PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
Draining fuel tank
Need to get the fuel out of the tank for a new build, any good way without dropping it?
Can I siphon it out one of the lines under the car through the pump?
Flip it upside down and shake. Lol. I dunno. I would be interested in hearing how its done. How full is it? Dropping it with a quarter tank shouldn't be too bad.
Drives: ls3 camaro Join Date: Oct 2012
i'd like to know
PHAT B33
It's full for storage, that's why I need to drain it. Too heavy for this old man to drop it.
![]() ![]() Drives: 2011 Camaro 1LT IOM Join Date: Jun 2012
Could probably use a might vac pump to get it out.
MRT2.0 with Helmholtz Pipes, Cold Air Inductions CAI, 4-Pack Gauges, Flat Black Stripes, Added Spare Tire Kit, Elite Catch Can, Chrome 20" Wheels, HUD, ABL Doors, GM Dovetail, Matte Black Gills, Rear Fascia Blackout
#6 |
Right Cam
Drives: 2010 LS3 / 79 Z28 Join Date: Jun 2009
Scanner software can run the pump with the engine off.
2010 2SS/RS M6 CGM E-Force + 2015 1LT V6/A6
#7 |
I would say the best way is to remove the fuel pump and then suck it out, but it looks like the fuel tank must be removed. Can you access the filler tube where it meets the tank? I'd disconnect there and start the siphon process.
#8 |
![]() Drives: 2010 CTS SportWagon 3.6 DI Join Date: Jun 2012
Can you just drive it?
#9 |
PHAT B33
Might be an option, I'll have to crawl under and check it out.
#10 |
PHAT B33
Too much crud on the roads. It's a garage queen. lol.
#11 |
PHAT B33
I forgot about that, prob the best option. I have HPT Pro so it should be in there. Thanks!
#12 |
I wouldn't drain it by using the fuel pump, just this risk of sucking up any sediment at the bottom of the tank could damage the pump itself. You never know what's in that tank, even on a vehicle that new.
#13 |
PHAT B33
Holds 19 gal, I'll take out 17 or so, it'll be close enough to empty for my purpose.. I can stop when the Low Fuel light pops on. Pump pickup has a sock on it and with 3k miles total on it running an ethanol blend, it should be pretty clean anyway. Thanks.
#14 |
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3 Join Date: Jun 2010
After removing more gas tanks than I want to recall, even when I was 26, and I could pick up my 455 engine block, a gas tank with a couple gallons in it was very hard to handle
