Old 03-08-2013, 02:38 PM   #1
CamaroC-17
Formerly Camaroc5
CamaroC-17's Avatar
Drives: 2010 Camaro LT/RS M6
update for you guys
I have my car back from the dealer. All new chains, tensioners, and seals for front end. All under warranty. They said my oil consumption issue was likely due to the chains loosening up. Only have a couple hundred on it and have not lost any oil yet.*Could be wrong though. I am not convinced that my oil loss was caused by the chains though. Guess time will tell
CamaroC-17 is offline   Reply With Quote
Old 03-08-2013, 02:46 PM   #2
CamaroC-17
Formerly Camaroc5
CamaroC-17's Avatar
Oh and if the oil loss problem was from the chains I think that should send a warning out to all owners
Old 03-08-2013, 10:29 PM   #3
OOLIE
OOLIE's Avatar
Drives: 2011 LS
Interesting. Was it chains or the result of chains causing other thing to go.
OOLIE is offline   Reply With Quote
Old 03-09-2013, 04:31 PM   #4
CamaroC-17
Formerly Camaroc5
CamaroC-17's Avatar
Well the chains are not it. Have driven about 350 miles and the level is dropping. Not sure where they filled it to but it is at the lower portion just above the cross hatches. Back to the dealer I suppose.
Old 03-10-2013, 09:29 AM   #5
CamaroV6
Drives: Camaro V6 1LT Manual
Wish you all the best!! hope they fix it right this time.
CamaroV6 is offline   Reply With Quote
Old 03-10-2013, 09:59 AM   #6
Toms2010
Drives: 2010 2LT
At what point are you covered by the lemon law? Would think that if they cannot fix it and you have to keep taking it in. you should be given something that will work correctly.
Toms2010 is offline   Reply With Quote
Old 03-10-2013, 10:08 AM   #7
TooCool5
TooCool5's Avatar
This is crazy, you need GM involved.
New short block maybe?
Old 03-11-2013, 02:16 PM   #8
formare
The Milano
formare's Avatar
Drives: 2017 Firefly ShipWorks
Per the GM service bulletin - 1qrt every 500 miles is within design specification.
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 03-11-2013, 02:20 PM   #9
AKA-22
AKA-22's Avatar
Drives: ELLE-1
yeah
AKA-22 is offline   Reply With Quote
Old 03-12-2013, 10:40 AM   #10
TooCool5
TooCool5's Avatar
I don't use a qt in 4,000 miles, maybe half.
Old 03-12-2013, 03:38 PM   #11
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
My last two oil changes were right on. Have no idea why
chevy 3 is offline   Reply With Quote
Old 03-12-2013, 04:04 PM   #12
RubyCamaro
Jan
RubyCamaro's Avatar
I guess I am just lucky. Ruby has never been one bit low on oil between oil changes............ever. I sure hope it stays that way.
Old 03-14-2013, 12:30 PM   #13
SNV
SNV's Avatar
Drives: 2014 RRM 2ls
As some of you know I have my timing chain done last month. I only have put around 650 miles on it since then. Just went to check oil level after reading this. My oil is stop on full. Doesn't look to be even a drop low.
SNV is offline   Reply With Quote
