Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 05-04-2009, 11:20 AM   #1
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
She LIVES!!!!!!!!!!!!!!
1986 Camaro + 99 LS1 from a Formula Firebird + carb conversion + open manifolds = fun.
the beginning
after the stock motor and trans was pulled.... nice lift on the front....
push button starter
switch mounting box
switches.
red - msd ignition box
blue - cooling fans
green - fuel pump
orange - alternator
fuse block
side shot of the motor
front shot
top shot
first start attempt.
idle adjust. as it turns out, Josh didnt set the fuel pressure regulator right and it was overflowing the carb. dialed it back down to 7 psi and fine tuning the idle
still got some cosmetic stuff to finish up. gotta get into the shop and fab up some brackets for the coilpacks as well as chop the throttle bracket down so we can fit the air cleaner on the car. then tuck the wires away and clean it all up. we've got a pair of cherry bomb glass packs ordered for the exhaust... straight off the stock manifolds dumping right behind the front tires. stay tuned
I piss excellence
and fart awesomeness
Old 05-04-2009, 11:26 AM   #2
CamaroSpike23
Truth Enforcer
after watching the start up vid.... I just noticed the red car in the background flying by... stopping hard, then backing up to check things out. lol
I piss excellence
Old 05-04-2009, 12:18 PM   #3
theholycow
theholycow's Avatar
Drives: '02 GMC Sierra, '80 Lesabre
You looked right at the red car, in the video...
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios
2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong)
1980 Buick Lesabre family heirloom with 36,000 miles
2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease
she really underestimates the damage i would do to her reproductive organs
http://allOffTopic.com is the place for all the naughty stuff you can't get away with on this forum...
theholycow is offline   Reply With Quote
Old 05-04-2009, 12:44 PM   #4
CamaroSpike23
Truth Enforcer
yeah... but my mind was on other things when we shot the footage...
I piss excellence
Old 05-04-2009, 02:06 PM   #5
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
noice.
Old 05-04-2009, 02:26 PM   #6
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Cool stuff Spike....
What made you decide on Edelbrock for the induction?
That car will surprise a few people.
Old 05-04-2009, 02:55 PM   #7
BowtieGuy
Enlightened
Drives: Nothing Currently
Because they are the kings of all things topside of the engine for the SBC.
This is what I'm starting to consider for my third gen. Make sure to keep me in the loop, I want to see this thing develop.
BowtieGuy is offline   Reply With Quote
Old 05-04-2009, 04:44 PM   #8
CamaroSpike23
Truth Enforcer
budget really. we've spent too much on this setup IMO. for all the expenses combined, to me, there's not much showing for it. but I like crazy setups too.
as for the edelbrock stuff, the intake manifold and MSD box had just come into the scene after we had pulled the motor apart for the rebuild. and instead of spending another thousand or more for the pcm, wiring harness, injectors, rails, new fuel pump, etc. Josh showed me this setup and it was only like $650.00 for the intake and MSD box. there's another version out there now, this one uses chips to "tune" it for different cam specs. the newer version actually has a hook up so that you can do live tuning on it.
the carb was just a spare one I had sitting around. I would have preferred to go with a holley (more tuneability IMO), but we had the Eddie and money was some what of a concern, so we used it. we are going to go with this combo for a little while. after the summer we are replacing the rear end with a Strange S60. after I blow up the stocker that is.
then the plan is to move on and build an LSX 454.
they are good for a lot of stuff for the top end of todays engines. some things are better/cheaper depending on where you go.
but if you want some more info about the build, let me know. ive got a few more pics and a detailed build plan for every thing.
I piss excellence
Old 05-04-2009, 09:04 PM   #9
speedster
SST...
speedster's Avatar
Nice Spike.
Now that is what Hot Rodding is all about !!!
I know where there will be a spare L99/LS3 soon...
Old 05-04-2009, 09:17 PM   #10
Inspector 17
I love crepes
Inspector 17's Avatar
Drives: 2017 ZL1 NGM A10
FRANKENMARO is alive!
Nice work Spike. Can't wait to see what's next.
Inspector 17 is offline   Reply With Quote
Old 05-04-2009, 09:18 PM   #11
CamaroSpike23
Truth Enforcer
Nice Spike.
which one? lol I'm actually wanting to play with both, but from a tuning standpoint, im intrigued more by the L99. as for the 86, we are actually planning on a 454 LSX sometime in the future.... running about 13:1 cr on 105 octane and a meth kit.... should be fun
I piss excellence
Old 05-04-2009, 10:30 PM   #12
speedster
SST...
speedster's Avatar
The L99 from my car.
Only 13:1....holy crap. Nice. Crisp.
Old 05-05-2009, 10:20 AM   #13
CamaroSpike23
Truth Enforcer
well, I already know an LS3 will fit nicely into a 4th gen. might have to take an L99 and drop it into the 78 LT....
I piss excellence
Old 05-05-2009, 11:26 AM   #14
Muscle Master
SS Lightning
Muscle Master's Avatar
Drives: An SRT8
Got a rough estimate on HP, and what kind of transmission you use T-56
The first rule of modding something that's not American is to not try to compete with modded V8 cars that are American. Really, they can run insane power with little investment. It's not even a fair fight.
Camaro 2SS RS, IBM, White Rally Stripes, custom fuel door: Status: going to the dealer: soon
Muscle Master is offline   Reply With Quote
Chrysler lives to fight another day: Alliance with Fiat successful nester7929 General Automotive + Other Cars Discussion 2 03-30-2009 01:38 PM
GM, Ford, and Chysler CEO's fighting for their lives on CSPAN camaro5 General Automotive + Other Cars Discussion 9 11-19-2008 09:48 AM
Plymouth Barracuda Lives Iroc-SS General Automotive + Other Cars Discussion 57 11-07-2008 09:26 AM
Super Vette Lives Up to Hype Sizzox General Automotive + Other Cars Discussion 3 10-25-2008 05:34 PM
