Old 06-26-2012, 10:56 AM   #1
jaggedx
Drives: Lots of stuff plus a 2012 Black ZL1
110 in Phx and my A/C is acting up!
it has happened a couple times now. After driving my car I have stopped and parked for a few minutes and when I re start the car the A/C blows warm. It is still on and in the same setting as when I parked. After getting back on the road it suddenly turns cold again, instantly. This is not normal for GM A/C I have owned nothing but chevys for a long time.
I hate dealers like no other. I would rather stab myself in the face with a fork than to deal with a service writer, But AC is a must for me here in the desert.
jaggedx is offline   Reply With Quote
Old 06-26-2012, 11:00 AM   #2
armysig
Catch me if you can
armysig's Avatar
Drives: 2012 IOM ZL-1
You don't have to go to a dealership. You can always find a shop that ASE certified to do the work. Check out Loud Pedel Motorsports, they might be able to help you out.
http://www.loud-pedal.com/
armysig is offline   Reply With Quote
Old 06-26-2012, 11:38 AM   #3
69NMYSS
69NMYSS's Avatar
Drives: '69 Camaro SS and '12 ZL1
I had the same problem when we hit 110 in Fresno. Remember, the engine bay is scorching with the boosted motor in 110 degree weather, so its going to take a second to get cold air moving again.
69NMYSS is offline   Reply With Quote
Old 06-26-2012, 11:55 AM   #4
HalinSS
Drives: ZL1 #879
I am in PHX as well and I have a similar condition with my AC. I am pretty sure its normal. Your car is black as well so it will be/stay heat soaked quickly.
HalinSS is offline   Reply With Quote
Old 06-26-2012, 12:07 PM   #5
AZ-ZL1
Dry Heat My @ss
AZ-ZL1's Avatar
Drives: 2012 ZL1 SUMMIT WHITE
Only 500 miles so far, but no problems.
AZ-ZL1 is offline   Reply With Quote
Old 06-26-2012, 12:18 PM   #6
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
You could give me the car, it is a little cooler in Tucson!
Sven59 is offline   Reply With Quote
Old 06-26-2012, 12:22 PM   #7
Blown355
Blown355's Avatar
Drives: 2017 ZL1 A10
The exact same thing just happened to me. 97 degrees here. Seemed to work fine after I started moving again. This sucks. I absolutely hate taking my car to the dealership.
2017 ZL1
A10
Redhot with stripe
Blown355 is offline   Reply With Quote
Old 06-26-2012, 12:27 PM   #8
FNBADAZ06
FNBADAZ06's Avatar
Drives: C6 Z06 Corvette
As an FYI.......for Corvette's, it was found that the A/C systems were overfilled with refrigerant at the factory. When the internal line pressures reached critical during use in the summer heat (I'm in Phoenix as well), the pressure switch will disengage the compressor.
Have a technician check for an overfilled refrigerant status in the A/C system.
Steve at Loud Pedal in Tempe could probably check this for you
FNBADAZ06 is offline   Reply With Quote
Old 06-26-2012, 01:49 PM   #9
BoostedX2
BoostedX2's Avatar
Drives: VR ZL1 #259/Nissan 370Z NISMO
Same thing happened to me several times. It seems that it will not work until a certain point is reached....perhaps the coolant has to cool down after you stop and turn the car off (at which point it gets real hot) and then starts flowing again...it did not do this in my 2010 SS...
BoostedX2 is offline   Reply With Quote
Old 06-26-2012, 02:56 PM   #10
jaggedx
Thanks for the input guys, At least it's not just me. That should actually make a diagnosis easier. The refrigerant rail pressure makes sense. I know that GM knows how to make A/C systems. My Black Duramax will freeze your nuggets off on a long trip.
Old 06-26-2012, 02:59 PM   #11
FNBADAZ06
FNBADAZ06's Avatar
I'm willing to bet you a beer on it.....then I can check out your ride when I collect on it
Old 06-26-2012, 03:10 PM   #12
ZL1Dave
ZL1Dave's Avatar
Drives: 2012 ZL-1 #1442
134 refrigerant requires air flow over the condersor to circulate properly at times. I wouldnt sweat it sounds like its operating normally.
ZL1Dave is offline   Reply With Quote
Old 06-26-2012, 03:17 PM   #13
BoostedX2
BoostedX2's Avatar
Sure is hot in Louisiana 100+ weather while its "getting ready" to work....
Old 06-26-2012, 03:27 PM   #14
FNBADAZ06
FNBADAZ06's Avatar
I was born in New Orleans......I feel for you when it get's that hot.
FYI.....113 here in Phoenix yesterday, 111 today ........and it's all heading your way
