Old 02-06-2013, 09:07 PM   #1
audiomikej
audiomikej's Avatar
Drives: the wife crazy talking Camaros
Parts list to install a ZL1 LSA supercharger on an LS3/L99 Camaro
**********Under construction*************************
Idiot’s guide to purchasing and installing a ZL1 LSA supercharger to your SS Camaro.
Chapter 1. Material list
Chapter 2. Installation tips and wiring guide
Chapter 3. Tuning and post installation experiences.
I have done a bunch of research and sourced some great vendors to buy from.
partstaxi.com
http://www.gmpartscenter.net
http://www.parts4chevys.com
gmpartsonline.net
GMpartsSHOP.com
http://www.paceperformance.com
lingenfelter.com
phastek.com
They are all great vendors but they do not give GM part numbers until after purchase. This prevents you from easily price shopping the various vendors. A great resource to find said part numbers
http://www.tonkinonlineparts.com
Here is a list of some of the parts needed
Supercharger with bypass 19257754 $1627.28
ZL1 Supercharger lid 12622236 $257.01
cooler insulator 12612467 $12.72
Fuel Rail 12605222 $236.10
LSA/LS9 Fuel Injectors 12598646 $396.16 new, found used for $225
EVAP solenoid 12639188 $22.48
intake manifold bolts (10) 11588718 $0.50
ZL1 Engine beauty cover 12639443 $56.04
Engine beauty cover studs (4) 11588406 $2.83
Crank Pulley (aka balancer) 12603916 $134.58 new, found used $50
Crank pulley bolt 11570046 $3.54
Crankshaft friction washer 12603843 $10.95 Lingenfelter (not sure if needed)
Front accessory drive kit 19243525 $889.95 paceperformance
AC compressor 22798907 $353.66 (list)
AC compressor mount 12622243 $65.18 (list)
AC Belt 12622244 $21.05 (list)
LSA/corvette LS3 Water Pump 19180610 (found on ebay $115)
Water pump gasket 12630223 $4.33
Supercharger intercooler radiator 22879421 $121.74
*LSA intercooler pump 20945282 $237.66
*Front Hose kit 22962566 $70.43
*I do not recommend OEM unit, it is a nice piece but it is expensive and a little tricky to wire/install. Aftermarket pumps are much cheaper.
ZL1 fuel pump ~$250 phastek.com
ZL1 Cold air intake $450
Custom tune
L99 add
Front timing cover kit L200010106 $140 Lingenfelter
Timing chain SD3SR602 ~$50
+more
Valley plate and gasket? 12599296, 12610141
I have a spreadsheet with more notes and part numbers will finish populating this post later.
All said and done budget $6000 for an LS3 and $8000 for a L99 ZL1 supercharger add. For a L99 I also recommend upgrading to a LS9 cam at the same time as you add the supercharger along with the required fuel pump upgrade and cold air intake.
audiomikej is offline   Reply With Quote
Old 02-06-2013, 09:08 PM   #2
audiomikej
audiomikej's Avatar
Old 02-06-2013, 09:08 PM   #3
audiomikej
audiomikej's Avatar
Old 02-07-2013, 07:42 PM   #4
mbrusco103
mbrusco103's Avatar
Drives: 2011 2SS/RS (M6) 427 Twin Turbo
2011 Camaro 2SS/RS ERL 427 M6 TT
-AGP Twin Turbo 55/57 .83ar | ERL 427ci | Squash Fuel System | Stainless Works Chambered 3" | Mcleod RXT | Factory Hurst Short Throw | Black Forgestar F14s | CTS V 6 Piston Brembo | VIS AMS Carbon Fiber Hood | Anvil Carbon Fiber Spoiler
mbrusco103 is offline   Reply With Quote
Old 02-26-2013, 11:24 PM   #5
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
damn...i'm curious. subscribed!
Old 02-27-2013, 11:12 PM   #6
nikos30
HT5 EastSide
nikos30's Avatar
Drives: 2010 Camaro 2LT
I will read every word. I love learning. thanks a lot man
nikos30 is offline   Reply With Quote
Old 02-27-2013, 11:16 PM   #7
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Good Stuff...
mlee is online now   Reply With Quote
Old 02-28-2013, 04:46 PM   #8
Juice2SS
Drives: 2011 2SS
I put that same list together all new on GMPartsDirect for $4800.
Juice2SS is offline   Reply With Quote
Old 02-28-2013, 09:03 PM   #9
audiomikej
audiomikej's Avatar
Be careful with GMpartsdirect.com, they have no phone number and they rape you on S&H. I recommend the vendors listed above over GMPD.
Old 02-28-2013, 10:07 PM   #10
knitetrain05
Drives: 2012 Camaro SS 45th Anniversary Edi
partstaxi.com
gmpartsonline.net
GMpartsSHOP.com
lingenfelter.com
phastek.com
Custom tune
L99 add
+more
Thats silly. Just buy a ZL1 and save the monkey shine.
knitetrain05 is offline   Reply With Quote
Old 03-01-2013, 01:09 AM   #11
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
For the same $$ or a bit more couldn't a Maggie be self installed and easier? And add more power?
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 03-01-2013, 01:19 AM   #12
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
CHMSC is offline   Reply With Quote
Old 03-01-2013, 05:47 AM   #13
Silver-SS
Drives: 2012 2SS RS
Subscribed
Silver-SS is offline   Reply With Quote
Old 03-06-2013, 11:30 PM   #14
Juice2SS
Drives: 2011 2SS
I talked to my local Chevy dealer and they said they'd match most of those prices. I might just have to do this.
tvs1900, zl1 lsa supercharger
