![]() ![]() ![]() ![]() Drives: 2013 Camaro ZL1 M6 Join Date: Sep 2010
Speedinc tune issues with my A6 trans
I had Speedinc tune my car over a year ago and ever since it seems to have problems downshifting. For example when I drive 30-40mph and punch it, it downshifts and launches hard for less then a second then it seems to pop out of gear and downshifts again right away. All this happens within 1 second. It is really annoying and embarrassing when I try to get on it a bit especially when passing another car. I do not have any problems using tap shift to manually shift. I have been driving the car in manual mode to avoid this issue. Sort of defeats the purpose of an Auto.
I posted this in the transmission section but realized it should be here in the Tuning section instead. I took the car back and Speed inc attached the computer to my car's computer while I was driving and logged the data. They saw the problem and admitted that it shouldn't be this way but couldn't explain why it was doing it so they put the stock file back in the car to see if the problem would go away. Once the car was back to the stock tune, I had no issues whatsoever. Once this was verified they programmed the modified file back into the car but this time they disabled torque management and the problem went away for few weeks but surfaced back. Has anyone experienced similar issues with their Auto after a tune? I don't feel confident in having them alter the parameters any further and am thinking to go back and have them tune my car back to stock then take the car to another shop for a brand new tune. Any suggestions are appreciated. thanks
![]() Drives: a Panty Dropper Join Date: Feb 2012
Yep go back to them and have them reload your stock tune then Just talk to Ted @ JRE and have him hook u up with a SCT Tune
![]() ![]() ![]() ![]() ![]() ![]() Drives: none Join Date: Aug 2011
On a relatively stock car, the A6 is pretty easy to "tweak" and get some really solid results. It would be interesting to see what they did with yours that's causing this problem. Even more interesting is that they can't fix it.
Try Fast Motorsports maybe? A buddy just had this TBSS tuned there and has nothing but good things to say about them. |
#4 | |
Got Boost?
Drives: 2010 1SS RS Join Date: Aug 2011
I live an hour from Speed Inc. and have a JRE tune it that says anything. Sent from my iPhone using Tapatalk. If is spelllled wrong deal with it. |
Are you sure it's not the PAS kicking in? Does it only do this in Sport mode, or is it doing it in Drive also?
#6 |
Yes, sounds like I need to get Ted from JRE involved or someone who really understands the auto trans. I plan on installing a VVT-3 cam and delete AFM/DOD including a 3200 stall. At that time I will get a new tune. I really don't know if it's the PAS kicking in. It has this issue in sport mode and "D" mode with traction control on and off.
#7 |
When I tuned my transmission, I had alot of issues especially with downshifting, and long shifts. It almost seemed to fall out of gear. I had to reset the adaptive learning on the transmission, and everything then worked wonderful. It took me about 2 months to figure this out, I almost took it and had it tuned by a professional.
2010 IOM SS - CAI, VMAX ported Throttlebody, ARH Longtubes to tailpipe Yank 3600SS Torque Converter, GPI SS4 VVT cam, Custom tune by Rhino79
#8 | |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
Are your quickly flooring the gas or rolling into the gas.
Sometimes if you roll an A6 into the gas it will stair step down to the appropriate gear. So it jumps down a gear, then waits a second and drop again. But if you quickly push the gas pedal to the floor, the transmission should drop to the appropriate gear (without stair stepping down). Even the best tune, can sometimes stair step down a shift. But if its happening all the time when you go WOT, then the tune needs work. |
#10 |
If you happen to have a copy of your hpt file, I would be glad to take a look at it for you.
#11 |
![]() Drives: 2007 Corvette C6 983 RWHP Join Date: Dec 2011
these transmissions are not simple to tune right. Doing it wrong can cost you a tranny. If you have to mention that to your tuner, you might want to consider a different tuner.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam YSI / 3.0 pulley, ARH 1 7/8 headers, NPP Dewitts / dual spals, A&A dual pump fuel system. 3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me. ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper Circle D Triple Disc stall 1009 RWHP @ 7000, 817 RWTQ @ 6000, |
#12 |
You are correct these are not easy to tune. I purchased some transmission tuning training, as well as spent ALOT of time reading and asking questions and learning before ever touching mine.
#13 | ||
Good point. If I remember correctly my tuner said that thousands of parameters were changed but he didn't know exactly what all of the changes were. He was working with someone at HP Tuners and they provided him data to write into the computer.
#14 |
The issue your having sounds related to the downshift speed tables, but there are so many parameters its tough. I am in th process of tuning mine now and its a lot of trial and error.
