Old 09-12-2012, 07:11 PM   #1
DWALEX
DWALEX's Avatar
Drives: Currently 2016-2SS, Future ZL1/Z28
new frameless mirror retrofit
I'm going to show the way that I use to make this retrofit on my 2010
step 1
switch the Pin 10 (red) to Pin 6 (mirror connector)
step 2
I get supply voltage from the red/white wire from the instrument panel to console harness or
CLSTR fuse (F4) is the same circuit. With this wire is it possible to use the mirror (make call or connect to Onstar ) even if the engine switch is off as in the previous mirror by pressing the power button on the stereo and maintain the mirror on until the call is over
or
step 3
I get (Low Speed GMLAN) from instrument panel to console harness
step 4
I cut these wires. (Left-Light green Right yellow/black) the new mirror DOES NOT USE. this harness is under the right kick panel, closest to the door
I use this wires to send supply voltage and data signal
plug the GMLAN wire to Left-Light green
plug the supply voltage to Right yellow/black
step 5
connects the mirror and enjoy it
Apparently in the 2010 the Onstar module the green and red LED's commands to BCM are not sends
any questions send me a PM.
DWALEX is offline   Reply With Quote
Old 09-13-2012, 08:39 AM   #2
Bodih
I Got My Orange Crush
Bodih's Avatar
Drives: it like I stoles it...
Thanks for working this out. Pretty involved for just swapping a mirror!
Haven't had a chance to look yet (and probably won't until my mirror comes in).
Is there a way to fit in a pass-thru harness behind the right kick panel? That way I can Tap the fuse block, T-tap the GMLAN, and swap the pin in the mirror, without cutting any original wiring harnesses.
or
If there's space, I may try a pass-thru harness at the mirror connector and run the 2 wires down the A-pillar to the Accessory Power and GMLAN. Doing this, I won't have to swap the pins either! (Ofer; knowing you, you're already working on this...)
I like to keep the integrity of the OEM wiring wherever I can. It helps make troubleshooting easier later on when I dork up the next electrical mod!
Thanks again. Great job!
My love is in league with the freeway. Its passion will ride, as the cities fly by, and the tail-lights dissolve in the coming of night. And the questions in thousands take flight ~Robert Plant - Big Log~
Bodih is offline   Reply With Quote
Old 09-15-2012, 11:21 PM   #3
CausticGuy
Drives: 2010 Chevrolet Camaro SS/RS
Everyone was so excited for this, now it appears no one cares. Lol. Nice work figuring the wiring out!
CausticGuy is offline   Reply With Quote
Old 09-16-2012, 10:02 AM   #4
big papa
big papa's Avatar
Drives: 2010 Camaro SS/RS
Since I don't use any electrical funtions of the mirror, but want the smaller size, will I damage the car by plugging the smaller one in? Maybe I could mount it and not plug it in. Will this set off any alarms?
19 GMC CC 4x4
2019 Harley RGS
big papa is offline   Reply With Quote
Old 09-16-2012, 10:39 AM   #5
WCoolBreeze
2SS
WCoolBreeze's Avatar
Drives: 2016 2SS, Red Garnet Tint
I will more then likely add this to the Mod list after Ofer has the MyLink2 (with Nav) working on the 2010 Camaros. That is if the Backup Camera video can be displayed in the MyLink screen.
Walt B.
2016 Camaro 2SS
2005 Dodge Magnum R/T (Yes it has a Hemi)
1987 Camaro RS (California Special) - For Sale
Gen6, 2016 Camaro 2SS, Red Garnet Tint (with Silver Rally Stripes)
Ordered: 2-12-2016
TPW: 3-7-2016
Built: 3-7-2016
VIN 1G1FH78G0157626
Delivered: 4-26-2016
WCoolBreeze is offline   Reply With Quote
Old 09-16-2012, 10:46 AM   #6
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Its the time of the year it will move.
But if you dont connect it you will have no auto dim and may have Onstar problums.
Walt B.
I have the mirror here so dont buy one.
Old 09-16-2012, 11:55 AM   #7
DWALEX
DWALEX's Avatar
No it wouldn't damage the mirror or the car, and does no affect any alarm, but if you don't plug it, wouldn't have the function of the automatic dimming interior and outside mirror, and couldn't have communication with onstar through the mirror
Old 09-27-2012, 09:37 AM   #8
Bodih
Bodih's Avatar
Got my mirror last night. This thing is SWEET! I'd still like to work up a PnP harness before I install it, but may press forward on our next Mod & Maintenance Day, 6 Oct.
Old 09-28-2012, 05:30 AM   #9
buckeyemike
buckeyemike's Avatar
Drives: 2012 Camaro LS
God that is a sexy mirror. Forgive me if this has been answered, but is it auto-dimming?
buckeyemike is offline   Reply With Quote
Old 09-28-2012, 12:55 PM   #10
DWALEX
DWALEX's Avatar
Yes
Old 09-28-2012, 12:58 PM   #11
that mirror looks awesome
Old 09-28-2012, 01:08 PM   #12
anglwngss
Texas Camaros
anglwngss's Avatar
Drives: 2011 Synergy Green 2SS/RS
subscribed and bookmarked! This WILL be a future mod of mine!
anglwngss is offline   Reply With Quote
Old 10-02-2012, 10:02 PM   #13
ss04flores
2012 Camaro SS
ss04flores's Avatar
Drives: 2012 camaro ss
how much does the mirror run?
_________________________
2012 IMB CAMARO SS
ss04flores is offline   Reply With Quote
Old 10-03-2012, 06:20 PM   #14
2SSRS@Gen5diy
step 1
Attachment 421821
step 2
I get supply voltage from CLSTR fuse (F4)
Attachment 421829
step 3
Attachment 421832
step 4
Attachment 421834
Attachment 421846
step 5
Attachment 423575
Why did you use the power from the CLSTR fuse (F4), cant we use the power there for the old mirror?
