Drives: Camaro Justice Join Date: Jun 2007
NEW ZL1 Sway Bars and 1LE Balance Bar
![]() Your ZL1 delivered with a 25mm front bar and 28mm rear bar. These are by far and away the best sway bars to come from the factory. No is you would like to stick like the Pedders L/28 and Bruce Raymond's OPTIMA Invitational Camaros a.k.a. the Fastest 5th Gens then you want to upgrade you OEM Z bars to Pedders 27mm adjustable front and 32mm Z style rear. These are a direct replacement set of bars and compatible with the factory endlinks. Pedders rear Style Z bar fits with the most popular drag wheel and tire combination and also is the ONLY Z style sway bar that fits with Pedders Supercar Coilovers! ![]() The least amount of clearance to the inner wheel area is at full droop when the car is on a lift. As you can see, there more than enough clearance. ![]() ZL1 Sway Bars ![]() The semi-square wheel and tire setup on your 1LE delivers great cornering. Actually it was too good. Chevrolet backed it down by using a 27mm front bars with the ZL1 28mm rear bar. The bad news is that the larger front bar increases understeer. The good news is that Chevrolet finally put a 27mm front bar on the Camaro. Pedders has been running a 27mm front bar since early in 2009. 1LE owners can corner like Pedders OPTIMA winning Camaros by adding a rear 32mm Z style Pedders bar. This is a direct replacement of your rear 1LE bar and the droplinks will work exactly as designed with your new 32mm rear bar. I know you think you 1LE is great in OE trim. Try our 32mm rear bar. I guarantee you LOVE it. 1LE Balance Bar Both bar sets use the OEM sway bar straps for additional stability and improved function. Chevrolet Engineering did a great job with the OEM strap. The shape and width gives them tremendous strength. Pedders specially cast our sway bar bushes to take full advantage of the OE strap. You can see the Pedders bush is wider than the OE bush. So much wider you would think it would be hanging out of the strap. Take a close look at the next to perfect fit! ![]() ![]() ![]() ![]() ![]() Be sure to use the Coupon Code!!!! givingparts2012 15% OFF I can't stand these guys.They are always giving away my money ![]() |
Oh man stop the madness. Another Pedders part I need and want
My Build Thread
http://camaro5.com/forums/showthread...=1#post5036900 Maureen@Rodgers Chevrolet...The best prices and customer service period!!(734)676-9600 Gen5Diy.com.....http://www.gen5diy.com/ Wretched Motorsports..www.wretchedms.com/ Pedders USA...http://www.peddersusa.com/ |
Drives: His Wife Crazy Join Date: Jan 2008
Available to Ship!
With the sale prices and Free Shipping on orders over $500 you can't loose! |
SOON.........
Drives: 2010 ABM SS/RS Z-281LE Join Date: Jan 2008
You guys are going to make my wife have a mental breakdown.......
Whats the fitment for 2010s gonna run 275s all around with bushings, wanna maximize my setup.
#6 |
Get the pedders lca's and endlinks with both zl spec sways and you will be very happy. I have the oem zl1 rear sway bar and will upgrade soon as I dont feel it enough. only Pedders will go on my car as they are the best and Rob will take care of you
My Build Thread
#7 |
![]() Drives: 2012 Camaro 2SS LS3 Ashen Grey Join Date: Mar 2012
Why are they called ZL1 bars and 1LE bars? Is it because they are they they same style just thicker?
2012 2SS/RS, Magna TVS2300, RX Catch Can, Borla S-Type, Pfadt Stage 4 w/ ZL Spec Sway Bars, ADM Custom Boost/AFR Gauges, Hurst Short Throw, Forgestar F14 Matte Black 20x11 & 20x9.5 Deep Concave all 4, Nitto Invo 315/35 & 275/40, Heritage Grill, Sparks Black Grill SS & Trunk SS, P13W Fog Lights (cool white) w/ DRL Harness, Blacked Out Brake light bezels, Xpel Smoke Light Kit
#8 | |
The 1LE Balance Bar explains in the name how it can be used. We have been using a 27mm solid front bar since early 2009. The 1LE is the first Camaro from the factory with a 27mm front bar. We like that choice. The Rea 28mm bar is too small and biased toward understeer. Keep the front OE bar and add Pedders 32mm rear bar to get balancd with a slight bias toward oversteer. ZL1 = Needs a two bar upgrade 1LE= Needs a rear balance bar |
#9 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
#10 | |
#11 |
#12 |
