Ron@Vengeance
Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum All audio, video, bluetooth, nav, radar, and electronics discussions.
Old 04-27-2009, 12:26 PM   #1
Embalmer
2G1FT1EWXA9103351
Embalmer's Avatar
Drives: 2SS RS, SIM, 6pd, 20"Alum
FAT32 40GB Portable HD Didn't Work
So my Smartdisk FireLite 40GB Portable USB 2.0 Hard drive - formatted to FAT32 did not work in the Camaro.
It powered it up but it didn't work.
I thought perhaps it just had to load for a long time but then I noticed - when I add a bunch of songs to a thumb stick and pop it in - it will load the first song and then it comes up and says "Indexing..." so I see it's reading the songs.
When I pop the portable hard drive in it doesn't switch to the USB device automatically like the thumbstick and it doesn't do any type of indexing - sooo... pretty sure it doesn't work.
If I get my hands on some other types of portable hard drives, I'll try them out.
Embalmer is offline   Reply With Quote
Old 04-27-2009, 12:28 PM   #2
UCF w00t
Geek
UCF w00t's Avatar
Drives: IOM 2010 Camaro 2SS
Interesting. I'm assuming the drive is getting power and spinning up? How does the device show up in the device manager on your computer? USB Mass storage? I see that it can use an external power source if the bus doesn't supply enough power, have you tried this?
UCF w00t is offline   Reply With Quote
Old 04-27-2009, 12:29 PM   #3
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
Well that's a bummer! There's going to be a lot of bummed individuals if this holds true for all external HDD's :(
Old 04-27-2009, 12:30 PM   #4
dodson914
Drives: 2008 2500 HD; 2008 G8 GT #199
Do any external HD work on cars? I would not have thought it would.
dodson914 is offline   Reply With Quote
Old 04-27-2009, 12:31 PM   #5
Croathlete
Danny
Croathlete's Avatar
Drives: 2010 Camaro 2SS/RS
Send a message via AIM to Croathlete
Did you try NTFS?
2SS/RS CGM with black rally stripes
DON_RAFA describing my Noweeds cutouts - "Very Strong. When I couldn't see you I still heard you. Sounds like your car is pissed at the world."
Please help me fight back by supporting me in the 2010 American Cancer Society's Relay for Life. Every little bit helps. Click here for more information. Thank you to those that have donated!
Croathlete is offline   Reply With Quote
Old 04-27-2009, 12:33 PM   #6
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Depend on how much power the USB drive is pulling. Some actually need to hook to 2 USB ports to get enough power to spin. That could be the issue.
Scott@Bjorn3D is offline   Reply With Quote
Old 04-27-2009, 12:35 PM   #7
Embalmer
2G1FT1EWXA9103351
Embalmer's Avatar
Under "My Computer" shows up as a "Local Disk" under "Type".
Under "Safely Remove Hardware" it shows up as "USB Mass Storage Device".
It is getting power and I can hear it cranking...but it's kind of like a stutter ... I just plugged it into my laptop and it's a full spin...not sure that it did that in the maro....
I have "not" tried an external power supply yet... I don't have a cord. I will try it if I can get a cord for it.
Old 04-27-2009, 12:36 PM   #8
Embalmer
2G1FT1EWXA9103351
Embalmer's Avatar
Originally Posted by Croathlete View Post
Did you try NTFS?
No I didn't. I've heard most people have worse results with that though...
Old 04-27-2009, 12:38 PM   #9
CamaroSkooter
And I believe once you format it to NTFS, you can't go back to FAT32...
Old 04-27-2009, 12:41 PM   #10
Scott@Bjorn3D
Did the USB cable that came with it have a Y splitter with 2 usb connectors? If it did one is power only. You could test this theory by plugging the power only connector into the USB on the notebook and the other into the cars USB and see if it works.
Old 04-27-2009, 01:24 PM   #11
Embalmer
2G1FT1EWXA9103351
Embalmer's Avatar
It did not. It actually has a jack for power and a switch to tell it which power source to use - external or USB.
I just need to find a jack that fits...can prolly put one together pretty easy.
Old 04-27-2009, 01:37 PM   #12
CamaroSkooter
The device didn't come with a power supply in the box? Or did it only come with the 120V wall outlet power supply?
Old 04-27-2009, 01:43 PM   #13
Embalmer
2G1FT1EWXA9103351
Embalmer's Avatar
It was a couple of years ago when I bought it... honestly I don't think it came with a power cord at all! I think it just had the USB cable with it.
Going to make one though.....
Old 04-27-2009, 01:47 PM   #14
CamaroSkooter
Hmm, I hope you get the voltage/amperage correct, cause I've fried electronics before because I didn't get the right type of power supply.
Good luck
Old 04-27-2009, 02:32 PM   #15
Embalmer
2G1FT1EWXA9103351
Embalmer's Avatar
Good luck
5V. Not sure what the current is...but oh well
Either way, I will report my success or failure.
Old 04-27-2009, 03:14 PM   #16
levi1922
levi1922's Avatar
Drives: 2LT RS CGM
i think it would be over all easier to get a flash drive,
and you can get a 8 gig that will hold plenty of songs for not that much money.
levi1922 is offline   Reply With Quote
Old 04-27-2009, 04:22 PM   #17
MTron
Drives: 99 Grand Prix
i have never seen a laptop hd that draws more then 10 watts, so i think if you can supply at least 2 amps at 5 volts u should be good to go!
As for why this is happening in the first place....well, power would be my first idea...after that...could be an incompatibility with the ATA chipset in the external...try another drive perhaps??? As well, maybe you should try changing the allocation unit size when formatting, try using all default setting when u format it, including the allocation size, if that doesnt work try 4096 bytes, which is a common size (dunno if its the default size tho...might be the same! lol)
also, try putting the music into a directory instead of just in the root of the drive, ie put all the music in a folder called music for ex e:\\Music\all ur stuff
MTron is offline   Reply With Quote
Old 04-27-2009, 08:59 PM   #18
SemperFi
U.S. Marine Corps
SemperFi's Avatar
Drives: 2009 Ducati Streetfighter
Sandisk Cruzer - 16 gb for under 30 with free shipping.
http://www.amazon.com/SanDisk-Cruzer...MFVS4E8H3FJMMY
knock it outta the park with this sweet wallet sized 320gb Western Digital HDD. Its small and brand new, takes less power than the clunky old disks $70
http://www.amazon.com/Western-Digita...0883879&sr=1-1
Texas Residents: Join the Texas social group!
Semper Fi!
SemperFi is offline   Reply With Quote
Old 04-27-2009, 09:04 PM   #19
UCF w00t
Geek
UCF w00t's Avatar
That's what he's trying (different brand/size but same idea). And it's not working.
Old 04-27-2009, 09:13 PM   #20
cyberbro
cyberbro's Avatar
Drives: Soon to be 2010 Camaro
I have a radical idea? See what the owners Manual says!
I'm sure it will have a list of what will work and will not work in the USB?
Camaro Dream on hold for now. But when I go for it I will only buy from BeckyD@RodgersChevrolet.
cyberbro is offline   Reply With Quote
Old 04-27-2009, 09:35 PM   #21
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
owners manual. . . hell that's the same as asking a guy to read the book for the xbox game he just bought or to read the directions before putting that desk together.
Magnaflow Cat back / ROTO-FAB Intake / Whipple Kit / RDP Tune.
580hp - 650Tq
franknbeans is offline   Reply With Quote
Old 04-27-2009, 09:37 PM   #22
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
i don't own that much music i think its 36GB am just going to buy a 64GB flash drive
trudawg660 is offline   Reply With Quote
Old 05-01-2009, 11:05 PM   #23
etrigan
etrigan's Avatar
Drives: 2010 2SS/RS Black Camaro
Any new news? I've actually bought a WD 320GB drive just for the car. Now, I may have to try something different.
As a guess, I would stick to FAT32 and avoid NTFS. One thing that you might need to do is do multipule partitions and drop no more than 10,000 songs on each partition.
"No matter where you go, there you are."
-B.B.
VIN #2G1FT1EW6A9106795
1100, Preliminary order accepted:10/13/08
6000, Del. to me:5/20/09
etrigan is offline   Reply With Quote
Old 05-01-2009, 11:22 PM   #24
levi1922
levi1922's Avatar
Drives: 2LT RS CGM
haha, thats is one of the things i am looking forward to! i always read them!
Old 05-06-2009, 09:33 PM   #25
Embalmer
2G1FT1EWXA9103351
Embalmer's Avatar
Didn't get the external power supply hooked up yet... will try to do that soon.
My Sandisk 16gb thumbstick/flash drive works great though..... Just FYI.
This site is like crack. You know you're addicted to Camaro5 when... GameOver620 5th Gen Camaro SS LS LT General Discussions 465 01-03-2011 02:28 PM
work outs on Demand Iroczlover Off-topic Discussions 0 02-21-2009 12:09 PM
How does Cell Service Work with OnStar and Bluetooth? 69er Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 5 01-03-2009 01:31 PM
If the El Camaro makes it to production.... Silverado General Automotive + Other Cars Discussion 8 02-21-2008 10:17 AM
Anyone Work In The Auto Industry? AirGoya Off-topic Discussions 1 07-31-2007 06:36 PM
