Old 07-19-2012, 06:09 PM   #1
2012ZL1
CaRaHoLiC
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
Curbs
Ok I smacked my splitter on a parking curb. How much are these things?:(
2012ZL1 is offline   Reply With Quote
Old 07-19-2012, 06:18 PM   #2
BeachBum
Drives: 2012 (ZL-1) #468
Let Me Know When You Find Out - I'm Always Watching The Speed Bumps And Curbs Too - With Only 6" Of Clearance I'm Too Going To Hit Something
BeachBum is offline   Reply With Quote
Old 07-19-2012, 06:33 PM   #3
RoketRdr
RoketRdr's Avatar
Drives: 2010 Duramax; 2012 CTS-V Coupe
Here ya go. http://www.curb-alert.com/index.php I know it's a little late now but will save ya from the next one.
RoketRdr is offline   Reply With Quote
Old 07-19-2012, 06:44 PM   #4
2012ZL1
CaRaHoLiC
Ya I found the part number 22894223 95.00 not too bad. I'm in for the curb alert though....
Old 07-19-2012, 07:03 PM   #5
Bad@ssCamaro
BeckyD Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
That is a great idea, that's going on the "to get" list.
Old 07-19-2012, 07:13 PM   #6
gmgdave
gmgdave's Avatar
Drives: 12 ZL1 & 08 Suzuki Boulevard C50
I got a replacement for $85.00
2012 ZL1 - #413 - IOM - Mods; Exhaust Commander. GMG Third Brake Light Pulsar, Tinted Windows, color matched Engine cover, ZL1 Floor Mats
gmgdave is offline   Reply With Quote
Old 07-19-2012, 07:29 PM   #7
Higgs Boson
Perpetual Order
Drives: indeed
You split your splitter?
Higgs Boson is offline   Reply With Quote
Old 07-19-2012, 07:44 PM   #8
htron50
htron50's Avatar
Drives: 2017 ZL1 Status "Thank You!"
HAHA>.. i just bought one to have as a spare before they get scarce. They ship from Tennessee I think. Not sure exactly. But they are cheap. Just going to be hard to find soon I think.
GM Part # 22894223 List $131.17 You can get for under $100!!
Then you need 8 plastic bolts to hook it up... maybe not if you can reuse the old ones, but in case you need them
GM Part # 11570637 List $4.39 Can get for about $3 or less each
htron50 is offline   Reply With Quote
Old 07-19-2012, 07:59 PM   #9
AZ-ZL1
Dry Heat My @ss
AZ-ZL1's Avatar
Drives: 2012 ZL1 SUMMIT WHITE
I came within an inch on the 1st day.
Now I back in, almost always, or I'm 3 ft away and 50 yards from any other car on the lot.
AZ-ZL1 is offline   Reply With Quote
Old 07-19-2012, 08:35 PM   #10
Taser Deployed
Taser Deployed's Avatar
Drives: 2012 Blk ZL1
+1! I use the hell out of my rear view camera.
Taser Deployed is offline   Reply With Quote
Old 07-19-2012, 10:10 PM   #11
1MtnGoat
1MtnGoat's Avatar
Drives: '12 SIM ZL1, 1 of 49
I have installed the curb-alert on my Z. It works on a part-time basis. When the voltage is above 13.2 volts (alternator charging) the unit turns on. When the voltage drops below this the unit turns off. Our alternators turn on and off as the car is driven. If the voltage has dropped (alternator off - battery voltage only) the curb-alert does not alert.
1MtnGoat is offline   Reply With Quote
Old 07-19-2012, 10:44 PM   #12
RoketRdr
RoketRdr's Avatar
GEEZ!! Wasn't aware of that...thanks for the info.
Old 07-20-2012, 12:14 AM   #13
1MtnGoat
1MtnGoat's Avatar
When the voltage drops you will hear a short beep indicating that the curb-alert is off. If your vehicle does not turn off the alternator it will always be working.
Old 07-20-2012, 12:14 AM   #14
hognutz
hognutz's Avatar
Drives: 2013 ZL1
I would try a little DC-DC step up conveter. regulate that at say 14v.
2016 2SS
2020 super duty on 37's
hognutz is offline   Reply With Quote
