04-04-2013, 08:57 AM | #1 |
Drives: 2012 SLP ZL770 #17 (Hugger Orange) Join Date: Aug 2011
FS: 2012 ZL770 - One of a Kind Hugger Orange
**SOLD**
For those of you that aren't familiar with this car, please visit Chapter II of my build thread. http://www.camaro5.com/forums/showth...=214185&page=9 I have listed below the carefully picked modifications that make this car a complete one of a kind solid car for both the track and for show. Not only is it one of only two ZL770s made, it is completely redone in Hugger Orange with painted stripes, all done at a top shop, and all done the right way. Yes, I know that I cannot sell this at what the car is valued at, but I'm hoping that I an give the chance to sell this to someone at an incredible deal. PM for Pricing. If you look at all of the mods this car is easily around 115K in mods. I believe that the price is more than fair. I also know that many can start saying, why spend this much on a car when there is the ZL1 and the upcoming Z28. I think those that have followed this build understand that there is so much built into every component of this car that more than justify the price. The car only had approx 3700 miles on it pre-build (currently about 4600), and with all the new components its practically new. Mods Below: Exterior Mods Custom Hugger Orange Color Change in PPG Paint SLP ZL Rally Stripes in Gloss Black buried in Clear SLP ZL Hockey Stripes in Gloss Black buried in Clear SLP ZL Wing with Painted Stripes in Gloss Black buried in Clear Trunk lid with painted stripes and painted blackout buried in Clear Heritage Grille Painted Hugger Orange with Heritage SS Emblem SLP Exhaust Diffuser with painted exhaust bezels in Gloss Black Taillights painted to 30% Tint SLP Rear Quarter Panel Faded Gill Insert s SLP front license plate removable bracket ZL 770 Badging Hood Cowl 770HP Supercharged buried in clear ZL1 Front Fascia with custom paint on bottom lip ZL1 rear splashguards ZL1 Side Skirts ZL Wheel Center Caps custom painted with ZL in Hugger Orange and Gloss Black SLP RTM Hood with Functional Heat Extractor Scoop Oracle Ghosted SMD side marker lights in Gloss Black Oracle Tinted LED Reverse Lights Interior Mods SS kick plate guard RPM custom 6 point Rollbar with removable cross and shoulder bar painted Hugger Orange Custom Tank Plates 770HP Embroidered Floor mats custom cut for roll bar points ZL1 Pedals SLP ZL Supercharged Specialty Vehicle Sequentially Numbered Dash Plaque #17 SLP ZL Supercharged Specialty Vehicle Sequentially Numbered Key Fobs #17 SLP Leather Bound Portfolio, Supplemental Owners Manual, Birth Certificate, Certificate of Origin Custom ZL770 Lighting Door Sills (EmblemPros) Under the Hood Appearance Mods *All under the hood appearance mods will be painted hugger orange to match exterior. Premium Fuse box Cover (Showstoppers) Premium ABS Cover (Showstoppers) Premium Master Cylinder Cover (Showstoppers) Power Steering Cap (Billet Custom) SS Radiator Cap (Billet Custom) Battery Cap Cover (Billet Custom) Dipstick Cover (Billet Custom) Oil Cap Cover (Billet Custom) SLP Supercharged Engine Covers Performance Mods SLP Built LS7 Aluminum Long Block 427-CID displacement 4.000 SLP/Manley 4340 forged steel crankshaft, balanced to rotating assembly 4.125" SLP/Manley 2618 forged alloy pistons 6.125" SLP/Manley 4340 forged steel H-beam rods SLP TVS2300 Supercharger (w/custom pulley set to produce 10 psi of boost) SLP 51018 Camshaft .654/.658-inch lift 214/230 duration @ 0.50 120° LSA SLP/LS3 Cylinder Heads SLP 1.85 Rockers SLP Double Row Timing Chain Set SLP Boost-A-Pump SLP 85 lbs/hr Injectors SLP 160° Thermostat SLP 55001 Heavy-Duty Oil Pump New GM Lifters and Lifter Guides Hardened Pushrods ARP Cylinder head studs MLS Head Gaskets 10.82:1 compression ratio (nominal) 58 Tooth reluctor wheel Canton 3 Qt Accusump ZR1 Plugs ZR1 Map Sensor JRE Super Tensioner CAI Intake SLP LT Headers Magnaflow Highflow Cats SLP LMII Exhaust SLP Skip Shift Eliminator Moroso Catch Can Be Cool Aluminum Radiator 10 Rib Rear Cog Custom Dyno Tune (iTSX) Drivetrain Mods MGW Short throw shifter assembly with Retro Ball Shifter DSS Level 4 Half Shafts 1000HP DynoTech Driveshaft JRE rebuilt rear diff (Detroit Eaton TruTrac Differential, GM 1LE 3.91 Gears, Posi Mod) ZR1 Clutch Suspension/Chassis Mods Eibach Coil Over Spring/ Shock Package SLP Adjustable Front and Rear Sway Bar Package Hotchkis 4 point strut brace BMR Safety Loop BMR Rear Control Arms BMR Rear Toe Rods BMR Tunnel Brace BMR Subframe Brace BMR Full Pro Bushing Set Brake Mods Brembo GT Front Brake Package, 6-piston front caliper, Two-Piece 15" Drilled Rotors Brembo GT Rear Two-Piece Drilled Rotors and 4 Piston Calipers Granetelli Stainless Steel Brake Lines ATE Super Blue DOT4 Last edited by Tribute; 02-07-2014 at 01:50 PM. |
04-04-2013, 09:12 AM | #2 |
ZLT!!! COTW (8/5/13)
Drives: 2011 IOM 1LT RS M6 Join Date: Mar 2012
Somebody is going to be so happy with this purchase!!!
04-04-2013, 11:30 AM | #3 |
Drives: 2013 Camaro 2SS RS LS3 Join Date: Feb 2011
That car is pure sex! Good luck with sale!
-2013 Summit White over Inferno Orange 2SS RS- -2014 White Diamond Silverado Z71 Crew Cab Short Box- |
04-04-2013, 07:45 PM | #4 |
Drives: '13 Roush S3 '16 Ram Sport 4X4 Join Date: Apr 2009
Great car. I bet that car put a lot of smiles on your face.
For those of you that have never seen the true Hugger Orange color, it is gorgeous. Especially out in the sun. My Camaro was Hugger Orange and would turn heads everywhere. GLWS |
04-05-2013, 02:20 PM | #5 |
Drives: 2010 IBM 1SS (Former) Join Date: Feb 2009
Nice build. For some reason, the wheels look computer-generated to me. Might want to make it clearer to potential buyers whether the car comes with aftermarket wheels. Good luck with the sale.
04-05-2013, 11:06 PM | #6 |
Sick car i have the little brother V6 The ZL327
04-06-2013, 09:46 AM | #7 |
America FVCK Yeah!
Drives: 2021 ZL1 1LE A10 Join Date: Mar 2013
Wow. What a well thought out build. I'd seriously consider trading my ZL1 for this.
04-10-2013, 03:29 PM | #8 | |||
-- I appreciate everyone's concern. I know this came as a big surprise. Basically in short, times were good and then times got tough. I'm a small business owner that deals with the govt, this sequester hit us pretty hard. This amongst other things made me re-adjust priorities. Main priority being family. I need to make sure I properly align things to take care of what matters most. This car was a fun build and very carefully pieced together. Someone will absolutely get an amazing deal for this, even at asking price it's a huge deal about a 40-50K worth of mods for free. Anywho, there will always be a time for cars, but for now, I've got to make the right choices and prioritize properly. I really appreciate the kind support and reach out, sorry about the delay in response, been pretty busy trying to keep things together. The best that anyone can help is try and put out a good word for the car. It would be great to line up a buyer here soon. Thanks! |
04-11-2013, 09:32 PM | #9 |
Drives: '11 Camaro 2SS/RS LS3 Join Date: Jan 2012
Sucks to see you selling it :(
I remember following your build thread. Beautiful car and a lucky person to whomever gets it. |
04-12-2013, 09:22 AM | #10 |
Thanks for the kind words Frid. Indeed someone will be lucky here.
04-27-2013, 12:09 PM | #11 |
Drives: 10 SLP ZL575 644 RWHP Join Date: Apr 2013
sent PM
04-27-2013, 02:10 PM | #12 |
PM returned
04-28-2013, 12:26 PM | #13 |
Black Santa
Drives: 2012 2SS/RS Join Date: Apr 2012
Wow homey! I didn't even know you had your ride for sale. I just came across it perusing the forum. Let's talk this week!
04-28-2013, 12:59 PM | #14 |
Sounds good. Talk to you soon.
