Drives: 2010 SS 426 V8 M/T Join Date: Aug 2012
My Camaro SS all the sudden feels slower???
Not sure what it is going on but all the sudden my V8 SS2 feels aweful slow?
No mechanical issues what so ever. Are I am getting used to the speed and power of the car or are I am crazy?? |
Con10der
Drives: 2010 2SS/RS M6 IOM Rally Stripes Join Date: Aug 2012
Time for mods!
Pend Install: Launch/Shift Light,BMR Susp/1" Drop/Sways/Track Pack,GM 3.9. Future: Janetty Pumpkin w/PosiTrac,1400HP axl,CF DS,Tick Stage 2 Trans,3 Disc Clutch,4"quad tip,center exit AB w/diff... |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '86 Monte Carlo SS Join Date: Nov 2010
Could be your power addiction.
Takes more to feed it. |
TRI COUNTY TAMPA
Drives: 2011 1SS/RS VR/BLK A6 Join Date: Jan 2011
Shouldn't be as it self cleans and isn't replaceable. It is part of the fuel pump in the tank. Entire pump has to be swapped out.
#6 |
Pull up Cougar!
Drives: 2016 2SS Join Date: Jul 2011
It's probably just you. Sometimes mine feels slow sometimes fast. It all depends how the butt dyno is working.
#7 |
Smoked by a GIRL
Id do a fuse pull. Ive done it twice on mine when it felt sluggish. Worked both times. Like kjkjr27 said, pull fuse 5 & 20 overnite. If by chance its had anything less then 93 octane in it, run the gas down to E, then pull the fuses. If the gas hasnt changed, just do the pull and dont worry about running the gas down.
2014 2SS/RS Summit White w/ IOM interior "Powder 2.0"
#8 |
Interesting.
The temperatures are perfect right not, lower 80's during the day and upper 50's at night. I will give the fuse pull a shot. Car only has 9300 miles on it. Been using 91 octane, that's all we have in AZ! |
#9 | |
TRI COUNTY TAMPA
Run it down to an 1/8th tank. Fill up with a top tier fuel like Shell then do the fuse pull and see what happens. |
#10 |
Just to clarify we talking about the fuse box inside the vehicle?
I have only been using Chevron since I owned the car. Shell also only has 91 octane! I hate to contaminate my fuel. |
#11 |
#12 | |
Yep , that's what it is , and no , there is no known cure . Good luck .
#13 |
Live for On Ramps!
Drives: 2010 Camaro/2LT/RS/T.F./6M "naomi" Join Date: Feb 2010
#14 |
