Old 03-11-2012, 12:08 PM   #1
Squintz Palladoris
Squintz Palladoris's Avatar
Drives: 2010 IOM 1SS M6
My LCAs for Smaller Diameter/more rear spacing wheels
I've been messing with this project in my spare time which I have not had alot of recently. Finally the finished product is on the car.
When I first wanted to tackle this project I was trying to design a nice LCA to work with the stock style shock. I didnt really like it. Thanks to Brett from BMR for kick starting my brain into not over thinking stuff, I decided to go with a different length shock which made the control arm MUCH easier to build. Plus it opened up a large array of choices in shocks.
I chose the Ride Tech Triple Adjustable coilovers
Coilover Resevoir
Special Thanks to my good friend Tim Bradham at TBC Race Cars in Fayetteville, NC for use of his equipment and facilities. And the beers I took from the fridge
Squintz Palladoris is offline   Reply With Quote
Old 03-11-2012, 01:58 PM   #2
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
Very Nice are you able to use 15" wheels
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 03-11-2012, 02:21 PM   #3
Squintz Palladoris
I will need a brake package to clear a 15" wheel. But I am 95% sure a 15" will clear with no issue. More likely to hit the trailing arm with a 15" than hit these LCAs.
I have some V6 brakes which will work with a 16", but may keep the brembos on there and run a wide 17" with a Big DR. Havn't decided yet. Just depends how much rear spacing/tire I can fit in the stock wheel well and if I can decide on using a radial over a bias ply.
Old 03-11-2012, 02:39 PM   #4
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
Looks AWESOME Squintz, very professional!!!! If you're not careful, you're going to have a large group of people knocking on your door wanting you to make some for them too!!! Are those your own custom trailing arms too? Congratulations, looks like a success to me!!!
blazzin1 is offline   Reply With Quote
Old 03-11-2012, 02:45 PM   #5
Squintz Palladoris
Thanks Blazzin. The Trailing arms and Toe links are from LPE. I did use the same clevis bracket on the LCA's as the trailing arms, purchaced from the shop that builds them for LPE.
I would love to build these for anyone who wants them. Unfortunately I just dont have the time to devote to it. I also had to modify the stock upper shock mounts to make these shocks work. They are spherical bearing mounts both top and bottom. This way I can mount them shaft down for less unsprung weight. I have a pic around here somwhere of the upper mount. Lemme dig it up.
Edit: Here it is
Old 03-11-2012, 03:33 PM   #6
bigsquirrel
My car runs on acorns....
bigsquirrel's Avatar
Drives: 2010 SS RS Inferno Orange
Impressive.
My car runs on acorns, the tears of ricers and these other slightly less important things...
2.9 Polished Whipple, Kooks LT 1 7/8 headers, HiFlow Cats, Kooks Sleeper catback, Cooling Mist Methanol Injection, PFADT Sport Sways, PFADT Springs, PFADT rear trailing arms, ADM intake, JDP stainless brake lines, Jegs Catch can, Stock SS wheels widened to 10 3/4, Hawks HPS Pads, Pedders Rear Subframe Bushing Inserts, BMR Center Brace, MSD BAP, AAC side markers, Emblem Pro's Custom Lighted Door Sills, Dash-Floor-Cupholder ABL lighting and other stuff....
bigsquirrel is offline   Reply With Quote
Old 03-11-2012, 05:00 PM   #7
Nessal
Drives: Exige, Miata, Ghia
Originally Posted by bigsquirrel View Post
Impressive.
You can say that again!
Nessal is offline   Reply With Quote
Old 03-12-2012, 09:03 AM   #8
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
That came out nice Squintz. Testing with a set of control arms now that look very similar to those
BMR guy is offline   Reply With Quote
Old 03-12-2012, 09:54 AM   #9
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: ...
PM sent
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 03-12-2012, 10:02 AM   #10
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
Old 03-16-2012, 04:45 PM   #11
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
So when are they going to be available ?
Old 03-16-2012, 10:46 PM   #12
Camaro427
Drives: 2010 SS2 Camaro
Great fabrication job on the control arms. How much longer did you make them and what are you rear camber settings?
Camaro427 is offline   Reply With Quote
Old 03-16-2012, 10:59 PM   #13
Squintz Palladoris
Thank You Sir. They are currently at stock length but are adjustable. Camber is at -0.07* right now. I will need to shorten them up a bit to get it to 0* at the current ride height.
Old 03-16-2012, 11:13 PM   #14
Camaro427
A thought on a second version might be to modify the control arm like you did with the trailing arm. This will give you a serious amount of flexibility. Just a thought. You sir are seriously talented and have done a great job.
List ZL1 Option Codes OldJedi Camaro ZL1 Forum - ZL1 Specific Topics 103 11-30-2011 08:25 AM
Fikse Wheels the leader in custom fit wheels 6061-T-6 Aircraft Grade Billet Aluminum Xplosive Performance Wheels / Tires 0 04-23-2011 12:43 PM
Setting up an IRS/Drivetrain for Drag Racing Kyle2k Suspension / Brakes / Chassis 44 06-05-2010 10:17 PM
Suspension guys out there - lets talk wheel hop Crowley Suspension / Brakes / Chassis 14 10-09-2009 01:06 AM
