![]() Drives: 2011 Camaro 2SS RS Join Date: Jul 2011
Spare Tire SS/RS
For those who are looking for spacers, Adapt It USA sells them at reasonable prices.
You Can Order a a spare from GM - TI55/70R18 Get a jack and lug nut wrench and you are set. My spare fits right over the battery with no problems. http://adaptitusa.com/contact-us.aspx
![]() Drives: 2018 1SS 1LE Join Date: Oct 2011
How much is the spare ?
![]() ![]() ![]() Drives: 2011 SS RS Convertible Join Date: Sep 2011
Good info,
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: ABM SS2/RS M6 Join Date: Apr 2011
I paid $500 for my spare tire, spacer, jack, and lug wrench for mine as a package. It ALL fits in battery compartment.
Life is short, drive it like you stole it! ![]() |
I bought a kit from a friend which had the jack, lug wrench & tire for $200.00. Check with your local dealership.
#6 |
#7 | |
Thanks...
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
OP, what thickness spacer did you get? I have an early 2010 so I don't have roller skates on my calipers to clear.
#9 |
You should be good 1 3/4 in.
#10 |
spacer is at least 3" wide, it fits on the lug pattern. im not home to tell you exact measurement
#11 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS RS M6 Join Date: Mar 2011
I have an early'ish 2010 2SS RS but I just bought it very lightly used two months ago. What are these roller skates you refer to? Any pic to illustrate maybe? Thanks.
#12 |
![]() ![]() ![]() Drives: 2012 Camaro 1SS LS3 Join Date: Jul 2008
Can someone briefly tell me how the adaptor works? Does it fit onto the hub with it's own lug nuts, then you mount the spare onto the adaptor and use the factory lugs to secure it?
If that's the case, how do you tighten the lugs when putting on the adaptor without the hub spinning--at least on the front? What kind of lugs would you get for the adaptor so they are small enough to fit the spare over? Any info?? |
#13 |
It was a fix to dampen for a vibration issue. Early models like mine actually have wheel weights epoxied to the calipers. Open the link provided in post #6 and there is a pic in that thread.
#14 | |
Thanks
| Ginger gets a spare tire! Clears roller skate brakes. | SUX2BU | Wheels and Tires Talk Sponsored by The Tire Rack | 17 | 05-24-2011 01:55 AM |
| Tire Monitoring System | monevz28 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 7 | 11-22-2009 03:42 PM |
| R6P, VIN and spare tire question. | CyberDude | 5th Gen Camaro SS LS LT General Discussions | 10 | 07-06-2009 05:16 PM |
