02-17-2012, 09:26 AM | #1 |
Drives: 2012 Camaro 2SS/RS Join Date: Jul 2010
Should I do it?
Thinking about getting the SCT tuner from Jannetty. The car is basically brand new, but I've already done the intake and exhaust. My main concern is ditching the stupid AFM, but I might as well optimize the car for my mods at the same time. I know the warranty will probably be toast, but it seems like tons of people have thrown caution to the wind and just went ahead with the tune.
02-17-2012, 09:32 AM | #2 |
Brandon Gilpin
Drives: 2011 Camaro SS / 2014 Fiesta ST Join Date: Dec 2011
just do it
2011 Camaro 1SS Platinum ed. ls3 k&n CAI, BBK LT's, MBRP Cat Back, Vengeance Racing Kaotic Camshaft, Melling oil pump, Norris Catch Can, dyno tuned By AGP Speed & Custom, msd coils, taylor cables, Vmax ported throttle body, strut brace, eibach springs, hurst ST shifter.
Black on black, Private forged wheels, Oracle side marker lights, black tail light bezels, 3D Carbon body kit |
02-17-2012, 09:52 AM | #3 |
Drives: '69 SS Convertible Join Date: May 2009
Realize it's your drive train warranty that will be gone. Things like heated seats, remote mirrors, etc. will still be covered.
Build Journal |
02-17-2012, 10:29 AM | #4 |
do it.
02-17-2012, 10:36 AM | #5 |
El Hefe
Drives: Black Camaro 2SS/RS Join Date: Jul 2010
Ted knows best, just do it.
02-17-2012, 10:58 AM | #6 |
Drives: 2019 GMC Sierra 1500 AT4 Join Date: Nov 2011
The warranty issue is not as black and white as some people here will have you believe.
Summit White 6" Lift, 37x13.50R24's |
02-17-2012, 11:10 AM | #7 | |
Drives: 2010 Camaro SS/RS Join Date: Oct 2011
02-17-2012, 01:22 PM | #8 |
Order placed
I think I might as well get all I can out of my current mods, and now I can say bye-bye to AFM. I'm not sure if what I'm hearing is when the it's activating or deactivating, but it sounds like the car is letting out a quick little fart. Not cool at all. It's not an issue with my Solo exhaust because I heard this same sound even when it was stock. I won't miss AFM at all. I'll update once I get the new tune
02-17-2012, 02:40 PM | #9 |
BowtieBelle's SS
Drives: 2010 Camaro SS Join Date: Jan 2012
Just did mine. Worth it!
02-17-2012, 04:00 PM | #10 |
Drives: 2010 Camaro 2SSRS RJT L99 Join Date: Jun 2010
Do it, you will never look back but be warned, its a slippery slope!!! LOL
Get rid of that damn AFM system, Have Ted tune the engine for your mods and have him do the trany tune as well. He will also turn off the torque management system which will give you your engines full torque power right off the throttle and not limit it until you get over 4000 rpms or whatever it is. When I was at your stage, my L99 would burn the rear tires but not dramatically. With a cold air intake, LT headers, HF cats, Corsa exhaust and Teds tune, it would just sit there and smoke the rear tires. Dramatic difference. The engine revs DRAMATIACALLY faster with the better breathing mods and the tune makes them work together like fine music. I also found that my fuel milage with the AFM turned off and good tune was slightly better then it was stock. As I said though, be warned, its a slippery slope but a fun one once you start adding mods!!!
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages. More to come!! |
02-17-2012, 04:19 PM | #11 | |
Drives: 2SS/RS CGM CAMARO BEAST Join Date: Jul 2009
Expensive hobby, but nothing is more fun than feeling the controlled violent vibration coming from 800 horses as you sit at a stop light. Welcome to the insanity my friend
2010 CGM 2SS/RS; 418 stroker; JE Forged Pistons (offset wrist pin); Forged Crank; upgraded valvetrain; Custom Comp Cams Cam; Kenne Bell 2.8; ID 1000s; Aeromotive Fuel pump with return; ARH Long Tubes; Spec heavy duty clutch; 3" Magnaflow Cat Back; Nick Williams 102 mm Throttle Body; Tune fixed by Dave Steck; 815 HP and 14 mpg
Upcoming-- Disintegrated drivetrain; Divorce if/when my wife catches on to my addiction |
02-19-2012, 01:26 AM | #12 |
Drives: 2012 1SS IOM Join Date: Oct 2009
I just got my JRE tune and I only have an intake, exhaust, and ported TB (mostly wanted to get rid of the damn AFM) and my car is a blast to drive again! I love it!!!! A day after I got my tune I had to take my car in because I found out the engine mount was missing bolts and they didnt say anything about my tune. Depends on the dealer I guess...
2012 Camaro SS IOM "TigreSS" Borla "S" Catback C.A.I. Intake VMax Ported TB JRE Tune |
02-19-2012, 10:38 AM | #13 |
Chillin Like a Villain
Drives: 2013 2SS Blue Ray Metallic Dusk Ed. Join Date: Apr 2011
Do it afm sucks ass!
02-19-2012, 02:07 PM | #14 | |
Drives: S/C 2SS/RS Camaro-6M-VicRed Join Date: Aug 2009
Location: Alfie (Mariano) lives in Shelby Twp, Metro-Detroit
Most people that break an engine, smoke a clutch, break a trans or axle were probably punishing the car. I've done a lot of drag racing in the past but not with this car. I loved every minute of racing and I broke a lot of drive train components. If you race it, i.e, full throttle power shifts, 5K launches w/drag tires, stuff will break. It comes with the program. Seriously, ask yourself, how many people to you know that blew up an engine by normal "performance driving"? If you broke it, you probably deserve it and the manufacturer owes you nothing. Alfie
