Drives: Twin turbo camaro Join Date: Apr 2013
twin turbo gen 5
just added twin turbos to my car i went from 425hp to 780rwhp
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
What else did you change?
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
+1
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
The image is blocked where I work. Is this a kit?
#6 |
Yes it is the kit that Granatelli makes
#7 |
#8 |
Banned
Drives: 10' 2SS LS3 M6 Join Date: May 2012
LOL^^^ some real solid detail that im sure will interest people...
#9 |
Yeah, since he got banned we haven't heard much about his kit. Details would be nice.
#10 |
forged steel connecting rods
forged Manley pistons All new bearings ARP bolts everywhere ARP head studs as well ZL1 fuel pump and a boost a pump for good messure Hear is what came from the Granatelli kit 2 x PTE6265 ball bearing Turbochargers with 4” Inlet Compressor ducting – Each capable of 65 lbs/min Turbos are V band mounted on inlet and outlet to insure easy rotation, solid mounting and best of all, there are no nuts and bolts entering or exit turbo body 2 x PTE 46mm Waste Gates that Insure Maximum Control Over the Monster Turbos. My waste gate springs are set for 10psi HPC coated exhaust side and red wrinkle painted all the cool side stuff 1 x 50mm Tial Blow Off Valve Largest Front Mount BELL CORE Intercooler with 3.5” inlets from turbos and a single 4” discharge pipe feeds direct to the throttle body. I had them leave the front Intercooler Tanks Black so it blends into the nose. Also they say that black helps extract heat Manual boost controller Thermal Heat shielding for all effected lines 4” Aluminum Intake Tubing w/K&N Filters and K&N “Hydro Shields” for extended dust/dirt/water protection They claim to be the only TT kit that does not hang below the frame rail, ensure plenty of ground clearance - that was a HUGE plus because my car is lowered Granatelli Custom Windshield Washer Bottle Polished Oil Cap w/oil return Last edited by evilcamaro; 05-08-2013 at 04:59 PM. |
#11 |
When I first had this kit installed it was on the stock engine and made just at 600 rwhp. I did that for 4 months then decided to go for it
#12 |
So no boostapump for FCM upgrade? What about injectors.
#13 |
Yes i have both boostapump and ZR1 with 60 lb/hr injectors
#14 |
![]() ![]() ![]() ![]() Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
Why did he get banned?
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
