Old 03-29-2012, 10:21 PM   #1
Ykmaro
Ykmaro's Avatar
Drives: 2011 2LT/RS
Rough idle, rpms bouncing
Help!! My car is idling rough, sometimes while shifting from from 2nd to 3rd the rpms flare up and then go back down. Also the rpms don't move up smoothly they go up in increments.. Like move up, stop, move up, stop. And if the car is in 5th or 6th it bogs and the rpms don't go up, they just bounce. What could this be?! A6 2011 2LT
Ykmaro is offline   Reply With Quote
Old 03-29-2012, 10:31 PM   #2
SS Product
Super Sport Productions
SS Product's Avatar
Drives: 2010 Camaro 2SS, SIM
Check your blinker fluid
2010 Camaro 2SS/RS SOLD
SS Product is offline   Reply With Quote
Old 03-29-2012, 10:40 PM   #3
usafboy
usafboy's Avatar
Drives: 2010 Silver SS/RS LS3
mines done this for as long as i've owned it. just assumed it was normal but hopeing down the road a tune and TB and/or Black Iceolator can take care of this issue
2010 Silver Ice Metallic Camaro SS/RS LS3
Mods...so far: resonator/muffler delete, tinted everything, '13 shift knob/boot, bowtie delete, PFADT sway bars, CAI intake, Hurst short shifter, JBA cat deletes, BMR trailing arms/outer bushings/steering rack bushing, Bo White ported TB.
Rhino79 Dyno tuned...405 HP/399 TQ
usafboy is offline   Reply With Quote
Old 03-30-2012, 04:16 AM   #4
allmotor
movin' down the motorway
allmotor's Avatar
Drives: Summiit White 2SS/RS/M6
Not that this is your problem, but mine did that after I installed a ported FAST intake. Not so much while shifting, but if I put the car in neutral and coasted, the RPM needle would "hunt" 4-5k and at the bottom of the RPM range, would almost feel as if the car would stall. I was having some work done at JRE and Ted retuned it. Perfect now.
So the way I see it, this is a perfect excuse for you to install some bolt ons and get a tune!!
417 stroker - Florida Speed and Power
allmotor is offline   Reply With Quote
Old 03-30-2012, 06:06 AM   #5
usafboy
usafboy's Avatar
true...but the problem i'm running into is my wife hates me buying car stuff bcus she doesn't understand how we are lol
Old 03-30-2012, 11:55 AM   #6
yourWHAThurtz
yourWHAThurtz's Avatar
Drives: 2012 Camaro 2SS RS
I have the same issue with the rough/fluctuating RPMs while idle. Took it to the dealership and had them document it. If it causes any problems in the future, I know who'll be footing the bill...
| SunTek CXP 35% Tint | Muffler Delete | Gloss Black Vinyl Bow-Ties | AAC 3156 Chrome Signal Bulbs | AAC P13W Plasma LED DRL Bulbs |
yourWHAThurtz is offline   Reply With Quote
Old 03-30-2012, 12:00 PM   #7
Scalded Dog
Scalded Dog's Avatar
Drives: 2011 1LT
The tach in my Silverado flutters around when I've got a battery or alternator issue. Is it possible that it's not the engine stuttering, but might be a tach or electrical malfunction?
BTW... my LT1 has never once showed anything but a smooth needle float in between any RPMs or any gears... so I would assume that it isn't "normal" to have fluctuations like that.
Scalded Dog is offline   Reply With Quote
Old 03-30-2012, 12:15 PM   #8
yourWHAThurtz
That was my first thought... It isn't terrible but it does seem to be irregular (not a consistent fluctuation). I've read some posts that said it's typical for the aggressive cams and bigger engine on the SS. Not sure if I trust that judgment so I had it documented at the dealer service center.
Old 03-30-2012, 01:48 PM   #9
Chevrolet Customer Svc
Drives: GM Vehicles
YK, if you haven't modded your vehicle and you're having these issues I would suggest having your vehicle checked by your dealer. Hopefully they can get this taken care of for you. If not let me know and I'll do what I can to help you.
Jeff Morris, Chevrolet Customer Service
Old 03-30-2012, 01:51 PM   #10
js19racer
js19racer
js19racer's Avatar
Drives: 2011 Camaro 2SS/RS
Might be a bad or loose spark plug wire.
js19racer is offline   Reply With Quote
Old 03-30-2012, 01:58 PM   #11
1hotchevy
Scottish Knight
1hotchevy's Avatar
Drives: RS/2SS 6 speed manual
could be as simple as a bad place to buy gas...bad gas can make it do that,, remember winter gas has ethonol in it
1hotchevy is offline   Reply With Quote
Old 03-30-2012, 02:26 PM   #12
buzzy56
buzzy56
buzzy56's Avatar
Drives: 2ss summit white L99
Air leak ?
Check to see that you do not have an air leak , manifold ,intake tube , hoses et'c..Found my engine idling erratically and jumping around last week. Warmed her up good and re tightened all of the intake clamps .The idle smoothed right out and has held steady since.
OLD SCHOOL / NEW SCHOOL COOL
buzzy56 is offline   Reply With Quote
Old 03-30-2012, 03:06 PM   #13
iHasCamaro
Drives: Silver 2012 1SS
I had this happen to me on a different car after the oil from my intake got sucked onto my MAF sensor. Do these cars have a MAF or MAP? If they have a MAF you can probably clean it w/ electronics cleaner.
iHasCamaro is offline   Reply With Quote
Old 03-30-2012, 11:19 PM   #14
Ykmaro
Ykmaro's Avatar
Drives: 2011 2LT/RS
I had a k&n CAI on and just out it back to stock so this might be why. I'll buy some MAF cleaner tomorrow and see. Problem wasn't fixed going back to stock
Torque Converters CamaroSpike23 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 48 08-16-2014 02:07 AM
Rough idle Lazzzr Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 07-06-2011 01:43 AM
Rough Idle issues Moonshade 5th Gen Camaro SS LS LT General Discussions 4 12-20-2010 11:54 AM
Rough Engine Start After Tune? Tanner Tuning / Diagnostics -- engine and transmission 9 10-08-2009 12:25 PM
GM High Tech Performance Magazine's L99 Tune - +81 ft lbs at 3500 rpms! SGOS252382 Tuning / Diagnostics -- engine and transmission 52 09-30-2009 11:31 PM
