Old 07-25-2012, 11:30 AM   #1
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Dragstrip gurus, I ask for your knowledge!
Hey guys, going down to a dragstrip on August 1st for the first time ever.
I have a v6 manual with RS wheels and tires.
Hit me up with all suggestions/advice/tips please!
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 07-25-2012, 12:00 PM   #2
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Pretty much the same things I've advised newbies to autocross (which I'm way more familiar with)
1. Have fun.
2. Don't worry about car prep other than what's required for tech or tinkering between runs. Mostly, just run the car the way you're used to it. There will be plenty of time to tinker at future events. See #1.
3. Don't even worry about "slow" numbers on your slips. See #1.
4. See #1.
Norm
Norm Peterson is offline   Reply With Quote
Old 07-25-2012, 12:54 PM   #3
ihaveacamaro
I like teeth.
Drives: #198
1. Have fun.
4. See #1.
Norm
Thanks Norm, I will definitely make sure to have a blast!
Old 07-25-2012, 01:14 PM   #4
Quick
Quick's Avatar
Drives: 2012 Camaro SS 45th
Everytime you enter the staging area you will become more and more comfortable with
the whole process. Take your time and enjoy yourself.Its all about the fun factor.Plenty of time to get serious later on.Once you get used to the process
then start trying to get better with your reaction times,launching your car and
hitting those shift points.Stay in the groove and let er rip.
OBX 1 7/8 LT's w/high flow cats. Doug Thorley catback w/x pipe. Cold air intake by CAI w/apex scoop.V-max ported throttle body.DynoSpeed tuned by Forest.369 rwhp/385 rwtq
Something wicked this way cometh...
Quick is offline   Reply With Quote
Old 07-26-2012, 03:23 PM   #5
ihaveacamaro
I like teeth.
Drives: #198
Thanks quick!
Keep it coming guys!
Old 07-26-2012, 03:29 PM   #6
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
The first few times you race, get accustomed to staging and the tree. When you get comfortable, put a little heat into your tires. Burn them out a little. The pirellis do great with a decent burnout
Old 07-27-2012, 02:59 PM   #7
ihaveacamaro
I like teeth.
Drives: #198
I've heard that burnouts are totally unnecessary on the stock Pirellis? A couple people have told me it's just a waste of thread
Old 07-27-2012, 04:37 PM   #8
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
i think they do better with a light burnout like a 5 sec one the first time of the day and after that like a hard launch to spin them for a sec or 2
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 07-27-2012, 05:16 PM   #9
lscamaro
lscamaro's Avatar
No, the pirellis for some reason act like a drag radial and do better under a little heat.
If you don't want to kill to much tread, take dekans advice. At least spin them once or twice to clean them off
Old 07-27-2012, 05:24 PM   #10
Norm Peterson
I would guess that's all that a first-timer at the strip needs to do. The entire experience is going to be new, and it's easy to forget new stuff when there's too much of it to try to remember.
Norm
Old 07-27-2012, 06:44 PM   #11
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
P-Zeros like to be heated. So do a little burnout to heat them up and clean them off.
With your power level, they should stick pretty well with a conservative launch.
Try to get off the line with very little wheel spin. It's better to roll off the line gently/smoothly than to roast the tires with an aggressive launch.
Good luck and have fun.
Old 07-28-2012, 10:03 PM   #12
ihaveacamaro
I like teeth.
Drives: #198
ok guys, sorry I should know this, but what's a good way to burnout? Never really had reason to until now....
Old 07-28-2012, 10:16 PM   #13
Frid
Frid's Avatar
Drives: '11 Camaro 2SS/RS LS3
I usually go around the water pit and then back up and then burnout a bit rolling. I don't dump the clutch. If you can understand what I'm saying
Frid is offline   Reply With Quote
Old 07-28-2012, 10:33 PM   #14
orbitearl
orbitearl's Avatar
Drives: 2010 r/s switchblade metalic
remove drivers floormat and all loose objects in the car, buckle up..cut off radio and air, tie your shoes tight, no, seriously! have fun! and dont have a full tank of gas! make sure your engine is full of oil, check all fluid levels
orbitearl is offline   Reply With Quote
