Old 01-19-2013, 03:36 PM   #1
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
DIY: Fix your broken seat warmer (pics)
If you are like me and many others that have had their drivers side seat warmer go out... I found the problem and fixed it.
Problem: Your drivers side seat warmer stops working. The lights on the button stay illuminated for ~1 minute, and the light goes off without the seats ever getting warm.
Solution: If you are under warranty... you could take it to the dealer... that is, if you don't mind them ripping your seat to shreds replacing your elements...................... that you do not even need.
If you want to fix it yourself, it is not that bad of a job. There is one little wire that has burnt out and had lost connection. It is not in the element....
.... YOU DO NOT NEED TO RIP YOUR LEATHER SEATS APART TO CHANGE THE ELEMENT!!!
Step 1: Take your seat out of the car. This takes me less than 3 minutes.
Seat removal DIY: http://www.camaro5.com/forums/showthread.php?t=100176
Step 2: From the bottom of the seat, locate the heater element leads that go to the seat back (not the bottom... that one is probably fine)
There is ONE pink and ONE blue wire going into a grey connector. (the other connector with pink and blue and 2 more wires goes to the bottom element)
Check the two wires for resistance or continuity. It should be between 1 and 2 ohms or they should show continuity. Mine showed an open circuit. (above)
If it is an open circuit, you will need to dig a little deeper to see the problem. The wire takes a 90 degree turn under the one-zie, and it gets burnt up there for some reason.
.... I dug a little too deep because I didn't know what I was after. That is why my bottom cushion is missing
Step 3: Unsnap bottom seat "one-zie" connector to release the leather. Then unzip 2 zippers on the back of the seat. Fold up the front leather to expose the lower section of the heater element.
Step 4: check the resistance directly on the heater element. It should be 1 to 2 ohms.
So......... you have an open circuit at the connector, but a good circuit at the element.... the wires in between must be bad.
Indeed they are:
You can cut and redo the connection on that one, and you will be done. I added male and female spade terminal connectors so it will be easy if I ever need to go back in there.
Enjoy your butt being warm again...
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 01-19-2013, 03:46 PM   #2
techinny
techinny's Avatar
Drives: '18 Sierra Denali '05 GMC 2500HD
Very nice diagnostic work and write up, saved for future reference.
Had: 2010 SS/RS M6 Hurst STS, Noweeds
techinny is offline   Reply With Quote
Old 01-19-2013, 03:49 PM   #3
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Awesome write up. I need to do this to mine!
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 01-20-2013, 07:17 AM   #4
SRFnSNO
SRFnSNO's Avatar
Drives: Blown & Flamed
Thanks for the write up need to look at this on mine also.
SRFnSNO is offline   Reply With Quote
Old 01-20-2013, 08:34 AM   #5
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
How does the harness come loose? I got the bolts out no problem, not like a lot of members have said. I just used a torx and a 8", 3/8" drive ratchet. I have a sprained shoulder and still did it without a lot of pain. A little hard to break loose but maybe 50 lbs force.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 01-20-2013, 11:36 AM   #6
CWI
CWI's Avatar
I finally got it out. I have continuity to the bottom of the seat. Found the problem after I remove the entire bottom cushion. It's in the back cushion damn it. Live and learn. I've done more work on this car than I did on any in the 70's and that was a lot.
Anyway, the pink wire was broken a little more than an inch from the heat element. Hope I don't have to do this again. It's like the rear deck, a bitch the first time and easy after that. Should be good to go once make the splice and put it all back together.
Your writeups definately helped, thanks.
Old 01-20-2013, 01:37 PM   #7
Bell040
Bell040's Avatar
I guess taking the seat out was easy for me.... since I have had the seats out of the car several times now. I took it out once for extra cargo space, another time to clean under it, and even once to race it (it weighs ~50 lb).
From reading everyone's problems with it, it's always the back cushion on the driver side...and it is always just an inch or 2 from the element.
Ordered: 10-13-08
Recieved: 6-12-09
Old 01-20-2013, 02:12 PM   #8
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Thank you for a grate DIY, nice to see members adding info they learn on the GEN5 diy.
Old 01-21-2013, 10:33 AM   #9
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
been saying this for a long time,if the issue was a short gm would recall it but since the wire breaks no recall,also the side air bag harness in the same seat has a similar issue
firestone_ss is offline   Reply With Quote
Old 01-23-2013, 02:20 AM   #10
CWI
CWI's Avatar
The problem with mine does appear to be a design issue. It broke at the same place as the OP. It looks to me like the wire gets pressed against part of the seat frame and over time gets cut through.
I had continuity through the pad and fixed the wire. Stuffed everything back together and tested again before reinstalling the seat and shi*, no continuity. Guess now I need a new heat pad.:(
Old 03-22-2013, 12:27 PM   #11
Agent WD-40
Agent WD-40's Avatar
Can anybody tell me what gauge this pink wire is? It would be nice to have wire in hand before pulling the seat out. This happened to mine and I want to replace the section of wire.
Has anybody re-engineered anything in fixing this to prevent it from happening again (like adding some extra support around the wire)?
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete
Roto-Fab Intake
Stainless Works 1 7/8" Long Tube Headers
Corsa Exhaust
Agent WD-40 is offline   Reply With Quote
Old 03-22-2013, 03:24 PM   #12
Bell040
Bell040's Avatar
You can see the wire by just looking under your seat and finding the plug (there is a black cover over the pink and blue wires)... without taking the seat out.
I just ran the wire out of the seat differently... so it should not fail there again.
Ordered: 10-13-08
Recieved: 6-12-09
Old 03-24-2013, 02:08 PM   #13
Agent WD-40
Thanks! I was able to find it. It looked like it was about 16 gauge. I ordered some flexible silicone jacket wire to replace the damaged factory wire.
Where did you end up running the wire? I'm assuming not around the corner of the seat like the factory did. I've not taken the seat apart yet so perhaps it will be self evident when I do.
Did you add any extra protection to the wire bundle (like split loom)?
L99 - 440 RWHP
Roto-Fab Intake
Corsa Exhaust
Old 03-29-2013, 06:42 PM   #14
Silver2SSRS6spd
Prefer to be blown!
Silver2SSRS6spd's Avatar
Drives: 2010 Silver/Black 2SS/RS Manual
I have a question about removing the seat, I loosened the two screws and they are spinning freely, yet they will not come out. It seems like I may have broken off the welded nut that is probably underneath the rails. Anyone have any ideas?
MagnaCharger TVS-2300 550rwhp 540 rwt and a radical suspension under the car.
Silver2SSRS6spd is offline   Reply With Quote
