![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
JRE SCT CUSTOM TUNE INSTRUCTIONS V5
JANNETTY RACING CUSTOM TUNE INSTRUCTIONS
When you Purchase an SCT X3 Hand Held Tuner from me you get ONE, 93 OR, ONE, 91 Octane Tune For Free 2010/11/12 Camaros Only, for your simple bolt on mods, CAI and Cat Backs, exclusions apply for Headers, cams, superchargers and nitrous and other vehicles. Custom Tuning for excluded items available at additional cost options on my site or contact me via email for a quote. Additional Tunes with minor changes are available AT THE TIME OF PURCHASE For 50.00 Each, i.e. Second tune for 91 Octane. Your new SCT X3 will come to you Blank, You will need to connect the device to your car and Upload Stock tune file. Here is how, Sit in the car, Close the Door, Turn off all accessories and Unplug any devices from the Power Ports, i.e. cell phones, radar detectors, navigation etc. plug the device in to your OBDII port, select Program Vehicle, Using the left arrow scroll left to UPLOAD STOCK, it will prompt you to turn on the key, Turn the Key on, But do NOT Start, Wait for the Dinging to stop and hit select. Your tuner came with a disc with Free Software called SCT Device Updater software, if not you can go to www.sctflash.com and down load for FREE, install this in your home or laptop computer Before you connect the device to your computer. Then After you install and OPEN SCT Device updater software, you can connect your X3 to your computer, Drivers should install automatically, then Get Stock File, Click Browse, Find your Desktop and Click Save. Go to your Desktop, there will be 3 files, Select the one with Your VinNumber.sul and email it to me tedj@jannettyracing.com along with your Full name, Address phone numbers, And all vehicle information Year, Make, Model, Engine, Trans, List of Performance Modifications and Preferred Octane 93 or 91. PLEASE RE READ LAST STEP, I CANNOT TUNE YOUR CAR WITHOUT THIS INFORMATION, EVERYONE SEEMS TO FORGET OCTANE REQUIREMENT. Then I will send you back a custom tune file for your mods. When you receive a response, Save the file to your desktop, it will be, YOUR NAME JRE TUNE.cef Again open SCT Device Updater, Then, connect your X3 tuner, select Load Custom Tune File, Browse to your tune file Select it, then select a position 1, then name it anything you like, i.e. JRE TUNE, click on program, you will see the progress bar at the bottom go green, then exit when finished. Connect to your car, Select Program Vehicle, scroll left to Custom Tunes, Select JRE tune and follow the on screen prompts. I have developed Dyno Proven tunes for all of the Product I sell, So Unless I instruct you to do so Datalogging will NOT be necessary. If I instruct you to Datalog your car, you will need LiveLink software to do so, you can download the software free here http://www.sctflash.com/tsupdates.ph...6&GUD=1&GSER=1 The best way I found is to use a laptop on the seat, First, Start the Car, Then Open the LiveLink Software Then connect the X3 to your laptop, Then connect the X3 to the OBDII Port of the car, Then Hit the connect button, a list of PIDs will come up, you will have to scroll through them selecting the Items below. Even thought they may not be named exactly as I listed them, I want you to select the following, but Try Not to select anything Not listed or doubles of any of the items listed. You may have to test several PIDs to see which ones work best or work at all on your car. Once you find a list that works well Save Configuration file for future use. Engine RPM - RPM MAP-Intkman abs prss FUEL PRESSURE ECT engine coolant temp – ecteng clt tmp TPS throttle position or pedal position – acc pdl pos 1s IAT intake air temp or Air intake temp – intk Airtmp MAF Mass Air flow Hz – Maffre 125 TIMING spark cylinder 1 – ign Tim Adv4#1cyl KNOCK RETARD – knk ret Vehicle speed Kph–? Long Term Fuel Trim bank 1 – ltf tri b1 Long Term Fuel Trim bank 2 – ltf tri b2 Pleas ONLY Select the PIDs Listed, Extra PIDs Slow Down Datalogging and give me useless information. Names can vary from computer to computer but you get the Idea. Once you have your PIDs configured and working, While NOT logging you can go to File/save LiveLink Configuration, for future Logging. Go find a open road somewhere, 1/2 mile or so long would be great, from a stop drive the car 1/4 throttle up through the gears normally shifting at about 4500 RPM Paddle shift works best on Automatic trans cars. Then repeat at about 1/2 throttle to 5500 RPM Speeding is not recommended or necessary 1st and 2nd gear are fine if you do not have the room. Stop, and Save Datalog As (Your name 4500-5500-WOT etc.) to your desktop. Email me the log files along with your Full name, Address phone numbers, And all vehicle information Year, Make, Model, Engine, Trans, and list of performance modifications, and any Comments you might think are helpful. PLEASE RE READ THIS STEP, I CAN NOT REFINE YOUR TUNE WITHOUT THIS INFORMATION. Please Do Not Assume I will know who you are By your Screen Name, or what kind of car you drive, or what your mods are, I deal with 50-100 people a Day so I must have all of your info right in front of me in ONE email so I can Properly Write your Tune. Your Cooperation in reading, understanding and following these directions will make this a Very Pleasant Experience for both of us. Thank you for Choosing JRE, Ted. If you have other questions about SCT this is the entire FAQ section http://www.sctflash.com/support/inde...goryid=3&nav=0
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
Banned
Drives: 10' 2SS LS3 M6 Join Date: May 2012
as an owner that is constantly adding little pieces, how does this compare to coming in and getting a dyno tune done?
I dont want to tune after every little mod, but want to get the most out of my mods each and every time. |
#3 | |
All of my tuning is created and tested on the dyno, and when you log and I analyze the logs and tune accordingly it is in most cases Better just due to my vast experience. Ted.
Just ordered mine from you guys...cant wait.
#6 |
BUMP for MARINE1991
#7 |
![]() Drives: 2018 Camaro 2SS 1LE Join Date: Jun 2012
Thanks, Ted, for the awesome tune you sent me. My car is running like a dream, and it seems to get better and better by the day.
#8 | |
![]() Thank you. Ted.
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: COTW 8/29/11 2010 CAMARO Join Date: Jul 2009
#10 |
Dances With Mustangs
I can confirm Ted's skill at tuning. He did mine in one go-around and nailed it. I was a bit skeptical at first about an email tune but I'm a believer now. I have a cam and other goodies and the car starts easily cold, idles well and runs great on the track. Couldn't ask for better!
Blue Angel is here!! ![]() 1SS/RS LS3 M6 IBM |
#11 |
![]() Drives: 2011 2SS/RS cyber gray/black strip Join Date: Dec 2009
How much is it? I'm really interested!
#12 |
See my web site for details or shoot me an email
http://jreperformanceparts.com/gm/20...10-camaro.html
#13 |
Bump
#14 |
Got Boost?
Drives: 2011 1SS/RS M6 SLP TVS 2300 Join Date: Oct 2010
Got my tune yesturday from Ted.. Great experance, car idle's and runs smooth!
2011 1SS/RS M6
MOD List: SLP 2300 Supercharged, Flowmaster AT Cat back, aux 4 guage cluster, 12" kicker sub and Kicker Zx400.1 amp, PFADT Lowering springs CAI Inc. CAI, Hurst Short throw shifter, JBA 1 7/8 Long tube headers. Future Mods: 416ci stroker. |
