| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
Drives a Maro
Ok.... car surging and dying again......
I had some perfect video of what it was doing but deleted it off my phone via PC by accident.
![]() So let me get the conditions laid down. NO CEL codes. When I am at low RPMs and only sometimes, it will drop to below 500 rpms and die. In gear only. Usually on an incline probably because of the load on the tranny in gear at low rpm. Instead of dying sometimes it will TRY to die but come close and then recover making it surge and buck up and down and up and down till it levels off. If I put my foot on the brake, it dies. Same thing it was doing before it went to Vengeance. Also, it seems that when it's hot outside is when it will do it. Not all the time but almost never when cooler out. Could be otherwise but as far as I recall. So maybe just cooincidence too. This surging and dying is WAY worse when the headers are open with the diverters. My air conditioner will only work when it's cooler out as well. When the air does work, it blows cold as ever. But when it's real hot out the AC just doesn't work. I wonder if it could be related at all? Also, I found my EVAP line kinked right where it's braided and is coming out of the rail where the fuel line comes up. I unkinked it but might still be collapsed til I get another one. I've done a number of things like a smoke test, on the entire manifold and adjacent lines. Checked the fuel pressure. Compression and leakdown test, looked for the header gasket to be leaking. So my questions are: Could a kinked EVAP hose cause this? Could it be related to the air conditioning problem? What else could it be? |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro Join Date: Feb 2010
On the A/C.... Fall will be here soon!!
9.80 @ 139.73, 1.45 60', 2010 Jannetty Racing L99
Any chance you added a breather? My car had the same symptoms when we installed the breather. Ted needed to adjust the tune.
#4 | ||
Drives a Maro
![]() Quote:
Seems that Vengeance may have just masked an already there issue? Not intentionally of course but it wasn't doing this when it left them. Wasn't idling perfectly smoothly on the tach but I attributed that to the cam. |
Voodoo Medicine Man
Drives: Black 2SS with RS package Join Date: Jul 2010
How much gas do you have in the tank?
An overheating fuel pump can cause those symptoms...stalls out then when it cools off it will start working again
#6 | |
Drives a Maro
And don't scare me like that. ![]() Car runs great when given gas. Even when held to the right RPM. I'll try and keep notice though just in case. |
#7 |
Big Time Newb
Drives: C63 Join Date: Jun 2012
sounds like you need a proper tune. maf, ve, idle spark, base running airflow, proper idle rpm, etc. it takes a lot of time to properly tune idle. wot is the easiest, part throttle is easy, idle can take time to do right.
#8 |
![]() Drives: 2011 Camaro 2SS/RS M6 Hurst RJT Join Date: Apr 2011
I've ran into something similar working on an SS at a dealership. I found the electrical circuits going to the MAF sensor chafed on the coolant pipe right under the air duct. Also try checking your knock sensor circuits. They might be contacting your exhaust headers and making and breaking contact with the heat. I hope this hepls.
#9 | |
Drives a Maro
Can a tune regress at all?
#10 | |
Drives a Maro
I'm not familiar with the knock sensor locations though. After I installed my blower this same thing happened. Seems it's back. The MAF sensors wires were good. But I'll look again. |
#11 | |
Big Time Newb
and no a tune won't regress but idle issues can show under different circumstances when not complete. any time you change the tb size or way air flows into the engine you should retune the idle. a cam drastically alters this. a tb alters this, even a ported one. most people rely on trims to try and compensate but it doesn't always work under all conditions. |
#12 |
The knock sensors are right above the oil pan and the left and right sides of the engine. I'll see if I can find a pic and post it.
#13 | ||
Drives a Maro
The problem can come and go in one trip to the store. Engine hot and cold has no bearing. It's done it both hot and cold. Just seems that the outside air temp can effect it. SEEMS anyway. Quote:
#14 |
![]() Drives: a Panty Dropper Join Date: Feb 2012
Yes on knock sensor is right above the oil cooler and the other is on the opposite side in the same location
#15 |
Drives a Maro
I'll check it out.
#16 |
Drives a Maro
Also, the tach needle bounces more than I'd like but might be normal. When it is acting up though it bounces pretty good.
#17 |
Quit being a pu$$y
You check the MAF? Sounds like dirty or faulty MAF.
#18 |
I noticed the same thing with the SS I looked at. The tach would bounce around all over the place. I pulled these pictures. Hope they help.
#19 |
Drives a Maro
I haven't had it checked. It was good before Vengeance. I had actually swapped MAFs with another Camaro. LOL
It still did the same thing. I'll try it again though. Might have to wait for the fest though. |
#20 | |
Drives a Maro
I've been down there. I know right where they are. Ya, my tach only bounces 200 rpms at it's worst. But still shouldn't do that. Even cammed I'd assume. |
#21 |
I bet when it drops down to 200 rpm you have to give it gas, and if you don't it dies?
#22 |
Drives a Maro
Well, it is cammed so really if it drops below 500 at all. And that's when it surges to try and recover if it can.
#23 |
I have mine cammed too and it has dropped low rpms maybe once or twice that i can remember where I did have to give it gas to keep it from dying. I don't know if it would have to due much with the tune, but all is possible.
#24 | |
Drives a Maro
That's what it will do. I don't mind having to give a a bit of gas but it sucks when it dies in front of everyone. And then it takes a second to start.
#25 |
"Black Ace"
Drives: 2SS/RS black/black Join Date: Aug 2008
^This. Do you have a ported throttle body? I had similar problems after getting cammed and dyno-tuned. It may need the idle raised slightly and/or more air, if I recall (I'm not a tuner though; I believe that's what was done to fix my issue).
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Maggie TVS 2300 SC, Spinmonster cam (230/234, .613/.598, 114+1) installed & dyno tuned by Lashway Motorsports, Richmond 4.10 gears, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane differential & cradle bushings; UMI trailing arms & toe rods. 568 rwhp/493 rwtq (conservative mustang dyno, 5 lbs. [bleeding] boost). |
| Thread Tools | |
