![]() Drives: 2013 2LT/RS/GFX CRT/Beige A6 Join Date: Aug 2012
2013 2LT Dual-Mode Exhaust & OEM Body-Color GFX Question
I think I'm going to have to decide between the dual-mode exhaust option and the factory GFX package on my order. I don't think I can have the rear GFX with the dual-mode exhaust. I'm leaning towards the dual-mode exhaust with the option of maybe being able to just order the factory body-color sides and front GFX.
I really like the way the factory body-color GFX looks. So if possible, I would like to get it in some form with the dual-mode exhaust. Can someone please post pics of a 2LT (can be a different year from 2013 as these are fairly new or even a different trim) with & without factory body-color GFX? I would like to see all four pieces if possible. Also, I'm not quite sure what a diffuser looks like. Is this also painted body-color if your purchase the factory body-color GFX? Any pictures of this would be greatly appreciated. |
Pull up Cougar!
Drives: 2016 2SS Join Date: Jul 2011
Photo sub forum, you can find all the pics you want in there:
http://www.camaro5.com/forums/forumdisplay.php?f=3 Use the search tab in the upper right once you're there |
Yeah, I looked there first. Unbelievable amount of info to go through.
I'm really looking for side by side pictures of with & without OEM GFX. Didn't see anything like that, but I wasn't able to go through all the threads & posts because I'm on a time frame. I thought maybe someone could maybe help me out rather quickly and maybe give me a little guidance. Thanks for your attempt anyway. Last edited by kmmink; 08-16-2012 at 01:09 PM. Reason: Added OEM before GFX. |
Lastest info on my order
My dealer tried to add the dual-mode exhaust option to my order, but it could not be added because my order has the body-color ground effects package. So, the order is going through as placed.
He has offered to place a new order for me with dual-mode exhaust and no ground effects or I can receive my current order and they can add the performance exhaust as an option at the dealership. I'm waiting for him to give me a call to discuss this further, but I'm assuming he is referring to GMPP. I would like some opinions as to what route I should go and pros & cons. 1. New order with NPP & no GM GFX? 2. Current order with GM GFX & GMPP dealer install? - can I keep my rear GFX? 3. Current order with GM GFX & third party performance exhaust? - which one? |
#5 | |
![]() Drives: Corvette Join Date: Sep 2009
So, are they capable of getting it right? Will a dealer even do this? |
#6 |
okcamaros.com
Dual mode exhaust is a SS, 1-LE, and ZL1 only option from factory
#7 |
Please read the thread.
Dealer would add the performance exhaust (GMPP); not dual-mode exhaust (NPP).
#8 |
![]() Drives: someday a convertible Join Date: Sep 2009
(NPP) is available on the 2LT. Someone also posted it is only avail with the man trans. I had info that is was available on both auto and man. If you go to Cars.com and bulid a 2013 the NPP is available to select.
#9 |
They see me trollin'...
Drives: 217 ci of fury; Chauffeured by SS Join Date: Jul 2011
Here's a pic of my car and my boyfriend's side by side. Mine has the GFX rear diffuser and his doesn't.
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread |
#10 | |
#11 | |
Again, please read the thread!
This is the lastest information about my order and questions that I have:
#12 |
okcamaros.com
#13 | |
![]() Post pics when you get it
#14 | |
I guess I'm not wording my questions correctly or something.I know that the NPP will not work with the GM rear spoiler. That's not what I'm asking because I already know this. My order is going through with the ground effects and NO dual-mode. I can either accept this order or I can place a new order with dual-mode and NO ground effects. I want to know if dual-mode from the factory is worth delaying getting a Camaro? or should I just get the one I ordered and let the dealer add the performance exhaust (GMPP) - NOT NPP-I know this is factory install only? or should I just get the one I ordered and get an after market performance exhaust? Sorry if this is confusing. I'm trying to make an educated decision because it's not like I'm buying a shirt. |
