Old 03-26-2012, 05:46 PM   #1
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
Has anyone towed a lowered SS on a U-Haul trailer?
I was wondering if anyone has loaded and towed there SS on a u-haul trailer? Did it fit easily? Any damage to the front bumper cover from the wheel tiedowns?
I need to tow one 800 miles behind a U-Haul truck and I'm questioning how well it clears, its lowered 1.1 inches and has a chassis brace as well, its a '12 convertible.
Has anyone one had any issues a using U-Haul trailer?
And before someone says drive it, I have several cars to move, this just makes the most sense and keeps some miles off of her, 7k already.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 03-26-2012, 05:59 PM   #2
Frank in MD
Raining Blood
Frank in MD's Avatar
Drives: 2014 SS Performance Sedan
Not personally, but I've seen it done, and I don't recommend it. The angle has to be just right or the undercarrige scrapes on the trailer.
Ordered 1/9/12 - Born 2/3/12 - Delivered 2/21/12 - '12 1SS/RS Summit White - TRADED.
2014 SS Performance Sedan #2974 - Red Hot 2 - S/R. & Spare. Built 01/09/14 #238 of 291 as configured
Frank in MD is offline   Reply With Quote
Old 03-26-2012, 07:23 PM   #3
wavrun2000
o come on
wavrun2000's Avatar
Drives: 06 GTO
Yeah those trailers are not really accommodating to a lowered car. Plus you have to drive all the way to the front of the trailer to properly secure it. May not seem like an issue but they have really tall wheel stops that your bumper has to clear.
06 GTO with three pedals like it should be
wavrun2000 is offline   Reply With Quote
Old 03-26-2012, 07:32 PM   #4
Orange5thGen
Orange5thGen's Avatar
Drives: 2011 Convert
Send a message via Yahoo to Orange5thGen
Have to use 2 by 6 or 8's like I did. What size wheels do yo have the tie downs go over your tires like a net so if they are 22's they won't work. I had the GM 21's and it was a tight tight fit. I used 2 2X8's then cut about 18" off each board to make ramps to the car ramps. I had the GM ground effects and had no issues. It is a tight fit but I did it.
Take the 18" pieces and put them in the front to protect the front spoiler.
Come see me at www.chicago5thgen.com TEAM LLT, , 2011 Covertible 1LT RS, JDM Color Shift Halo's, Showstopper Camaro Bowtie Led Mirrors, Side Markers and Engine Cover, Pace Setter Catback Exhaust, BK Coilover Kit, 21" Full Crome GM wheels, Tinted windows, I WIN BEARS Plate. Full amber ABL dash and door update with IOM interior panels.
Orange5thGen is offline   Reply With Quote
Old 03-27-2012, 11:40 AM   #5
urr2slo
urr2slo's Avatar
I'm running 275/40r20's on 20x9 wheels up front, front spoiler will be removed but I was wondering how close the lower bumper cover will be to the tire stop, when the suspension bounces will it contact the bumper?
I'm not so worried about the loading and unloading as the ramps will be straight out, not angled down from an inclined driveway.
Old 03-27-2012, 11:42 AM   #6
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
Hey Rick, make sure the trailer is at least 84" wide otherwise you have no chance of getting the camaro to fit. I have a trailer and a truck now, but i would need it back of course!
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
Old 03-27-2012, 11:45 AM   #7
midnighter
Drives: nothing
Check this thread out,
http://www.camaro5.com/forums/showthread.php?t=188269
Old 03-27-2012, 12:24 PM   #8
Hannibal
Hannibal's Avatar
Drives: Camaro SS & ZL1
I've seen it done several times on the Uhaul trailers. I was not confident in that solution so I opted for the two wheel cradle. This proved to be very easy and I had no issues towing the car.
Hannibal is offline   Reply With Quote
Old 03-27-2012, 07:05 PM   #9
urr2slo
urr2slo's Avatar
if the gas wouldnt cost so much i'd ask you to to it out for me. if i borrow your trailer to use, you would need to wait till i buy a new truck to return it , that would be awhile.
Old 03-27-2012, 07:50 PM   #10
ss409cid
ss409cid's Avatar
Drives: 2011 SS RS Convertible
I rent Uhauls. The trailers are not Camaro friendly. If lowered even less friendly. If it is your only option, tilt trailer to the rear as much as possible to load. Use 2x10s to extend ramps, and use 2x10s under front wheels of car to assist in tie down clearance. It is hard to load a lowered car on a dovetail trailer, Uhauls have no dovetail. Hope this helps...
ss409cid is offline   Reply With Quote
Old 03-27-2012, 08:01 PM   #11
Caspers2SSRS
Caspers2SSRS
Drives: Summit White 2010 2SS/RS Camaro
Its perfectly safe to use a UHaul AT Trailer to tow a SS model Gen5. If your car is stock/factory equipment, ride height, ie, its all good. The (W -wide series) Auto transporter is the one recommended by the UHaul prequailfying software used during the equipment reservation process. Anyone telling you otherwise isn't UHaul wise................. Casper loves riding on a UHaul AT all safe and cozy.
Caspers2SSRS is offline   Reply With Quote
Old 03-27-2012, 08:11 PM   #12
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
http://www.bhtrailerrentals.com/id4.html
check these guys out. they are in your neighborhood and offer trailer rentals.
I piss excellence
and fart awesomeness
Old 03-27-2012, 11:03 PM   #13
JWood
RJT 2LT is a blast
Drives: 2010 Camaro 2004 Tahoe
Towing on u-haul
i have done it several times but mine is a stock 2LT. Find a low spot in the road like a driveway or water crossing and put some wood under the front tires to clear.
JWood
JWood is offline   Reply With Quote
Old 03-28-2012, 11:45 AM   #14
urr2slo
urr2slo's Avatar
Thanks, but I am towing one way, from Nor-cal to Az.
On Sale- SLP SS and RS classic bowtie replacement badges with Landing Pad- Free Ship MarylandSpeed Exterior Parts & Accessories 4 02-03-2012 10:25 PM
FS: 1997 Camaro SS 30th Anniv 28K miles NEW JERSEY bigwoolyg Autos For Sale / Wanted 10 01-30-2012 05:49 PM
2010 camaro ss vs 1999 camaro vs u haul van inferno_orange_ss/rs Chevy Camaro vs... 4 05-23-2011 06:13 AM
Turned in my 335i today (warning long post) Fraxum 5th Gen Camaro SS LS LT General Discussions 108 09-11-2010 07:38 PM
Camaro SS manual shipment (not production) hold officially confirmed by GM (UPDATED) Tran 5th Gen Camaro SS LS LT General Discussions 715 07-23-2009 11:05 PM
