Solo Performance
Camaro 1LE Forum Camaro 1LE Package releated discussions
Old 08-07-2012, 09:37 AM   #1
Lgndryhr
Camaro for Life
Lgndryhr's Avatar
Drives: 2010 2SS/RS A6 CGM & 2013 1LT A6 VR
Send a message via AIM to Lgndryhr
Post Insideline Calls Camaro 1LE Their Favorite Camaro to Drive
Featured on Camaro5 HOMEPAGE
http://www.insideline.com/chevrolet/...rst-drive.html
2013 Chevrolet Camaro SS 1LE First Drive
Proof There Is Such a Thing as Too Much Tire
By Bill Visnic, Senior Editor | Published Aug 7, 2012
We've heard a lot this political season about the "1 percent," but Chevrolet is more concerned about the "2 percent." That would be the sliver of Camaro owners who spend enough quality time on racetracks to feel qualified to complain about the Camaro's understeer. In response, Chevrolet has brought back Regular Production Option 1LE.
Striking out to "fix" understeer can be tricky enough, but there is another thing driving the development of the 1LE package for the 2013 Chevrolet Camaro: pride.
The Camaro guys are a little tired of losing the lap-time war to Ford's Mustang Boss 302, particularly the Laguna Seca version. Ford even has an openly designated "Track Package" for the standard Mustang GT. Nuthin' like that for the Camaro, so Chevy thought it was high time to get back in the game.
What You Get and How To Get It
The 1LE option package is an amalgam of reverse-engineering-type thinking and parts-bin scrounging, but it starts with a 2013 Chevrolet Camaro SS. Specifically, a Camaro SS coupe with a six-speed manual transmission. Automatics and convertibles need not apply.
Most of the 1LE's suspension hardware is borrowed from the prodigious Camaro ZL1, and we'll get to that nitty-gritty shortly. The most important takeaway, though, is that a 2013 Camaro SS with the 1LE option — the Camaro that effectively is being billed as the hot setup for the racetrack — actually gets less tire. Sort of.
See, the 1LE package adds the 20-by-10-inch-wide front wheels and 20-by-11-inch-wide rear wheels straight off the ZL1. But instead of also employing the ZL1's staggered tire setup (285/35s up front and 305/35s at the rear), those crafty development engineers stretched the ZL1's narrower front tires over the 11-inch rear wheels in their quest to dial out understeer.
The Camaro SS with the new 1LE package might just be our favorite Camaro to drive.
It was a little more complicated than just having a 285/35 at each corner. You don't get a demonstrable change in chassis behavior just with a change of rubber width — you've got to get down to some suspension work, too.
So the 1LE package brings in monotube dampers and 27mm front and 28mm solid antiroll bars, both 1mm thicker than the standard SS bars. The ZL1's wheel bearings, toe links and rear shock mounts are also added as part of the 1LE package. It didn't hurt that for 2012, all Camaro SS coupes got the ZL1 stabilizer-bar links that are positioned outside the control arms, facilitating steering response and further helping resist body roll. There's a strut tower brace and beefier rear axles along with some of the best feedback you're gonna find from any electric power steering (all 2013 SSs get this new variable-ratio EPS).
What Don't You Get?
Those same development engineers didn't think it was vital to upgrade the SS's standard brakes. They're already four-piston Brembos and you have to draw the line somewhere when it comes to cost.
And of course you'll note the 1LE is not like a ZL1 in two major ways: Under the hood is the SS's LS3 6.2-liter small-block V8, not the ZL1's whacked-out supercharged 6.2-liter (LSA). And although it gets new monotube dampers, the 1LE clearly doesn't step up to the ZL1's high-tech, magnetorheological Magnetic Ride Control adaptive damping.
There are some suspension upgrades, too. They include the ZL1's fuel pump and extra pick-ups for high-g track work. There's also the heavier-duty TR6060-MMG version of the Tremec six-speed transmission with closer gear ratios and a transmission cooler. Lastly, a shorter 3.91 final-drive ratio is also standard on the 1LE.
On the outside, 1LEs get a blacked-out hood and the same matte-black look for the rear spoiler and front splitter, as well as the black ZL1 wheels. And you'd have to be mad not to have some love for the ZL1's flat-bottomed steering wheel (good riddance to that ridiculously dished original wheel) swathed in suede microfiber, as is the short-shift lever from the ZL1.
Lose Some Grip, Right the Ship
It all sounds good on paper, but we didn't know what to make of it all until we took some hot laps around Gingerman Raceway in southwestern Michigan. And damned if it doesn't work.
After just a few acclimation runs, we started going into each turn a little deeper and attempting to adjust the line with the throttle. You can get the 1LE to rotate in a controlled and progressive fashion, a more difficult task with the standard SS and something that probably wouldn't be wise to attempt with the bombastic ZL1.
This with the Camaro's stability control set to the otherworldly calibrated "Competition" mode, leaving enough of a safety net to make us feel comfortable with indiscriminately applying power in 3rd-gear turns. At those speeds, the 426-horsepower LS3 is in the heart of its power band and begging to bust loose that narrower rear rubber. We can't answer for fully defeated stability and traction control; we judged there is plenty of "useful" oversteer without the sweat or drama of no traction control in a powerful car on a tight road course.
It's all about making the most of a just-right amount of slip from the rear tires, says Camaro Chief Engineer Al Oppenheiser. Where the standard Camaro SS (and even the ZL1) have just plain too much grip at the back, forcing the front tires to lose grip first in the corner, the engineered-in slip of the 1LE's narrower rear tires — in conjunction with the rest of the suspension fettling — facilitates rotating the car and steering with the throttle.
After our laps, we figure the 2013 Chevrolet Camaro SS with the new 1LE package might just be our favorite Camaro to drive — and probably not just on the track. Steve Padilla, the Camaro 1LE ride-and-handling engineer and the guy who probably most sweated the details, doesn't seem at all surprised by such a bold — and perhaps premature, given the brevity of our exposure — statement. He briefly flashes the knowing smile of a guy who may have reached the same opinion something like a thousand laps ago.
Street Legal, but Do You Really Wanna?
Chevy didn't give us any street time in an SS with the 1LE package, but we don't think the setup would be unbearable for everyday use. There's nothing necessarily "hard" about the tuning or the setup. Those accustomed to handling-oriented suspensions won't mind the ride quality a bit.
The 1LE is for the hard-core bunch, said John Fitzpatrick, Camaro marketing manager. He said the 1LE — the RPO code goes back to parts-catalog hardware put together for Pro-Am racing in 1988 — will be instantly known to the kind of Camaro buyer who wants such a setup. Chevy expects that to be about 2 percent of all Camaro buyers. Almost all will be ordered, Fitzpatrick adds.
And the best part about it? Those 2 percent won't have to have a "1 percent" level of resources to afford the 1LE. When it's available sometime around the end of August, the 1LE package will add just $3,500 to the price of the standard SS. Oppenheiser said owners of current Camaros will be able to replicate most of the 1LE package from the parts catalog, although they won't have access to the unique final-drive ratio or the new electric power steering. Bummer.
Better yet, the 2013 Chevrolet Camaro SS with the 1LE starts at $37,035 including destination, which makes it, ahem, nearly $6,000 less than a Boss 302, much less the Boss Laguna Seca.
"That buys a lot of track time," Oppenheiser deadpans.
Edmunds attended a manufacturer-sponsored event, to which selected members of the press were invited, to facilitate this report.
Build Thread
Current ride: 2010 CGM 2SS/RS A6 #128349 (his) &
2013 VR 1LT A6 #147344 (hers)
Exterior: Cyber Gray Metallic / Interior: Ebony
Nickname: Valkyrie
Best run: 13.5 stock on Pzero's with barely any tread left
How to hug your camaro
Buy the car that you would most like to get beat in. The other guy will always be faster.
Lgndryhr is offline   Reply With Quote
Old 08-07-2012, 09:46 AM   #2
PYROLYSIS
Remember the Charleston 9
PYROLYSIS's Avatar
Drives: 2004 KME PREDATOR (Engine 24)
Thanks for posting. A lot of people have been waiting to see a white 1LE. Very nice. I really want the RS package but the older style headlights look awesome.
Old 08-07-2012, 10:20 AM   #3
Lgndryhr
Camaro for Life
Lgndryhr's Avatar
Yes I too have been wanting to see a white 1LE. Very excited to finally see it. Just wish it had the RS package. I am surprised by how good it looks without it though.
Build Thread
Nickname: Valkyrie
Old 08-07-2012, 10:26 AM   #4
Bhobbs
Drives: 1998 Camaro Z28, 1970 Chevelle
The white looks good with the black hood and wheels.
Bhobbs is online now   Reply With Quote
Old 08-07-2012, 10:48 AM   #5
Mikamaro
(Prononce Mike-Camaro!)
Mikamaro's Avatar
Drives: A 2010 CAMARO SS-1LE
Location: In the Land of the GenIV Camaros & Firebirds.
http://www.camaro5.com/forums/showth...01#post5404901
Built #83817, Born January 18th 2010, First Drive May 15th, Christened June 11th 2010.
Mikamaro is offline   Reply With Quote
Old 08-07-2012, 10:55 AM   #6
Lgndryhr
Camaro for Life
Lgndryhr's Avatar
Originally Posted by Mikamaro View Post
Build Thread
Nickname: Valkyrie
Old 08-07-2012, 10:57 AM   #7
Mikamaro
Mikamaro's Avatar
Originally Posted by Lgndryhr View Post
Copy the text review in our original post and I will delete my post.
Old 08-07-2012, 11:28 AM   #8
1LEE
1LEE's Avatar
Drives: 2007 Cobalt SS/SC
I can't wait to purchase a 1LE!!
It looks real nice in white.... but I'm still leaning towards Vic Red.
I want to see an Ashen Grey 1LE before I make up my mind though.
1LEE is offline   Reply With Quote
Old 08-07-2012, 11:49 AM   #9
snizzle
Recalled user
snizzle's Avatar
Drives: '12 2SS MT 45th AE
Another good review.
2012 2SS 45th AE LS3 M6
Borla ATAK Catback
CAI Intake
VMAX CNC Ported Throttle Body
RX Polished Catch Can
Hurst Short Throw Shifter
Pfadt ZL-Spec Stage 3 Suspension
Old 08-07-2012, 12:07 PM   #10
Cpanthers85
Drives: 2011 Camaro 2SS RS
You can get that final drive ratio, though!!! Lies. lol
2011 2SS/RS L99
2009 Cobalt SS
1979 Z28
Mods: Kooks Long Tube Headers, RotoFaB EForce CAI, American Thunder Catback Exhaust, PFADT Stage 1 Drag Kit + Front Sway Bar, GM Strut Tower Bar. ZL1 Fuel Pump. Nitto NT05R. RX Catch Can.LS9 Cam and Springs.LS3 Conversion.JRE Fuel Rail Upgrade.Edelbrock Eforce.60# Eforce Injectors.Extreme Racing Tune. 523/495
MY BUILD THREAD
Cpanthers85 is offline   Reply With Quote
Old 08-07-2012, 12:07 PM   #11
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
So you can't go buy the 3.91 gears from the parts catalog?
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is online now   Reply With Quote
Old 08-07-2012, 12:20 PM   #12
Silver85IrocZ
Drives: 85 Iroc-Z Under Cover Z (car cover)
Thanks for posting this , nice write up ! !
Looking good in white .
hmmmm so many colors
new desktop background
1985 Camaro Z28 Iroc-Z 5.0 Liter Tuned Port V8
Silver85IrocZ is offline   Reply With Quote
Old 08-07-2012, 12:24 PM   #13
Mcchuck
Drives: 1999 Dodge
How about a 1LE vert with a GM roll bar installed ???
Mcchuck is offline   Reply With Quote
Old 08-07-2012, 12:48 PM   #14
DanSS24
DanSS24's Avatar
Drives: myself crazy
Not to be too picky but how about some high res shots of the white, I need new desktop wallpaper. Pleez.
I'd rather chase speeders and bad guys with a 1LE than my R/T Charger
DanSS24 is offline   Reply With Quote
Old 08-07-2012, 12:51 PM   #15
Jimmy Superfly
Jimmy Superfly's Avatar
Drives: 2012 IBM 1SS L99/A6
Hmmmm.... where have I heard this before......
http://www.peddersusa.com/products/21
I remember they had that 2010 SS with 305's on all four corners and people thought they were crazy.
2012 IBM 1SS L99/A6 -VMAX TB, CAI inc w/ Apex scoop, RX Catchcan, Pfadt Stage 2 FE4/ZL1 kit (springs and adjustable sways), Stainless steel brake lines
Jimmy Superfly is offline   Reply With Quote
Old 08-07-2012, 01:06 PM   #16
PYROLYSIS
PYROLYSIS's Avatar
Here's a video of Super Chevy driving this same 1LE around gingerman.
http://www.camaro5.com/forums/showthread.php?t=242130
Old 08-07-2012, 01:15 PM   #17
scottyvegas
X SS
scottyvegas's Avatar
Drives: 2010 Camaro 2SSRSM6 1988 Sportside
Very nice!
No animated signatures. Thank you.- Your welcome.
MODS: H&R SPRINGS, QTP CUT OUTS, PAINTED STRIPES, PAINTED SS EMBLEMS, PAINTED FIN, PAINTED REAR TAIL LAMP BEZELS, HERITAGE GRILLE, DUCTS, SKIP SHIFT, CENTERFORCE CLUTCH, HURST SHORT THROW, CAI INTAKE, SCOOP, WASHER RELO KIT, KOOKS HEADERS, KOOKS HI FLOW CATS, CUSTOM TUNE,AAC STUFF, FUZZY DICE, LASER BEAMS, DISCO BALL, SYBIAN & 3 CHROME VALVE STEM CAPS................
scottyvegas is offline   Reply With Quote
Old 08-07-2012, 01:25 PM   #18
Cpanthers85
Here's the part numbers. 3.91 Gears only - 22813040
And Here's the thread that talks about ALL the 1LE Parts for your SS.
http://www.camaro5.com/forums/showthread.php?t=237956
2011 2SS/RS L99
2009 Cobalt SS
1979 Z28
MY BUILD THREAD
Old 08-07-2012, 01:41 PM   #19
Char1ieone
Fear the Red Bow Tie
Char1ieone's Avatar
Drives: 2010 Black Camaro 2SS/RS LS3
SICK! SICK! SICK!!! Damn I so want to trade my 2010 2SS/RS for one of these!
Char1ieone is offline   Reply With Quote
Old 08-07-2012, 04:59 PM   #20
ken53007
ken53007's Avatar
Drives: 2010 camaro ss
Thats nice I wanna see one in inferno orange
ken53007 is offline   Reply With Quote
Old 08-07-2012, 07:33 PM   #21
b4z
Drives: '06 Pontiac GTO M6, '09 V8 SRX RWD
3.91s, but completely different gears in the M6 transmission.
b4z is offline   Reply With Quote
Old 08-07-2012, 08:07 PM   #22
psm6769
Drives: 67 Camaro
Think I'm going to sell my 67 for this. Anyone interested.
psm6769 is offline   Reply With Quote
Old 08-07-2012, 08:29 PM   #23
Blue Menace
Drives: 2013 WRX Sedan
To my understanding, you can add this package to an existing SS.
Blue Menace is offline   Reply With Quote
Old 08-07-2012, 08:59 PM   #24
PYROLYSIS
PYROLYSIS's Avatar
These are the only IOM 1LE pics that I know of.
Old 08-07-2012, 09:02 PM   #25
PYROLYSIS
PYROLYSIS's Avatar
You can add pieces of the package to an SS. New transmission and gearing would be very expensive. The wheels and tires alone cost about the same as what the 1LE package costs on a new SS. I think it would be cheaper to trade.
