Old 11-02-2012, 12:04 PM   #1
Sean@Phastek
Sean@Phastek's Avatar
Drives: 2010 Camaro X5 Turbo
Thumbs up SEMA 2012 - Hot New Camaro Products! (MEGA PICS)
2012 SEMA Show in Las Vegas:
HOT NEW CAMARO PRODUCTS!
MGP Caliper Covers - Stealth Black Series
The new Stealth Black Series is available for the entire product line offered by MGP Caliper Covers. Paint fill options include silver, white, red, yellow, black, and even pink! Engineered and manufactured in the USA.
Trick Flow Specialties GenX 255 Cylinder Heads for GM LS3
Trick Flow engineers combined the best features of GMs LS3 and LS7 cylinder heads with its own unique brand of race winning engineering and technology to create the ultimate square port LS cylinder heads for 4.000 and larger bore engines.
Goodridge USA Camaro ZL1 Phantom Brake Line Kit
Designed specifically to fit the ZL1 Camaro, this kit improves braking performance and consistency by eliminating volumetric expansion associated with OE hoses. Phantoms feature black poly-coated Stainless braided PTFE hoses with Stainless ends, banjos and bolts. G-Stop kits ship complete with all necessary hardware to allow easy installation.
Squash Performance E85 Drop-In Fuel System
E85 compatible 1500HP dual pump in-tank fuel system. Integrates with the stock bucket to reduce effects of fuel slosh in the tank. Works with the stock jet pump system. Return style wiring harness assures maximum pump power.
Lingenfelter Camaro SS Differential Cooler Kit
Differential cooler kit for 2010-2013 Chevrolet Camaro SS. Includes temperature controlled fan and electric pump. For high speed and racing use.
Whiteline Suspension Camaro Rear Alignment Kit
Activate More Grip with Whiteline's adjustable rear alignment setup consisting of adjustable toe, trailing and lower control arms are designed to modify factory camber, toe and track on the Chevrolet Camaro
Proform LS Valve Covers
Universal GM LS Slant Edge valve covers. Multi-color, one box for 6 different style valve covers.
Trick Flow LS2/L92/LS3 Timing Chain Dampener GM
This timing chain dampener provides a small amount of tension on the timing chain to keep it from "Whipping" during gear change.
Whiteline Chassis Control Essentials Bushing Kit
Whiteline's Essentials Set for Camaro includes all the critical drivetrain bushings to improve handling and traction.
K-Mac Suspension Top Strut Mounts - Camber and Caster Adjustable
No modifications. Fast, accurate adjustment from engine the bay. Massive adjustment. Prevent costly edge tire wear or more traction on Race Days. Patents Pending.
Lingenfelter LSA to LS9 Supercharger Conversion Front Cover
Supercharger front cover for LSA engines to convert to LS9 TVS2300 Supercharger without having to change accessory drive or throttle location. Fits ZL1 and CTSV
Proform Coil Brackets for LS3 & LS7
Ignition Coil Bracket for LS3 & LS7 Style Coils
Lingenfelter Forged LSA Poston and Ring Set
Forged 4.070" piston, pin, & ring set for ZL1 & CTS-V LSA engines. Designed to clear the production piston oil squirters. For 6.125" connecting rod.
Lingenfelter Camaro SS & ZL1 Intercooler Radiator and Fan Kit
High Capacity Intercooler radiator and fan kit for the ZL1 Camaro and for Supercharged and Turbocharged Camaro SS applications.
K&N 2012 COPO Camaro Air Filter
RR-3005 is a Racing Only air filter designed to fit the 2012 COPO Camaro on the normally aspirated 427 engine.
Lingenfelter LSA Engine 2-Step and Timing Retard Controller
Adjustable RPM limiter with timing retard function for ZL1 and CTS-V LSA engines. Trigger activated retard for nitrous. MAP sensor based retard.
Trick Flow Oil Vapor Separator Tank System "Catch Can"
The oil vapor separator tank systems pre-clean crankcase ventilation gases before introducing them into the intake manifold. The modular design fits a variety of applications, including traditional open breather systems, late model closed systems, and systems for forced induction engines.
K&N 2012 Camaro ZL1 6.2L V8 Intake System
K&Ns Carbon Fiber Intake Kit uses an oversized conical shaped filter. The intake kit will fit into the engine compartment using factory holes and mounting points.
QA1 Front & Rear Sway Bars
Front Sway Bars are manufactured from lightweight hollow core 4130 Chromoly Steel for Maximum Strength and Durability. Rear Sway Bars are manufactured from heavy duty solid-core 1045 Cold Formed Steel. Features ability to fine tune the roll stiffness for 2010+ Camaros.
AIRAID MXP Cold Air Intake for 2012 Camaro ZL1
The AIRAID MXP Series Cold Air Intake System for the Supercharged 2012 Camaro ZL1 improves airflow by 19%! This new intake features a one-piece roto-molded air box containing a 1400 cfm premium air filter, and a massive 4.25" induction tube with a billet aluminum MAF housing. With custom tuning this intake is capable of 30+ hp gains!
JRi Shocks 5th Gen Camaro Struts
JRi's proven superior shock technology is now available in strut applications and complete coil-over systems for the serious competitor, who demands the highest performance while optimizing ride quality. Double adjustable struts and systems available for 5th Gen Camaros and S-197 Mustangs
Trick Flow Steam Line Fitting & Plumbing Kit for GM LS
The fittings attach to the corners of GM cylinder heads and feature -4 AN male threads. They're manufactured from black anodized billet aluminum and include O-rings and stainless steel bolts. The plumbing kits contain the fittings and all of the necessary hose to plumb just the front of the heads or all four corners.
QA1 Strut Tower Brace
QA1's New Strut Tower Brace for 2010+ Camaros drastically improves handling with quicker and more precise steering action. This unique design reinforces the front substructure and strut towers.
QA1 Rear Lower Control Arms
QA1's rear control arms are CNC cut and formed steel. They reduce control arm flex during hard cornering and acceleration. They are also designed to be stiffer in bending than the factory arm, allowing the shock and spring to work more efficiently and maximize grip.
QA1 Camaro Stock Mount Shocks
QA1's Stock Mount Shocks for the 5th Generation Camaro are available in Double Adjustable and Single Adjustable valving options. Designed with Drag Racing, Street Performance, Autocross, and Road Racing Applications in mind, these stock mount shocks give you the control you need and the performance you've been waiting for!
ProCharger NEW i-1 Supercharger
High efficiency centrifugal supercharger with programmable ratio, intelligent control system, dry hybrid drive, and optional touchscreen display. Available as a complete air-to-air intercooled supercharger system.
SLP Camaro and Corvette TVS 2300 Supercharger
SLP's all-new Roots Type TVS 2300 Supercharger are now available for 2010-2013 V8 Camaro and 2008-3013 C6 & Grand Sport Corvettes.
Holley Accessory Drive Systems for GM LS Engines
Die-cast brackets, OE style hardware, and commonly available accessories unite for a cost-effective, application frieldny choice that looks at home on any swap application.
COMP/TCI GM 6L80E Torque Converter
Bolt-together lightweight billet design for easy DIY drain, service/tune; unique modular, lockup clutch design yeilds highest torque capacity for late model Camaros & 6L80E vehicles.
Mr. Gasket/Accel Super Coil for GM LS3 Engines
Super Coils produce more power over the stock coils.
IPF Tuning / Vortech Camaro V6 Supercharger Kit
IPF Tuning Camaro V6 Supercharger Kit for 3.6L Direct Injection engine. Features Vortech V3 headunit, CAD designed brackets, molded silicon hoses, front mount intercooler and ECU tuned by IPF Tuning Power Flasher. Increases power from 305 hp to 435 hp and is available with a supplemental engine warranty. V8 Power with V6 Efficiency!
K-Mac Suspension for Camaro
Get power to the ground. We've had more experience with Camaro (2006 VE/G8 suspension platform). In Australia and New Zealand rules state mandatory (both GM and Ford) to use K-MAC adjustable bushes V8 ute race series for Safety and Performance.
Camaro ZL1 Brake Upgrade Kits from GM
Upgrade the front brakes on your 2010-and-later Camaro SS or V-6 model with the larger brakes from the supercharged Camaro ZL1
Camaro 1LE Suspension Upgrade Kit
Give your 2010+ Camaro SS greater capability in curves with the same suspension and drivetrain components used in the production 1LE performance package.
Billy Boat Performance Camaro ZL1 Bi-Modal Exhaust
Billy Boat Exhaust has designed an exhaust system specifically for the ZL1 Camaro using their proprietary PRT mufflers. Hand fabricated out of T304 stainless steel, the muffler offers increased exhaust flow and emits a nice deep muscle car, and enhanced ZL1 style growl at idle, roaring into acceleration and galloping through to cruising speeds.
QA1 Camaro Front Struts
QA1's Stock Mount Struts for the 5th Generation Camaros are available in Double Adjustable, Single Adjustable and Drag Race inspired "R" Series valving options. In addition to the adjustable valving, this bolt on strut allows for fully adjustable ride height giving you the stance you want.
Litespeed Racing Camaro Titanium Exhaust System
Litespeed Racing is proud to introduce its all new Titanium exhaust system for 2010+ Camaros. This system can be used as an axle back addition to your stock exhaust, or as a full cat back system. Titanium is 1/3 the weight of steel, and equally strong, while also providing better corrosion resistance, and a more exotic exhaust note.
New Products showcased throughout the show floor:
Sean@Phastek is offline   Reply With Quote
Old 11-02-2012, 12:18 PM   #2
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
Thanks for the coverage!
Old 11-02-2012, 12:22 PM   #3
Char1ieone
Fear the Red Bow Tie
Char1ieone's Avatar
Drives: 2010 Black Camaro 2SS/RS LS3
THANK YOU for posting these! Gets me really excited about what is out there and what is coming out, plus with you including the part numbers helps me in finding exactly on what I need. Very usful thread!
Char1ieone is offline   Reply With Quote
Old 11-02-2012, 12:29 PM   #4
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
My Favorite Phastek Thread each year...!!!!
Old 11-02-2012, 12:30 PM   #5
Sevn86
Sevn86's Avatar
Very nice!
3100 Sequenced:10/12/09
3400 Broadcast:10/22/09
3800 Produced:10/27/09
4200 Shipped:10/29/09
Old 11-02-2012, 01:55 PM   #6
RubyCamaro
Jan
RubyCamaro's Avatar
1LE suspension kit for V6
Waiting for pricing for the 1LE suspension kit for V6. PM when available.
Old 11-02-2012, 01:59 PM   #7
2010_5thgen
2010_5thgen's Avatar
Drives: 2012 Porsche Panamera 4
i really like the black vortech supercharger. i told myself when i got my camaro, that if i ever did a supercharger i wanted to get everything painted black on it, so it blends in more. very nice.
Brixton Forged
CM10 Wheels IN STOCK!!! RF7 SOON!!!!
Camaro/M3/M4 wheels in stock High Gloss Titanium
2010_5thgen is offline   Reply With Quote
Old 11-02-2012, 02:07 PM   #8
RatRacer
RatRacer's Avatar
Drives: 11 Synergy Green LS 15 Colorado Z71
The more I scrolled, the smaller my wallet got.
Thanks for the mini catalog pre-release.
RatRacer is offline   Reply With Quote
Old 11-02-2012, 03:29 PM   #9
DanSS24
DanSS24's Avatar
Drives: Dream Cars in my head
Interchangeability is a good thing. It's great that you can base V6 and turn it into a road race ace.
Wishful thinking...but I sure can dream big.
DanSS24 is offline   Reply With Quote
Old 11-02-2012, 04:23 PM   #10
Dent RS
Axes Kivster
Dent RS's Avatar
Drives: Camaro '12 2SS/RS
thanks alot bro for the photos , really great products .. ipf S/C :drools:
Dent RS is offline   Reply With Quote
Old 11-03-2012, 12:24 AM   #11
KILLER74Z28
MOD SQUAD
KILLER74Z28's Avatar
Drives: 2G1FT1EW9A9100666
I really like this thread.... NICE!!!
Who cares about the Blue Oval crowd and their little Ponys? We're getting our Camaro back-and it'll be Supercharged!-MDAII
Team LS3
KILLER74Z28 is offline   Reply With Quote
Old 11-03-2012, 10:10 AM   #12
camaro_RS
Emerald Coast Camaros
camaro_RS's Avatar
Drives: A lot of show, not much go.
Awesome thread! Thanks for sharing.
-White Mary Jane....build thread [COTW 6/11/12] :
camaro_RS is offline   Reply With Quote
Old 11-04-2012, 08:45 AM   #13
2SShowngo
2SShowngo's Avatar
Drives: 2013 black ZL1#456
AWESOME THREAD THANKS FOR SHARING....finally an actual parts thread without ugly ass firebird conversions!!!!!!!!!!
2SShowngo is offline   Reply With Quote
Old 11-04-2012, 09:54 AM   #14
showstopper
Drives: 2010 RS/SS
I need more details on that new Pro charger. What is the deal with that?
showstopper is offline   Reply With Quote
sema 2012 new products
