Drives: 98 Camaro Race Car 3.96 @ 202 MPH Join Date: Mar 2009
LMR and RPS clutches have worked together over the past few weeks to come up with our own exclusive clutch line for the new 2010 Camaro SS's. LMR now has the first aftermarket clutches available for shipment today! We decided to go with two different designs. The first one being an organic twin disc that will be able to support 600ft lbs of torque. The second clutch is our BAD BOY Carbon on Carbon billet twin disc clutch capable of holding 900ft lbs of torque. Over the past few weeks we have been testing this new Billet carbon on carbon clutch and I can tell you first hand that this thing drives like a dream for being able to handle such power. You will go through 3 cheap clutches before you even come close to breaking one of these. If anyone has any further questions or wishes to place an order today, please feel free to email me back or just give me a call at the shop. Thanks!
FIRST C7 Corvette in the 7's & 9's 2019 ZR1 LT5*9.00*@ 157 Current C7 World Record Holder 7.55*@ 184*MPH Quickest and Fastest GEN5 LT Powered Vehicle LMR1200HP Supercharged C7 8.84 @ 160** LMR1200HP Twin Turbo C7 9.35@155mph-2014 2 TIME OUTLAW DRAG RADIAL LSX CHAMPION 2008/2010 9.47 ZR1 Corvette-2009 FIRST 2010 CAMARO in the 9's-2010 713-466-9900 Latemodelracecraft.com |
![]() Drives: 2001 Camaro Join Date: Mar 2009
Sweet, No more worries on which clutch to use.
![]() ![]() Drives: on order black 2010 2ss Join Date: Mar 2009
nice!! whats pricing??
from a another board: 1295 for the organic and 2495 for the carbon on carbon.
![]() Drives: 2010 Inferno Orange 2ss Join Date: Jan 2009
Can someone explain the benefits of an aftermarket clutch to me? this is the only area i really dont know about bc i have never owned a manual...i get that its stronger but is there any other advantage to them?? thanks
Previously owned:
2010 Camaro 2SS M6 Borla S Type Axle back Dynatech 1 7/8" headers New Era intake Vector Motorsports tune |
#6 |
"That Guy"
Drives: Camaro SS...........what else? Join Date: Apr 2009
Location: OOOOOOOklahoma where the wind comes sweepin' down the plains.
Sweet!
#7 |
What can you tell us about the factory clutch set up?
Was: 2010 SS/RS M6 IBM R6P
Now: 2014 SS (Sedan) Mystic Green |
#8 |
One other advantage is the Carbon/Carbon it is lighter, I don't know the weights of the Organic set up. I have driven many cars with these clutches and they have the best pedal feel out of any other brand and can hold some thrashing.
#9 |
![]() Drives: 1999 Z28 1983 Z28 Join Date: Nov 2008
More importantly how is the pedal feel? Where does the clutch grab? Any chatter?
Current cars:
![]() 99 Z28 06 Silverado 14 Silverado |
#10 |
RR Status
wOw REALY there kina pricee for me ima just stick to the stock one for a while.... clutch never even crossed my mind but i will keep it in my mind now
#11 |
DIE HARD G.M.FAN 4 LIFE
Drives: 99 TransAm WS6,00 TransAm WS6,05GTP Join Date: Nov 2008
i aint a fan of the manual transmission but big ups 2 those who will be giving the streetz hell with these poerful twin clutches More Power to the 2010 Camaro SS
#12 |
![]() Drives: 92 firebird,2010 camaro Join Date: May 2009
Something to think about.Got to get here so I can try out the factory first.Then make a choice.
#13 |
Inferno is the only color
Drives: 96 ls6 camaro, iom 2ss/rss / Join Date: Mar 2009
Yeah defiately pricey. Biggest things are weight, and how they handle the power you put to them. when you upgrade , more hp and tq it will be harder for your clutch to grab and put the car into motion. In a stock application the aftermarket clutch will just last much longer and grab a lot harder when you release it.
#14 |
![]() Drives: 1998 Z28 M6 Join Date: May 2008
Now all we need is a TRULY reliable fix for the hydraulic setup.
I think RAM has a new non-GM design slave cylinder(which is what causes hydraulic issues) and when using an aftermarket master cylinder, might just do the trick. I know I might sound crazy, but I almost wish they had a mechanical setup so I would never have to worry about bleeding the hydraulics, keeping air out, keeping heat away and making sure the hydraulic seal in the slave cylinder stays where it should...
GTR: Get Transmission Replaced
