchaluja is offline   Reply With Quote
Old 02-01-2012, 01:17 PM   #13
BLACK10
BLACK10's Avatar
Looks good. Why two different face gauges?
Old 02-01-2012, 01:31 PM   #14
Padre
Padre's Avatar
I thought they came with swapable faceplates. Doh!
Padre
