Old 04-02-2012, 07:50 AM   #1
epstein
Drives: SS/RS
Send a message via AIM to epstein
Fellow Eforce Owners
Recently I encountered a bird style squeak under my hood that would only happen during boost.I had this issue prior to replacing my valley pan leak and it was still present after. So naturally the belt was replaced and eliminated . After exhaustively checking and re affixing all of the vacuums and multiple test drives I noticed something odd. One of the 5mm Allen head bolts that hold the top supercharger plate was damp with oil. After looking up the design of the eforce there is no oil to leak. So This morning on a whim I checked the tightness of these bolts.... Yeah Not just one was loose But more like 6. My Unit has never been disassembled nor Painted .
And My Birdie....... She Flew away!
Brian
epstein is offline   Reply With Quote
Old 04-02-2012, 08:49 AM   #2
MA2010SS
Drives: 2010 Camaro SS
Did the bolts that hold the SC head to the lower intake have loctite blue on them?
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 04-02-2012, 09:16 AM   #3
JANNETTYRACING
JANNETTYRACING's Avatar
Brian
Good Find.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 04-02-2012, 10:03 AM   #4
toesuf94
toesuf94's Avatar
Drives: THR #11 E-force supercharged
Send a message via MSN to toesuf94
I shall check mine - thanks for the heads up! I know they are only supposed to be 'torqued' to 11 inch pounds - not really tight at all.
Cars and women are both going to give you problems...but you can pay somebody else to fix your car!
toesuf94 is offline   Reply With Quote
Old 04-02-2012, 05:55 PM   #5
oachalon
Drives: 2010 Camaro 1SS
My cover is leaking and i contacted edelbrock. They sent me a new gasket and longer bolts. In the email they say torque to 8 ft lbs. I havent had time to take the old cover off and install the new gasket. What did people use to access those back bolts? They are pretty tight to the firewall.
I was thinking about getting the covered painted since im taking it off. Any members on here have recommendations on where I could get the covers painted?
oachalon is offline   Reply With Quote
Old 04-02-2012, 06:05 PM   #6
epstein
Drives: SS/RS
Longer Bolts huh........ My opinion they need alot more than 8ft lbs...... The front bolts were done with a T handle 5mm.... The rear Bolts were done with a convention 5mm key...The short end
Ill contact edelbrock tommorrow and get me my bolts and Gasket.
Any Body shop can paint it for you .....just be weary of paint on inside and seam area.
Thanks Ted for the compliment
Old 04-02-2012, 06:12 PM   #7
Cpanthers85
Drives: 2011 Camaro 2SS RS
how many miles on your eforces before you are finding issues? You guys are making me nervous about putting it on! lol
2011 2SS/RS L99
2017 Chevy SS
1979 Z28
Mods: Kooks Long Tube Headers, RotoFaB EForce CAI, American Thunder Catback Exhaust, PFADT Stage 1 Drag Kit + Front Sway Bar, GM Strut Tower Bar. ZL1 Fuel Pump. Nitto NT05R. RX Catch Can.LS9 Cam and Springs.LS3 Conversion.JRE Fuel Rail Upgrade.Edelbrock Eforce.60# Eforce Injectors.Extreme Racing Tune. 523/495
MY BUILD THREAD
Cpanthers85 is offline   Reply With Quote
Old 04-02-2012, 06:59 PM   #8
oachalon
Cpanther,
I do not think its something to worry about. Just make sure your bolts on top are snug before putting the supercharger on.
Old 04-02-2012, 07:07 PM   #9
tjbusa
Serious Sleeper
tjbusa's Avatar
Drives: 2010 CGM 2SS/RS M6
I'm still in the process of installing, I will check them tomorrow. thanks
Drive-by
Fact of Life:
After Monday and Tuesday
even the calendar reads...
W T F
tjbusa is offline   Reply With Quote
Old 04-02-2012, 07:48 PM   #10
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '11 2SS/RS IBM/BLK M6
Thanks for the heads up Just checked All Ok here.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly
SSBUSDRVR is offline   Reply With Quote
Old 04-02-2012, 08:29 PM   #11
Camaro_Custom_Painted
Choke on that causality!
Camaro_Custom_Painted's Avatar
Drives: 2010 2SS/RS
Just checked mine too....the two center ones (along the back of the unit) were loose and there was a trace of oil around them. The rest were plenty tight.
Edelbrock EForce - Stainless Works Headers - BMR Sways & Arms & Toe Links & Control Arm Bushings & End Links - Rotofab CAI - Assorted Interior, Exterior, Underhood Bling - Red Jewel Stripes & Full Body Clear - Lexani LX15 Wheels - JRE Fuel Rail Upgrade - Kenne Bell BAP - Heartthrob XPipe - Elite Catch Can - Pedders Cradle & Front Arm Bushings - Hotchkis Strut Brace - MSD Wires - Carbotech Brakes - DSS 1000HP Axles & Driveshaft - Mickey Thompson Tires - Halo Harness - AutoMeter A/F, Boost, Fuel Pressure Gauges - Whats Next?
Camaro_Custom_Painted is offline   Reply With Quote
Old 04-02-2012, 08:44 PM   #12
oachalon
Mine were loose. i tightend them up first. I will see what happens. if it still leaks, i will change the gasket and bolts.
Old 04-02-2012, 09:10 PM   #13
epstein
Drives: SS/RS
Glad You guys are checking!......
Nervous?..... These units are rock solid.....I have over 15k on mine......
Old 04-02-2012, 09:50 PM   #14
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Good call.
I just checked and the center ones were a little loose also. This is an example of what makes these forums so great. Sharing information!
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000,
realcanuk is offline   Reply With Quote
DFW-Camaro5 formally known as DFW- Camaro Owners UnknownWarrior USA - Texas 2 11-11-2010 04:27 AM
C5 Owners Roll At Atlanta Motor Speedway musclecargirl USA - Southeast 48 10-18-2010 03:35 PM
Did you get a bookcover to hold your owner's manual when you bought your Camaro? vernal 5th Gen Camaro SS LS LT General Discussions 71 09-11-2010 02:54 PM
Free Dyno pulls to all new 5th gen Camaro owners in Ohio Area! IPS Brandon USA - Great Lakes 7 09-25-2009 11:30 AM
LSX owners: AFR Cylinder Head Owners FTI-EDC General Automotive + Other Cars Discussion 0 11-10-2006 06:54 PM
