Old 06-29-2013, 06:24 AM   #1
TSSUNAMI
It was ninety nine cents!
TSSUNAMI's Avatar
Drives: 2014 Jeep Wrangler
Strong MAF sensor. Believe the hype.
So I've had my 2011 1SS RS for some time now, and I've had a nagging issue with mild throttle surging when going into neutral, as well as a choppy idle, and an occasional random bogging when downshifting and getting on the gas hard.
After reading thread after thread, about vacum leaks (couldn't find any leaks) Throttle surging (some think it's normal) The potential drawbacks of an OTR intake (I have a New Era, it's awesome.) As well as a plethora of other issues and solutions, I stumbled onto a thread about the MAF sensor.
I'm sure many of you here have read up on the topic, but it never occured to me that my car just may have a weak sensor.
Ordered my new "strong" MAF from Apex Chase, last week. It arrived today. Took all of 5 minutes to install.
Here's the results.
Low RPM surging: GONE
Choppy Idle: GONE
Bogging on downshifts: GONE
Bogging from off throttle to high throttle conditions: G O N E
Decel popping was also marginally softened. (my car sounded like a drive bye shooting. It's not as cool as you'd think. I promise. Especially at 5 AM when I'm typically coming home from work.)
Overall I am a VERY happy camper right now. Prior to adding long tube headers, I really never noticed any of these issues. I thought a good tune would fix it. I was wrong. This may have been the best 100 bucks I've ever spent on my car.
Thank you Chase!
TSSUNAMI is offline   Reply With Quote
Old 06-29-2013, 06:34 AM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
That is great! I am glad that your issues were finally worked out.
For those that would like more information on the MAF sensor issue, check out the link below.
"Weak" vs "Strong" Camaro SS MAF Sensors
Old 06-30-2013, 05:34 PM   #3
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
When I installed my ADM Race intake this was the first thing I checked. I was fortunate enough to have a strong MAF from the factory.
Without a doubt this is a thing to be aware of.
Firefighter is offline   Reply With Quote
Old 07-02-2013, 06:19 AM   #4
Apex Motorsports
It is a crap shoot. Some get lucky, some don't. But like you said, definitely something you want to check.
Old 07-02-2013, 08:11 AM   #5
Denis
Denis's Avatar
Drives: 2010 SS
I had a weak one. Swapped it out along with the Apex scoop and bottle. Very happy camper.
Old 07-02-2013, 02:19 PM   #6
BLACK10
BLACK10's Avatar
data logging can make it easy to detect if you have a weak maf.
Old 07-02-2013, 02:23 PM   #7
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
What are we looking for? All I have ever seen is my MAF signal, so I don't really have anything to compare it to.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 07-02-2013, 02:25 PM   #8
thahemp
Geek
thahemp's Avatar
Hehe. Nevermind BLACK10... it's right there in the 1st paragraph of Chase's article .
x = ~x
Old 07-02-2013, 02:31 PM   #9
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
Just curious, has anyone did the "strong" MAF mod and it didnt cure their bucking and surging problem?
Camarojt is offline   Reply With Quote
Old 07-02-2013, 02:37 PM   #10
thahemp
Geek
thahemp's Avatar
I have a strong MAF and my car has always idled rough and bucked in parking lots pretty bad. It also squeaks sometimes when the motor misses a beat at idle. Almost sounds cammed once it's warmed up.
x = ~x
Old 07-02-2013, 02:57 PM   #11
Camarojt
Camarojt's Avatar
That's why I was asking. Bc my car idles rough at first start up, sounds cammed which is kinda cool, then after it warms up for a min, the idle calms down.
Then once I pull out of my driveway and get onto the street, it drives perfect thru the gears, but as I'm slowing down like at a stoplight, it surges pretty hard as it downshifts to each lower gear. The rpms act like as if someone gives it gas right as its downshifting.
This gets a little less noticeable after you drive it for 10-15 min but it never COMPLETLY goes away!
Old 07-02-2013, 03:06 PM   #12
Apex Motorsports
There are several things that could cause similar symptoms. What modifications do you have done to your car?
Old 07-02-2013, 03:10 PM   #13
thahemp
Geek
thahemp's Avatar
Mine never calms down. I'm probably gonna check mine again... It was so long ago that I checked it I'm starting to doubt myself.
I think I'll use BLACK10's method and monitor the MAF frequency with the laptop. I hate pulling that fastlane intake out.
x = ~x
Old 07-02-2013, 08:22 PM   #14
Camarojt
Camarojt's Avatar
All bolt ons Chase.
ADM CAI w/scoop
PTB
1 7/8 headers
3" exhaust
UDP
Circle D 3600 stall
strong MAF
