Old 04-21-2012, 03:48 PM   #1
xfighter1
Drives: 2012 Camaro LS
My 2012 RX Catch Can Install
This is how I installed my catch can, I tried to mount it originally on the engine cover stud but it wouldn't fit without cutting the cover. I'm in the process of painting the cover so I'm not really up for that. So far I've had no problems and the cover fits easily back on. Just putting this out there for anyone installing one on the LFX.
xfighter1 is offline   Reply With Quote
Old 04-21-2012, 03:58 PM   #2
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Very cool
Lil' Nasty is offline   Reply With Quote
Old 04-21-2012, 06:21 PM   #3
JohnZ
JohnZ's Avatar
Drives: 2010 Camaro 2LT V6
Nice! I just installed my catch can today, but I cut the engine cover so it would fit on the stud. BTW, what did you do with the clear tubing that was attached to the drain?
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace
SS Brembo Brakes, Racing Brake Stainless Lines
JohnZ is offline   Reply With Quote
Old 04-21-2012, 06:57 PM   #4
xfighter1
Thanks! The clear tubing is still on, I just cut the majority of it off. Left about 4 inches of it on so I can still use it to drain.
Old 04-21-2012, 07:13 PM   #5
mycamaro2011
mycamaro2011's Avatar
Drives: 2010 Camaro 2LT Victory Red
I wanna order the catch can and breather but with a couple of posts I have read with blowing the main seal is worrying me alot.
Has everone verify what the problem was? was it a bad install or defecting breather or catch can?
The dealers in MA would never cover it if the found out some aftermarket part was installed..
mycamaro2011 is offline   Reply With Quote
Old 04-21-2012, 07:21 PM   #6
JohnZ
JohnZ's Avatar
What posts talk about blowing a main seal? I have only heard good things about the catch can.
Old 04-21-2012, 07:34 PM   #7
xfighter1
I have read one post where a guy had problems with his, but most people believed he installed it wrong, other than that every other post I read was nothing but positive, which is why I went with this as my first mod.
Old 04-22-2012, 08:12 AM   #8
CPT_Hoolie
CPT_Hoolie's Avatar
Drives: 2012 1LT RS
Is it possible to install the catch can on the drivers' side?
CPT_Hoolie is offline   Reply With Quote
Old 04-22-2012, 09:57 AM   #9
CrzyGamr2
Mid-Florida Camaro Club
CrzyGamr2's Avatar
Drives: 2011 2LT/RS
Yes. They make a bracket for that purpose.
CrzyGamr2 is offline   Reply With Quote
Old 04-22-2012, 10:00 AM   #10
11SynergyGr&Bl
JZ
11SynergyGr&Bl's Avatar
Drives: 2011 Synergy Green Camaro
nice spot ^.^ looks good there.
*2011 SGM Camaro*
Hi/low 8k HID kit, Injen WB long tube, Pfadt stage 2, Rx black ice-olator, Rx catch can (color matched =D).
11SynergyGr&Bl is offline   Reply With Quote
Old 04-22-2012, 10:18 AM   #11
CPT_Hoolie
CPT_Hoolie's Avatar
Drives: 2012 1LT RS
Thanks. Just wondering which bracket to get when I order my catch can. I'm installing a CAI brand cai and I'm wondering how much clearance there is for the catch can on the driver's side. I'm not interested in cutting my engine cover to fit the can on the passenger side.
OP, I like your solution. Which bracket did you use?
Sent from my SPH-M930 using Tapatalk 2
2012 1LT RS SW
15MAR12 purchased
22MAR12 Custom stripe install
25APR12 Installed CAI intake / ADM scoop / Roto-Fab windshield washer relocation
02MAY12 Installed RX Catch Can
...MORE TO FOLLOW
"Life's full of ironies, if you're stupid." -- P.J. O'Rourke
Old 04-22-2012, 01:21 PM   #12
SC2150
That is correct. Out of over 10,000 of these sold and in use the only oil leaks (no one EVER blew a seal out.....just caused leaks that stopped when they installed the hoses correctly) were from the hoserouted backwards so the checkvalve prevented the can from evacuating.
But some of the unscrupulous competitors have jumped on that and PM people considering buying that this is an issue. Something you see we dont stoop to. We report actual facts when mentioning anyone elses.
Awesome install soultion!! Will add this to the instructions!!
Old 04-22-2012, 04:34 PM   #13
xfighter1
Thanks!! I ordered it with the standard bracket. I love the looks of this, very well produced. Cant wait for their ported throttle body to come out!!!
Also, I have it set to the highest position so it can be seen better, but if you put the can lower on the bracket there is a lot of room for the can. I'll probably move it down when I get a cai installed. Just food for thought.
Old 04-22-2012, 06:44 PM   #14
mycamaro2011
Just wondering in this video is the hoses going into the injen intake suppose to be blocked off? looks like he has it connectted?
