05-07-2013, 10:19 AM | #1 |
Drives: 2010 2SS Join Date: Jan 2013
Gorilla locks without key emegency removal.. the easy way
I bought my car with gorilla locks on my car.. but it didn't come with a key, and i have no idea how to find the serial number to get a replacement.
I thought i was screwed. However, had a friend lend me a 19mm/21mm thin walled flip socket as pictured below: I used: the 19mm side of the said flipsocket a long breaker bar silverback gorrilla strength generic 2 ton floor jack and used a rubber mallet, tapping the socket gently into place and they came right off. FU gorilla locks, hello OEM!
05-07-2013, 05:46 PM | #2 |
KNGTFALL
Drives: 2012 2SS 45th edition Join Date: Aug 2012
That's Great....
Now plenty of thieves can now google removing gorilla locks without a key, and they can read your post. Most can figure stuff like that out, but now even the stupid criminal was given some help. Thanks |
05-07-2013, 07:45 PM | #3 |
Drives: 2SS/RS Join Date: Sep 2008
Which is why you get the ones that are free floating. Also most thieves won't mess with a car with 20 wheel locks on them as it takes too much time to remove all of them this way.
05-07-2013, 07:52 PM | #4 |
KNGTFALL
But some things should be Tabu on forums. especially a DIY on removing wheel locks without a key. Next we will have DIYs on opening your door without a key, stealing air bags, and hot wiring.
Just sayin' |
05-07-2013, 07:55 PM | #5 | |
one car wolfpack
Drives: 2010 Camaro V6 Join Date: Nov 2010
Wheel locks don't change the fact that some guy could shoot you and hijack your car. When the thief sees you have wheel locks on your car, he would just key your car and walk away. Kind of like locking valve stem caps, the thief will try to pull it off until the valve stem brakes and then your tire is deflated. Also most thiefs have special keys that fit any lock, look on amazon. |
05-07-2013, 09:01 PM | #6 |
Everyone has a point. Can we just get a Mod to delete this thread and be done with it?
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
05-08-2013, 01:09 AM | #7 | |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
05-08-2013, 02:57 AM | #8 |
Team LFX
Drives: Fast Join Date: Mar 2012
05-08-2013, 10:30 AM | #9 |
Ok well what if you weren't a thief?
Like me. Yup
05-08-2013, 10:41 AM | #10 |
At first it was either:
"WITHOUT the card giving the serial number of the lock we nor Gorilla can supply you the correct lock. That serial number is how to find which lock it is and we don`t have that information only Gorilla does. Gorilla`s phone number is 800.262.6267 If you do not have the serial number, then you`ll have to cut them off by chisel, or hammer on a socket to back off, or freeze them with nitrogen and shatter them." (source: http://www.sfxperformance.com/articles/465) or craftsman lug-out
05-08-2013, 11:56 AM | #11 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
To me it's just been cheaper to keep oem.
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
05-08-2013, 12:45 PM | #12 | |
Drives: 2013 Chevy Camaro 2LT 3.6 V6 Join Date: Apr 2013
05-08-2013, 01:29 PM | #13 |
more convenient too
05-08-2013, 02:54 PM | #14 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
Then again, some low lifes just need a reason to move on.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
