| Dragstrip, Tracking, Autocrossing, Driving Techniques Discussions Performance driving discussions |
Thread Tools |
![]() Drives: 69 Camaro, 010 2SSRS Join Date: Sep 2008
Will i hook up?
Hey guys, tracked my Camaro once so far and couldn't hook up on the street tires (even at 17 pounds in them). I am looking into a drag radial and coming up with the Nitto 555R, 305/35/R20.
I am running at 470rwhp, and will probably plan to be around 510 Do you think i will hook up with the Nitto?
#2 | |
Banned
Drives: 2003 Cobra Convertible Join Date: Feb 2009
SST...
Drives: SST Camaro 2010 Join Date: Oct 2008
Depending on how often you are going to take it to the track, you may want to consider the smallest diameter wheels you can fit that will clear the brakes. Other than that, the Nittos are presently (I think) the widest drag radial that will fit the Camaro. Getting power to the ground is always a challenge.
Unless you are putting those on the stock rims, you should find a set of 18's that will clear the rotors, then get a similar od tire for those rims. If it is a street car you probably want a different set of tires/rims for the track anyway.
Hooters, hooters, yum yum yum, hooters, hooters on a girl thats dumb.
-Al Bundy 07 2WD Trailblazer SS, LS1 E-fans, 4" FWI, pcmforless tune 72 VW Beetle, 2275cc, Dual 44 IDF's |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS/RS IBM Black Polished Join Date: Feb 2009
Sounds like a good problem to have. What mods have you done to boost rwhp by 100? I agree that a set of 18" for the track as wide as you can get and just get some drag slicks for the track. Why mess with the drag radials if it is going to just be at the track on them anyway. The drag slicks will be a better buy and you will get max bite and should be good to go will into the higher rwhp numbers you are seeking. And you will be able to enjoy those smoking hot burnouts without chewing away at the tread. Love hearing about this type of problem.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
#6 | |
![]() Drives: Black 2SS RS M6 Join Date: May 2009
Get with your tuner and log some launches, two or three. Then have your tuner take out some timing just in the area of the timing table that generally applies to your launch in first gear. This will allow you to bring down the hp/tq a little so you can hook up better at a high rpm so as to still get off the line quickly. You may want to do this in combination with a wheel/tire improvement. I do not have my M6 SS yet so I have not been able to work with the launch control. Also could you please put your mods in your sig so we can better advise you more quickly. BTW I had very good luck hooking up my C5 with the BFG drag radial.....very sticky. I am wondering how well the launch control is going to help with hooking up over 450 rwhp/tq??
Black 2SS/RS M6
![]() VIN# 2G1FT1EW4A9121666 (Bayed) Last edited by SSRider; 07-02-2009 at 06:16 PM. |
#7 | |
![]() I definitely agree with you guys that an 18" tire would be the best bet to go with, but i was also looking into something thicker for street use (cosmetic look wise). So i want to go with the 20" (if it will hook). i do not have the cash to buy 18" tire AND rim to go with it :( especially if i want a new set for the street also.. Plus the car won't be at the track too often, i just really want to hook up when i make it out to the next "PINKS All out" in September.
#8 | |
With the above being said...This is an 18 inch wheel so they would not match the 20's but if someone pulled them off an ls I think those are 18" wheels. But verify that the brembo's would fit behind first before dropping money on them. With the HP you are running you need to find some way to take some of the stress off your launches. Never ever going to do that off a 20" rim and tire cause there just is not enough sidewall. A set of these would last for years and years based on your semi frequent drag racing. But when you go you want to be able to hook it up. Goodyear has a good tire too But you are going to find the wheel sizes too small for the brakes on a lot of tires. Nitto is one of the few that you will find 20's with. But they are so very proud of them and the compound is pretty darn hard cause they want you running them on the streets as well. They say 15k miles but that must be on a cooper cause everyone I know burns them up in under 10K. You have a good post here and I look forward to some of the real drag guys posting up their opinions. I don't know squat about shinola but have been around a few tracks learning for years. Good luck
#9 |
Master of Medicine
Drives: 2012 VW GTI, 2007 TBSS, 2002 Camaro Join Date: Oct 2008
Go over on the corvette forum and see what drag radials they are running...that will give you a pretty good idea of what to do.
#10 |
Camaro Owner Soon!
Drives: Chevrolet Cobalt SS/SC S2 GMPP Join Date: Jan 2009
I'd say don't do the 555R's. They are a pretty hard compound and I ran them on my Cobalt and they wheel hopped and wouldn't hook much better than my normal 555's I run all day long.
The normal Nitto 555 is an amazing tire though for Daily Driving and weekend "joy rides". It lasts a really long time for such a tire (over 40k and still tons of tread! like 40% still left!) And they grip nice as long as it's not to cold out. I have had success with the normal 555 and have purchased a second set (18 inch) for my Cobalt. The 555r on the other hand was pretty much a slightly better drag version of the 555 and didn't last long nor did it help really at the track. I'd try to find a cheap set of 18 inch wheels that will fit on the brembos and run a real cheater slick or true slick with a lot more side wall. You will like it more in the long run and the effect on your times will be impressive! plus they will last seasons and seasons while the 555r won't last very long! Good luck! |
#11 |
![]() Drives: 2009 Corvette, 1987 Buick GN Join Date: Sep 2008
With all that power on tap you should definitely get a good set of track wheels and tires to maximize gains. What track did you go to? I use to go to school in Palos Verdes.
#12 |
![]() Drives: 1985 IROC, 2011 Camaro Join Date: Oct 2008
no, 20" nittos will not hook up with 470rwhp.
the smartest person on Camaro5! Thanks for enlightening us!
#13 |
Thanks for all your help and input guys, i think im going to go with a MT ET Street Radial II, 305/45/18. Shouldn't have any problems there
SubSolar, i go to Fontana to race (AutoClub DragWay, or w.e its called haha) I will just have to accept that my new street tires and rims won't be around for a while :(
#14 | |
A drag radial is certainly going to help, but Nitto, IMHO, is not the best option out there. However, since it looks like you want to keep the 20" wheel on the car at the track, it might be your only option right now. |
#15 | |
#16 |
Banned
Drives: 2006 Mustang GT Join Date: Jul 2009
#17 |
Banned
OP did you make it to the track yet?
#18 |
Ok, there is no such 18" wheel that will fit the Camaro, i have made 20 calls to so many different companys, they all say that the break caliper is too big.
am i really stuck with using a 20" wheel? (meaning stuck with the Nitto as a drag radial as well?)
#19 | |
![]() Drives: 2010 SS/RS CAMARO Join Date: Aug 2008
IOM 2 SS/RS LS3 vin9862
#20 |
Nobody wants to tell you they will fit because they can't be sure. More than one person has already managed to fit 18" Corvette Z06 rims. It is definitely possible. See if you can find someone that has done it, and find out exactly what they used, it is around here somewhere.
#21 |
Moderator, USN
I'm feel compelled to point out that regardless of what tires you have, you're going to need to upgrade your suspension in order to get the most out of your car. If your goal is to get to the finish line faster, then you need to consider the power source, the grip of the wheels, and how the power gets to the wheels. If you forget the between parts, then you'll miss out on a lot of potential.
#22 |
![]() Drives: #3124!!! Join Date: Apr 2008
This may have been totally resolved by now, but I just threw this 20" combo on my Camaro and am really pleased with the results. I daily drive my Camaro a very short distance so the tire wear isn't a worry for me. I'm at 509rwhp and am used to sliding grotesquely on the stock tires in second and third gears. With the Nitto I still get a really solid chirp in second and complete traction in 3rd. It was a big difference on my car. In first you can still light them up, but after some practice you'll see your 60' time drop. I haven't run on a clean track yet to have a specific time but it's noticeable.
#23 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
NT555Rs are a ton better than regular street tires when heated up at the track. But they need a nice long burnout to get them softened up.
Yes, 18" wheels with MTs would work a lot better, but that requires a second set of wheels/tires and you have to take the time to change out your wheels everytime you go to the track. The NT555Rs are all we've got for a daily driver drag radial. We're still waiting for the 305/35/20 MTs to come out (supposed to be any day now). But they will not make a good daily driver tire, but it will give us another 20" drag radials option along with the 315 NT05Rs.
#24 | |
![]() Drives: '69 Yenko Camaro - 11.73 @ 118 Join Date: Aug 2009
'69 Yenko Camaro - 11.73 @ 118, on F70-15 Polyglass tires, Pure Stock
'10 Yenko Camaro - 11.75 @ 117, LS7+A6+Converter |
#25 | |
H-Town Camaro Club
We have a couple of autos running 1.5X 60' with zero suspension mods. The car squats nicely on stock springs and leaves stright. I will say hooking at this HP may require the JRE posi mod to keep from spinning one tire. |
| Thread Tools | |
| TEXAS! Introduce yourself here! | TAG UR IT | USA - Texas | 1622 | Yesterday 03:02 PM |
| TAG's 2010 THRSS #2 | TAG UR IT | Member Car Journals | 2708 | Yesterday 08:33 AM |
| Front Tow Hook? | Mayhem | 5th Gen Camaro SS LS LT General Discussions | 17 | 10-20-2011 05:34 PM |
| how hard to hook up a sub? | Adam | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 10 | 06-04-2009 06:01 PM |
| Reno hook up anyone? | Iroczlover | USA - Southwest | 2 | 09-29-2008 05:49 PM |
