Let's go Rangers!
I have an oil leak, off to the dealer!
![]() Hard to tell where it's coming from but my guess it the timing chain cover as it's seems to be coming from behind the serpentine belt. I'm sure either way this will not be an afternoon fix. This so sucks!!
Emerald Coast Camaros
Drives: 2010 Camaro 2LT/RS M6 Join Date: Nov 2009
That sucks. Hopefully the delear won't give you a hard time with your mods
Let's go Rangers!
My dealer is pretty good so I doubt it, but one never knows!
Let's go Rangers!
Turns out I was right, timing chain cover needs to be resealed. Will pick it up tomorrow, unless my other posts happens.
Sent from my 2LT/RS using Tapatalk |
Parts Guru Extraordinair.
Drives: '02 SS 'Vert M6 Join Date: Mar 2011
Actaully,its a chain . 3 of them,not a belt.
Please check out my other hobby ; http://jetphotos.net/showphotos.php?userid=1008
#6 |
Let's go Rangers!
Waiting on my rental.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP Join Date: May 2009
Have them check the chains while they are in there.
#8 |
![]() Drives: 2012 45TH 2LT RS Join Date: Jul 2012
To reseal the front cover will not be an easy job for the dealership, particularly while the engine is in the vehicle. The most significant concern I would have is any residual oil on the mating surfaces! The front cover is completely sealed by RTV, there is no gasket (except for the water pump to front cover assembly - they arrive together from the supplier at the engine plant POA). When the front cover is assembled to the engine block / heads at the plant, there is a precision RTV head that is programmed to apply the material perfectly. Out in the field, the tech must have ample room in the engine compartment to ensure that he/she is applying the bead correctly to perfectly oil free, clean mating surfaces!
#9 | |
Let's go Rangers!
Here is my bright red rental, Impala LTZ ![]() Sent from my 2LT/RS using Tapatalk |
#10 |
Hmmm cant you cut out a gasket for it since they come with none and simply use RTV?
Life is short, drive it like you stole it! ![]() |
#11 |
Let's go Rangers!
Forgot to mention, there was no question on my mods. Repair is fully warrantied!
#12 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
I replied incorrectly to the PM!! The V8 is simple, the V6 is a bear and 45th rs is absolutely correct on all counts.
#13 | |
Let's go Rangers!
#14 |
[COTW 4/13/15]
Drives: Supercharged LLT Join Date: Jul 2010
Hmmm is yours a late 2011? I know that's when they put better timing chains in the LLT
| Tags |
| chevrolet customer svc |
