Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Motorsports Discussions
Old 07-07-2012, 01:35 PM   #1
AdamZ
Drives: Eve - 2011 Camaro 2SS/RS
Drag radials?
Anyone have any information on where to get some decent drag radials that won't break the bank?
AdamZ is offline   Reply With Quote
Old 07-07-2012, 05:27 PM   #2
Rockit_z28
www.1baddogracing.com
Drives: 2010 IOM 2SS/RS Auto
Discount Tire
Rockit_z28 is offline   Reply With Quote
Old 07-07-2012, 11:53 PM   #3
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
Originally Posted by Rockit_z28 View Post
Discount Tire
Discount Tire is a good place to start.
I think one of the best drag radials that could still be used on the street are Nitto NT555R. I've seen some people run them on 18" C6 Z06 wheels (front). The NT555R's are also available in a 20" size, so you could use them on your stock wheels.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 07-07-2012, 11:55 PM   #4
AdamZ
I had people telling my that the 18 inch vette drag radials were cheap, easy to find, and good for drag racing which is what I need them for. Idk what kind of tires those are....maybe those are what you're talking about?
Old 07-08-2012, 12:06 AM   #5
LimaCharlie
The 18" Z06 wheels are available in OEM form or reproductions. Ebay usually has alot of them. Here is a reproduction company example:
http://www.factoryreproductions.com/...6-Z06-c141.htm
Here are the Nitto tires I'm talking about:
http://www.nittotire.com/Tire/nt555r
Old 07-08-2012, 01:02 PM   #6
Higgs Boson
Perpetual Order
Drives: indeed
do you need them to hook? nittos do not hook. Mickey Thompson hooks. nittos is for show.....
Higgs Boson is offline   Reply With Quote
Old 07-08-2012, 01:11 PM   #7
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Nittos will hook just fine. There the best option if you drive to the track. As you increase your power level look at the hoosiers or et streets.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 07-08-2012, 05:11 PM   #8
Higgs Boson
Perpetual Order
Drives: indeed
I will agree they are better than a stock tire but they still spin. I am not sure what your definition of "just fine" is but I have had Nittos, BFGs, and MT ET Streets and Street Radials on my street cars and Nittos are terrible for good 60 fts.
With a MT you can dump the clutch at 6 grand if you want and they will hook and that is with 850 HP in my Z06....
I have had Nitto 555Rs with 400 HP that don't hook.... To me, a 1.8 or 1.9 60 ft isn't even worth driving to the track. A stock powered car will get a 1.65 60 ft when it hooks so anything less is less than an ideal run, why bother? Because going in a straight line in 13.5 seconds is "fun?"
I race NHRA and IHRA Super Stock, race shifter karts, own some very high HP cars, tune stock cars and trucks as well as powerful ones.... I don't know what your background is besides having a supercharger on a Camaro but encouraging people to spend good money on tires to take to the track that simply do not have great traction is a horrible recommendation.
Why not just use what works best the first time??? The guy didn't say he wants a daily driver tire that works better than stock at the drag strip. he asked where he can get some decent drag radials. Key word is decent. Decent starts at BFG. Nittos are hardly decent (for the strip).
OP, if you are looking for something to use at the strip (and drive to and from the strip) I recommend Mickey Thompsons all day long. If you are looking for something you can put on your car without swapping them out, BFGs are better than Nittos but either will work.
If you go with MT, keep in mind radials are great for an automatic but if you have a stick, I only use ET Streets (non-radials). The sidewall takes the hit of the stick much better, radials hop and break parts....
Here is a clip of my old Z06 on ET Streets (non radials). Headers and a 100 dry shot only (and Pfadt coilovers on road course mode, lol):
http://www.streetfire.net/video/2001...gto_139156.htm
Old 07-08-2012, 05:18 PM   #9
lexlueger
lexlueger's Avatar
6
lexlueger
1.567
Nitto 555R
305/45/R18 Nittos hook...case closed. They may not have worked for you. I've run hoosiers/M/T/Nitto. The hoosiers are the most consistent of the three. I saw no increase in 6o times with nitto 555r/nt05r vs the M/T's. The hoosiers seem to be the superior drag radials on our platform.
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 07-08-2012, 05:25 PM   #10
Higgs Boson
Perpetual Order
Drives: indeed
6
lexlueger
1.567
Nitto 555R
I would not say case closed based on that, lol. You have a lot of HP to be able to even spin to a 1.56. If my race car spins it turns a 1.39, does that mean it hooked? No.
There are 100 examples of "nittos suck" for every example like yours.
However, there are good reviews on the NT05r.
BTW, have you tried a MT on your car (non-radial)? You may find even faster times. Unless you launched as hard as possible with no spin, there is more there.
BTW, what 1/4 mile time did that result in?
edit: I see you ninja edited. I agree, Hoosiers are also a good option. They are an even more dedicated tire than the MT, IMO.
Old 07-08-2012, 05:31 PM   #11
lexlueger
lexlueger's Avatar
BTW, have you tried a MT on your car? You may find even faster times. Unless you launched as hard as possible with no spin, there is more there.
Can you read? I said I saw no improvement in 60 times with the M/T. Another know it all internet hero.
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 07-08-2012, 05:36 PM   #12
Higgs Boson
Perpetual Order
Drives: indeed
Yes, I can, can you? I acknowledged your ninja edit, which you chose not to read, I chose not to delete anything from mine. Lol, who can't read? Now you're just being an ass.
I've made my recommendation. I won't call you any names. And I'm no hero. Just smarter than you are, I see you take offense to it. I understand. It must be difficult to be you. Maybe one day I can understand the pain you suffered in your life. Probably not though. Now, go get Superman, comic boy. I liked that movie when I was like 5.
Old 07-08-2012, 05:40 PM   #13
lexlueger
lexlueger's Avatar
Ninja edit? COOL STORY BRO.
The thread is about drag radials. I sure the OP in interested in someone with real world experience with these tires on a 5th gen not some internet super racer with a garage queen...
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 07-08-2012, 05:45 PM   #14
Higgs Boson
Perpetual Order
Drives: indeed
First, my race car is not a garage queen and my camaro is my daily, lol. What garage queen do I own? Are you now just going to throw odd things to say out there? What garage queen are you talking about, seriously? Are you on something?
Second, do you know what a ninja edit is? It means you clicked edit to add more info moments before I clicked reply. Had I clicked Quote, it would have read differently than your final post.
Cool story bro, lol.... I can see you have no ability to correlate appropriate internet memes and comeback lines to their appropriate comments or statements. I would have had to tell a story to get a "cool story bro."
You are highly entertaining. What random and unaccounted for statement will you make next?
As I have already stated, I have experience with all of the tires in question. Why are you making asinine statements? Completely false....
