Old 12-15-2012, 06:17 PM   #1
DWALEX
DWALEX's Avatar
Drives: Currently 2016-2SS, Future ZL1/Z28
My new door switch
Here I show this video of my new switches on the doors when I get back from the holidays I'll show how I did and what parts I used to use the stock panel-through connector
Tools required:
T20, and T27 torx socket
7mm socket wrench
Socket screwdriver
Heat shrink tubing
Electrical soldering iron
Solder
Heat gun
Terminal crimper
Phillips screwdriver
Car Panel Removal Tool
Electical Tape
Precision Screwdrivers set
Wire 3 color and black
Parts you need:
door panels 2012-13 (driver and passenger)
door lock/unlock switch D.S#22879460,22847867. P.S#22847868
Conectors tyco (2) #1379029 (need a small mod) I have 1 sets with terminals available
TE CONNECTIVITY Terminals Micro Quadlok Syste Series (8) 963715-1
and for Panel-through connectors, "if you want to use this way" you need :
1- Female HPCS
FCI automotive Connectors #60013031 (1)
2- 1.5 Female Term
FCI automotive Connectors #60000531 (2)
3- 2.8MM Male Term
FCI automotive Connectors #60110631 (1)
4- 1.5MM SWS MALE
FCI Automotive Connectors #60100731 (2)
*these parts are hard to get, especially in small quantities*
Step 1:
I took the switch signal from radio/HVAC control or Body Control Module (X2 L-Blue connector). you can attach the t-tap to this wires. I prefer to solder the wires I would not do this if it was not permanent modification.
door lock switch lock signal Pink/Black wire
door lock switch unlock signal Orange/Black wire
Step 2:
make the connector. this is the switch diagram
Step 3:
must to pass the lock signal wire through the door connector. this thread can help http://www.camaro5.com/forums/showthread.php?t=155660
here we use the terminals for this connector
if you want to use this mode or can pass the wire around of rubber boot
body harness
door harness
on the door harness I changed the wire color. Please don't do that because it can be confusing
Step 4:
as had to pass two wires through the driver door connector. but only has one pin available, *I used the ABL wire (purple) for unlock signal and connect the LED (ABL) to the circuit LED backlight dimming (yellow)
ABL with my wiring
these are the steps that I took
DWALEX is offline   Reply With Quote
Old 12-15-2012, 06:23 PM   #2
montreal2010yellow
montreal2010yellow's Avatar
Can't see the video, it's private?
Old 12-15-2012, 06:31 PM   #3
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
It plays ok for me.
Caddy
Caddyroger is offline   Reply With Quote
Old 12-15-2012, 06:32 PM   #4
Caddyroger
Caddyroger's Avatar
Originally Posted by DWALEX View Post
Here I show this video of my new switches on the doors when I get back from the holidays I'll show how I did and what parts I used to use the stock harness
http://youtu.be/hUc8h_7PlIQ
Happy Holidays, C5 members.
Did you have to buy the door pads?
Caddy
Old 12-15-2012, 06:34 PM   #5
DWALEX
DWALEX's Avatar
yes
Old 12-15-2012, 06:48 PM   #6
Caddyroger
Caddyroger's Avatar
yes
That is to expensive for my blood. They are nice that you have in the door.
Caddy
Old 12-15-2012, 07:12 PM   #7
DWALEX
DWALEX's Avatar
yes I know. I got a set of door panels from a totaled ZL1. I just changed the switch bezel
Old 12-15-2012, 07:33 PM   #8
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
good job let use now what you did.
Old 12-15-2012, 07:51 PM   #9
DWALEX
DWALEX's Avatar
yes I will, I'm gonna make a schematic and load some pictures after holiday
Old 12-15-2012, 08:35 PM   #10
Cmlloveless
Drives: 2010 2SS RS
Man where do you guys find these crashed camaros? I can't ever find newer cars at any of the junk yards around me!
Cmlloveless is offline   Reply With Quote
Old 08-05-2013, 02:26 PM   #11
JAustin
JAustin's Avatar
Drives: (sold) 2011 2LT/RS auto, SW/tan top
I'd have to find a crashed 2012-13 convertible! No way I'd pay dealer price for these door panels.
Just another example of what Chevy should have done in the first place (put the power door lock switches on the armrests). My Jeep Wrangler has power window switches on the center console and power door lock switches on the doors. Whenever I switch vehicles, it takes a few tries to get reoriented!
JAustin is offline   Reply With Quote
Old 08-05-2013, 04:22 PM   #12
DWALEX
DWALEX's Avatar
I bought a pair of used panels just change the switch bezel and sold it again
Old 12-26-2013, 08:24 PM   #13
CamaroLS
CamaroLS's Avatar
Drives: 2014 Blue Ray Met. Camaro 1SS Vert
Thank you
CamaroLS is offline   Reply With Quote
Old 12-27-2013, 06:33 PM   #14
CamaroLS
CamaroLS's Avatar
I bought some door panels months ago for the door inserts and put the door panels back in the box and left them alone till now. I was working on the RS lights today and decided to pull the door panels back out and look what I found. These must have been off of a 2013. So now I can do this mod and wait to do the Mylink upgrade. Yah
