Fuse Pull
All I here is fuse pull, fuse pull, fuse pull for bettert performace. By doing this what exactly does it do?
Anabolic Connoisseur
Drives: Sold - Blown Camaro 2SS/RS LS3 Join Date: Sep 2010
#3 | |
Voice Of The Voiceless
#4 | |
The problem: If someone puts a low octane fuel into the tank, the vehicle can’t recover from the low octane table. Once in the low octane table the car will continue to use that information even if you are now using a higher octane fuel. Of course the side effect of this is sluggish performance, and we don’t really need to explain the benefits of running a higher octane fuel in a performance application. If you just purchased your Camaro you wouldn’t be incorrect in thinking that it isn’t uncommon that at some point the car was filled with a less potent gasoline, especially if it came from a used car dealership or from an owner who was uninformed of this problem and wanted to save a few bucks at the pump. The LTFT’s are, unfortunately, a part of the car’s non-volatile memory. That means the information is stored there, and doesn’t reset when the vehicle is turned off. However, there is a way around this problem. Although the spark tables are part of the non-volatile memory and cannot be removed, they can be reset. A simple solution is to remove a couple of fuses from the fuse block in the engine compartment. Pulling the fuses will allow your Camaro’s ECM to reset itself to the high octane table. If you are running high octane fuel then it remain in the high table until the ECM again detects a low octane fuel. The process is quite simple: First, make sure the car is empty of the low octane fuel. Run the tank down low and refuel with high octane. You might consider running a tank or two through before attempting the fuse pull. Once you have better gasoline in the system, locate the two fuses shown in the diagram below. They are in the fuse box located on the passenger side of the vehicle’s engine bay. The fuses are in position #5 and #20. Remove each of these 15 amp fuses and allow the car to sit for a period of at least a few hours. There is a small, grey fuse pulling tool located on the fuse panel (In the diagram below it would be in the lower right corner area). That should make the pulling of the fuses easier. If possible, remove the fuses and allow the car to sit overnight. Once they have been out for several hours, replace the fuses. When started, the car will attempt to use the high octane fuel trims first, and if you keep high octane fuel in the car it should remain on the higher table permanently. Of course, lowered octane fuel in the tank means repeating the process.
Thank You Gentlemen.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
Excellent, Chase...
You should put that up in the fuse pull thread as well....That thread has gone all over the place, it could use a "re-set" too...lol... |
#7 |
![]() Drives: 2013 1ss Join Date: Jul 2012
Is there any information related to if the system will eventually reset itself with consistent high octane? Most sensors map to current conditions and I find it tough to believe they would not have the octane sensor map to current also.
#8 |
Yeah, there's information...It won't happen...That's why there's a fuse pull procedure....(Read post #4)...
#9 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: COTW 8/29/11 2010 CAMARO Join Date: Jul 2009
or you can get a tune and never have to worry about it ![]() ![]()
#10 |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
Interesting. Did not know that.
#12 |
![]() Drives: 07 C6 LS2 Join Date: Aug 2012
Hand held tuning device.....there you go. More power and no fuse pull needed.
2011-Black LS3 2SS/RS-SOLD
2007-Victory Red C6-Magnacharged (M112 Intercooled), B/B Bullets, Lingenfelter Hood/Tune/Valve Covers, AR Catted Long Tubes, K/N Drop Ins, much more |
#13 |
Wind Rider
Drives: ZL1 19 White; Jeep 5.7 GC 15 Join Date: Jan 2010
Is it an issue with 2010-2012 V8 models only ??
Im not Gray any more !!
#14 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 RJT 2SS M6 Camaro Join Date: Feb 2011
The other thing you're to hear is: search, search, search,
2010 RJT 2SS M6, Kooks Long Tubes, NPP Exhaust, CAI Cold Air w/Jannetty Scoop, RotoFab Washer Bottle, Elite Engineering Catch Can, MGW Shifter w/ZL1 Shaft and Knob, 2015 SS Sedan Steering Wheel and Air Bag, 2012 Heater Hose Conversion, 2012 Power Seat Conversion, RS Head Lights,Gen5DIY RS Conversion Harness, LED Fog Lamp Bulbs, Backup Camera Kit, NLP Spoiler, SLP Splitter, ZL1 Rockers and Diffuser, Color Matched Shark Fin, RS Roof Mouldings, Painted White Stripes, WCC LS3 Emblems, Heritage Grille and Blacked Out Tail Light Panel w/Retro SS Emblems, 416 RWHP, 411 RWT, Tuned by BlueCat.
