Old 05-28-2013, 07:05 PM   #1
Phdpsy
Phdpsy's Avatar
Drives: SW 2013 1LE
Tricks to see oil level on dipstick after fresh change?
I know my eyes aren't what they used to be....but really? Just did the first change on my 2013 1LE and cannot see the oil level on the dipstick accurately for anything. Drained, changed filter, sealed her up, added just under 8qt mobile 1, idled her for a minute, let it settle....then...crap, can't tell. Wiped clean and did it a few times and still can't tell. I've tried in different lights, angled it, and I'm baffled. Definitely oil on the stick, but level is anyone's guess. Any tricks out there?
I'd likely not worry excessively.....no I would anyway...but I'm heading to a driving event at Circuit if the Americas next weekend and will be pushing the car hard. Just concerned it my somehow be overfilled.
Phdpsy is offline   Reply With Quote
Old 05-28-2013, 07:39 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
x2...great question!
Glen e is offline   Reply With Quote
Old 05-28-2013, 09:16 PM   #3
mulletman
Drives: 2017 Camaro SS
Wipe the dipstick completely dry. Inspect the dipstick in bright sunlight and angle the dipstick until the top of the oil level shows. I have heard of spraying white primer on the bottom of the dipstick but have not tried it.
mulletman is offline   Reply With Quote
Old 05-28-2013, 09:59 PM   #4
Moto44
Moto44's Avatar
Drives: 2011 Synergy Green Camaro SS
I find this frustrating, too. I fold a dry paper towel around it, unfold it, and check to see how high the oil mark rides up on the dipstick.
6-speed manual and a Magnaflow exhaust
Moto44 is offline   Reply With Quote
Old 05-28-2013, 11:28 PM   #5
Avenging Orange
Avenging Orange's Avatar
Never had an issue seeing the damp part of the dipstick in contrast with the dry. And I have cataracts!
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 05-29-2013, 12:04 AM   #6
mulletman
Sixty-three per cent of Chinese doctors have cataracts. The rest drive Rincolns.
Old 05-29-2013, 03:22 AM   #7
Phdpsy
Phdpsy's Avatar
Drives: SW 2013 1LE
Old 05-29-2013, 03:28 AM   #8
Phdpsy
Phdpsy's Avatar
Drives: SW 2013 1LE
Might have to try something like this. There just does not appear to be a clear transition line from wet to "dry". It seems like there is still oil around the sides and part of the face above the full mark, but not completely across the flat surface. It is like a slow tapering off vs. a more defined "line" as an ending point.
I miss my dirty oil that showed up so well when checking the level
Old 05-29-2013, 06:48 AM   #9
CatiaJockey
CatiaJockey's Avatar
Drives: 2010 2LT RS
Wipe the stick dry and dust it with baby powder, reinsert and the level will be clear.
Old 05-29-2013, 10:44 AM   #10
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
I'd say to dust the dipstick after pulling it out. Might work and won't put baby powder in the crankcase.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 05-29-2013, 11:28 AM   #11
Ehmsea
Ehmsea's Avatar
Drives: 2013 2SS RS Hurst NPP
I use the paper towel trick as mentioned above. I don't wipe the dipstick clean, I press it between the folded paper towel.
Why didn't they just make the damn thing white???
No Worries
CAI Intake w/washer relocation and race scoop
Ported Throttle Body (Polished)
Kooks LT stepped headers 1-3/4 to 1-7/8
High Flow Cats
Livernois Motorsports Stage 2c Cam Package
https://www.youtube.com/watch?v=AKXyCyBh9BU
Hill Start Assist Delete
Ehmsea is offline   Reply With Quote
Old 05-29-2013, 11:39 AM   #12
bw26ss
Banned
Drives: ss camaro
pour in the correct amount of oil and your done
bw26ss is offline   Reply With Quote
Old 05-29-2013, 01:00 PM   #13
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
I guess I usually find that one side of the dip stick usually has more oil collected on it I think due to the way that it's oriented in the dip stick tube. So I usually check both sides of the dip stick looking for the reading on the side that has the least amout of oil on it. I can usually pick out a nice line on the dip stick that shows where the level was. Also sometimes you can use the 3 holes the put in the end of it and look for the hole that last has oil on it.
Otherwise the papertowel trick seems like a nice idea. I don't think I would put anything like powerder on my dip stick and then stick it back down the tube. Sounds like a problem waiting to happen to me.
Nick S is offline   Reply With Quote
Old 05-29-2013, 06:41 PM   #14
Phdpsy
Phdpsy's Avatar
Drives: SW 2013 1LE
PERFECT solution, and so simple!
Got out the powder, pulled out the dipstick and wiped it off lightly. Powdered both sides and tapped it on the edge of a trash can to get off the excess (just left the finest film on it). I wiped the powder off from the middle of the hashed section down to the tip, and from 1/2" above the full mark up. This left about 1" of dipstick with the film on it. Slid it in, paused, pulled it out....Boom! The part to the top of the fill line was "gone" and the part over that was there, clear as can be. Level was just right (whew!). What a great solution. When you see how much powder is actually left on the dipstick after you tap it and wipe the top and bottom, you will laugh. It is such a tiny amount that there is no way it would be possible to hurt anything. I'll do this again any time I have a question in the future. I love the forums!
