Old 05-16-2013, 11:15 PM   #1
a.morblu
a.morblu's Avatar
Drives: 2011 Sinister SS
Identify This Leak
I was under the Camaro this evening working on the exhaust and found this guy leaking. It looks like it's coming out of the oil pan and runs back towards the transmission. Anyone recognize it? Thanks in advance.
a.morblu is offline   Reply With Quote
Old 05-16-2013, 11:50 PM   #2
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Mods:
Old 05-16-2013, 11:59 PM   #3
Avenging Orange
Avenging Orange's Avatar
Coolant leak for the oil cooler. Take it in and have it repaired...there is a TSB for this.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 05-17-2013, 08:58 AM   #4
a.morblu
a.morblu's Avatar
Thank's. I'm cammed and tuned so out the window goes all warrenty work. I guess I'll take this opportunity to upgrade. Anyone have any suggestions?
Old 05-17-2013, 11:09 AM   #5
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I would still ask a dealer about it. Tuning and camming have little to do with a leak from the side of the block. The worst they can say is "no". If you haven't been told "no" ask first. Your other alternative is to fix it yourself or block it off.
Old 05-17-2013, 11:42 AM   #6
The Stig
knows 2 facts about ducks
The Stig's Avatar
This. While you are cammed and tuned - neither would have any real "direct" impact on that seal not being good. Besides - worst they can say is no right?
Click to view my build thread
Old 05-17-2013, 12:12 PM   #7
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Maybe a bit worse than that, if they say no and charge you a half hour shop time for diagnosis.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 05-17-2013, 04:00 PM   #8
a.morblu
a.morblu's Avatar
I'll def ask. You're right. All they can say is no. Either way it needs fixed before it becomes a bigger issue.
Old 05-18-2013, 12:35 AM   #9
Avenging Orange
I have headers and a tune........dealer said nothing. Its a TSB not a warranty issue, should be no problem. They will more than likely have to unbolt the drivers side header to get better access. Its a cross threaded nipple that occurred on some vehicles during assembly.....after time it develops a small coolant leak. There are lots of threads on this issue....check em out.
Old 05-18-2013, 11:56 AM   #10
FLYNNZL1
Drives: Man
Send a message via ICQ to FLYNNZL1 Send a message via AIM to FLYNNZL1 Send a message via MSN to FLYNNZL1 Send a message via Yahoo to FLYNNZL1 Send a message via Skype™ to FLYNNZL1
I had the same leak, there is a TSB. It is caused by a cross threaded connector. May sure to stress the leak is caused by poor workmanship. My dealer tried to tell me connectors are not covered on my extended warranty. They have to retread the hole to fix it properly.
FLYNNZL1 is offline   Reply With Quote
Old 05-18-2013, 12:44 PM   #11
Chevrolet Customer Svc
Drives: GM Vehicles
Wow! Sincere apologies about the leak. Please send me a message with your VIN so I can research this matter further. I look forward to hearing from you.
William R.
Chevrolet Customer Care
Old 05-21-2013, 11:13 AM   #12
JOHNSON SPEED SHOP
Drives: 2010 Camaro 2 SS/RS
This is not a complicated repair. The connector will need to be replaced because it is made from soft aluminum. The threads in the block are cleaned up and a new connector is installed with pipe sealant.
JOHNSON SPEED SHOP is offline   Reply With Quote
