Old 08-11-2012, 05:44 PM   #1
jmontalvo
jmontalvo's Avatar
Drives: 2011 Rally Yellow 2LS
Just installed some stuff in my NON-RS headlights (kinda pic heavy)
First of all, I'd like to thank lscamaro, austinjames, Dtrimpi87, Jonathan@AACstyle.com, SSinister 2010, and TCAT for their support.
Well after seeing Dtrimpi87's headlight setup, I knew I wanted to go that route.
I got the HID+projector kit from theretrofitsource.com and the halos from AAC. I got the Bi-xenon Morimoto Mini Stage III Kit (H1) with the GTi-R shrouds, H13 relay, and 5000K bulbs from TRS and the non-RS headlight halos+fog light halos from AAC. Total came out to around $700.
Since I'm a total noob with the wiring, I had someone else do this for me. I'm just going to post the pics in order.
Some a**hole left a water bottle here at one of the car shows I went to. WTF?! :fac epalm: I have no idea what the yellowish liquid is.
Total time was around 9 hours. Most of it was figuring out how to run the wires/mounting the projector. We put the the control box right under the radio/in front of the shifter.
I'll add more pics later on when it gets darker.
|Trifecta Tune|Custom Magnaflow Exhaust|Cold Air Inductions C.A.I.|BBK LTs w/ HFC|Anvil Rear Notch Glossy CF Spoiler|Body Color Heritage Grille|10 spoke polished ZL1 replica wheels|VMAX ported TB|RS Headlights|Night Owl RGB Halos
jmontalvo is offline   Reply With Quote
Old 08-11-2012, 05:47 PM   #2
looks great, I'll definitely be looking for the pics in the dark.
Old 08-11-2012, 06:21 PM   #3
STuRTzz
Drives: '12 Summit White 2ls W/Black Stripe
I have a lot of questions for you. Ill ask you the next time we play xbox together. Looks good!
STuRTzz is offline   Reply With Quote
Old 08-11-2012, 07:11 PM   #4
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Looks really good man! About the help... No problem at all! I have done a lot of retros before but have never done one with the demon eyes like you wanted. It came out amazing!
Old 08-11-2012, 07:15 PM   #5
puertoricanfont
puertoricanfont's Avatar
Drives: 2016 Camaro 2ss
Good job on the retrofit. Wait till night time that's when the retrofit shines it's true colors. You will no longer worry about not being able to see. It's like having th sun in the front of your car lol. Like yourself I also did a retrofit. I also see that your using the colorshift halos. I'm Definately leaning into buying those and ditching the one color halos. One question tho, why do the big halos look like they are too low?
puertoricanfont is offline   Reply With Quote
Old 08-11-2012, 08:02 PM   #6
jmontalvo
jmontalvo's Avatar
Thanks! I really appreciate it!
I'll be on for tomorrow's op so ask away!
Thanks man! I really appreciate your input and it came out great!
Thanks! I can't take all the credit though. I helped someone install them for me. Oh and I sure hope they're bright. I've heard of stories where the HIDs are worse than the halogens.
The halos were just a little big. My guess is to make sure there are points where the halo will glue onto the housing. I think the RS halos will be more visible since it can rest on the shroud. Get what I mean?
Old 08-11-2012, 08:19 PM   #7
puertoricanfont
Yea I know what u mean bro. I think for the non rs AAC halos they are glued to the actual headlight lens. It still look kick add tho. I'm definitely a lil jealous
Old 08-11-2012, 08:34 PM   #8
jmontalvo
jmontalvo's Avatar
They're not glued to the lens. They're glued to the points where it meets the edges of the chrome housing.
Old 08-11-2012, 08:47 PM   #9
lscamaro
lscamaro's Avatar
For non-rs they are glued to the actual lens. Well supposed to be. Mine look like puertoricanfonts do
Old 08-11-2012, 09:12 PM   #10
jmontalvo
jmontalvo's Avatar
Wtf?!?!?! Why do they add the adhesive on the back then?!
I experimented with it on the lens but the halo would come out at an angle with respect to the smaller halo. It really wouldn't look all that great.
Old 08-11-2012, 09:17 PM   #11
lscamaro
lscamaro's Avatar
I have no idea why the adhesive is even there. I don't use it. I have my own epoxy I use to secure the halos.
Old 08-11-2012, 10:25 PM   #12
puertoricanfont
Mine are flashtech. They are glued to the scatter shield because they are more circular than oval opposed to AAC. And I know what you mean about the projector not being centered. Mine look like they are but up close the projectors are not completely centered in the middle of the halos. Now This is how you are suppose to install the AAC halos http://www.camaro5.com/forums/showthread.php?t=198952
Old 08-11-2012, 11:25 PM   #13
AdamZ
Drives: Eve - 2011 Camaro 2SS/RS
You did awesome man.
AdamZ is offline   Reply With Quote
Old 08-12-2012, 12:54 AM   #14
Unfkwthabl
Unfkwthabl's Avatar
Drives: 2011 V6 Synergy Green Camaro
I dont think the outer halos are meant to be centered on the scatter shield. If you lift them up higher more of the halo will show instead of it being half hidden. Heres mine with more of the halo showing.
Unfkwthabl is offline   Reply With Quote
