03-07-2012, 01:41 PM | #1 |
Drives: 2010 CGM 2ss/rs M6 Join Date: Feb 2012
TURBONETICS and long tubes ?
Can the turbobetics kit be ran with long tube headers? or would i have to do a remote style setup?
03-07-2012, 04:36 PM | #2 |
Got Boost?
Drives: 2010 1SS RS Join Date: Aug 2011
Popcorn
Sent from my iPhone using Tapatalk. If is spelllled wrong deal with it. |
03-07-2012, 04:57 PM | #3 |
Got Boost?
Don't think long tubes will work but have seen some with shorties.
03-07-2012, 10:55 PM | #4 |
Drives: Camaro SS Join Date: Jun 2011
Long tubes won't work with Turbonetics kit. You don't need it.
03-07-2012, 11:16 PM | #5 |
Ghostly Unknown
Drives: Silver Ice 2010 SS/RS A6 Join Date: Oct 2008
no
TS416,GMPPLSX-LS3 6 Bolt Heads,Custom 80mmComp Turbo,ID850 Injectors, Lonnies Twin Pump Setup,Level 3 4L80E,DSS,3in Magnaflow Exhaust,CoolingMist Meth,RX Dual Catch Can,InnovateWB,Aeroforce Interceptor,AEM Truboost Controller,matte black CF5 Forgestars.700rwhp/712rwtrq
03-08-2012, 12:12 AM | #6 |
Drives: 2005 STi corn fed Join Date: Jul 2008
Why would you want them? Longer hot-side piping will just increase lag. The turbos will muffle the sound anyway.
03-08-2012, 12:47 AM | #7 |
Drives: Has Wheels Join Date: May 2011
Long tubes won't work, and you don't need it. Even shorties may not make a noticeable difference, and more testing is needed to determine that.
03-08-2012, 01:02 AM | #8 |
need....more....hp
Drives: The Neighbor Hater Join Date: Dec 2010
The amount of money you would spend on a set of headers does not make sense for turbo systems, seeing you can easily increase the boost with a controller. As someone else also stated there would be more lag with long tubes because it will take longer to push the gases through. You want to get the gases through the piping as fast as possible.
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims |
03-08-2012, 01:09 AM | #9 |
Are all you other Turbo guys running your car catless? A new company is supposedly creating forced induction capable cats. Currently, the high flow cats on the market and stock cats are eventually going to let loose, as many people are having cat failures on forced induction applications, especially turbos from the pressure/heat.
03-08-2012, 01:10 AM | #10 | |
need....more....hp
03-08-2012, 01:15 AM | #11 |
10-4 on that. I would be nice to save two tune files on a system that can swap from one to another for times like that because the A/F ratio will likely be way off from cats to catless.
03-08-2012, 07:50 AM | #12 |
Drives: ZL1 Camaro Join Date: Feb 2009
No cats on mine, but I do not need the car to be tested for smog here in FL.
03-08-2012, 09:09 AM | #13 |
I would recommend a set of ARH Smog Legal Headers.
Turbochargers Do In FACT respond to Exhaust improvements.
www.jannettyracing.com
03-08-2012, 09:32 AM | #14 |
I need to move to Florida, ha-ha. No smog rules sounds like a car lovers dream come true. I wonder if job opportunities are better than it was a few years out there.
Thanks Ted for chiming in. Those are supposed to be great shorty headers, and I'd love a pair. They are pretty expensive though, but you have to pay to play right. I just wonder how much of a power difference we would see from a cheap shorty header versus the new ARH ones on a turbocharged system to justify the cost difference. It does look like the ARH are of higher quality and will likely have great longevity and craftsmanship, which will always increase cost. |
Similar Threads | ||||
Welcome to the Turbonetics Family! | TurboneticsRW | Forced Induction - V8 | 19 | 08-09-2011 08:56 PM |
2010 Camaro SS Turbonetics Turbo System | TurboneticsRW | Forced Induction | 41 | 03-13-2011 07:56 PM |
