Old 07-07-2013, 01:36 PM   #1
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Low oil pressure..... pump or filter?
Well I replaced the oil sensor AND put a mechanical gauge on the car but still shows low pressure.
Before I tear it down, what are the chances the oil filter got plugged or broke?
Melling high volume pump. Oil filter has been on for about 5k miles.
Old 07-07-2013, 02:03 PM   #2
LS3 SS
Drives: 2010 Cyber Grey Camaro SS (LS3)
What type of Filter? I guess for piece of mind purposes you can try to replace the filter (AC delco I would go with). It's the less time consuming method as opposed to checking your O/P. More than likely it is going to be your Melling that's the cause for the low oil pressure, whether its the o-ring or the pump itself.
LS3 SS is offline   Reply With Quote
Old 07-07-2013, 02:04 PM   #3
Indyblue98
2012 RS 2ss
Drives: 2018 ZL1 2012 2SS WhippleCharged
Would only cost a few bucks to test it out.
2018 ZL1 A10 and 2012 2SS RS Whipple-Corsa-RotoFab-ZL1 Diff 3.73 Pfadt ZL Stage 3 Suspension+
Indyblue98 is offline   Reply With Quote
Old 07-07-2013, 02:12 PM   #4
PQ
Booooosted.
PQ's Avatar
Agreed. Just wondering opinions.
I put a mechanical gauge on it and the cabin gauge and mechanical gauge both agree.
I'll put a new filter just for piece of mind.
I'm not sure the type of filter. I'll go check.
Old 07-07-2013, 04:11 PM   #5
67motorcat
Blown Cool Breeze
67motorcat's Avatar
Drives: 2011 Black on Black 2SS M6
What is your Oil pressure?
What weight of Oil?
How hot outside has it been in your area?
You may or may not have a problem.
Had a 2010 IBM 2SS M6
Enjoy life.Think of all the women on the Titanic who passed up dessert.
67motorcat is offline   Reply With Quote
Old 07-07-2013, 04:55 PM   #6
PQ
Booooosted.
PQ's Avatar
What weight of Oil?
Drops to 0-5 psi on the mechanical gauge and 2-5 on the cabin gauge.
5-30 Mobile One
Not real hot. Maybe 90* Oil Temp around 215 like it always reads.
Old 07-07-2013, 05:34 PM   #7
67motorcat
Blown Cool Breeze
67motorcat's Avatar
Oh,Ok....with that low of a reading it would seem like a mechanical problem...pump,O-ring on pick-up tube,etc.
Some guys are running 0-20W Oil these days like on the Ford Coyote motor.
It can show lower pressure than we are used to seeing,but has no ill effect.
Flow is always better than pressure.
Sorry to hear that man,but shouldn't be too hard to fix.
Old 07-07-2013, 05:40 PM   #8
PQ
Booooosted.
PQ's Avatar
Does the water pump have to come off?
Haven't really looked at it close.
Old 07-07-2013, 07:22 PM   #9
PQ
Booooosted.
PQ's Avatar
Scary part is when it's cooled down and freshly started the pressure hold steady and drops slowly as it heats up.
But that starting pressure is only 30 psi.
Old 07-07-2013, 07:27 PM   #10
Denis
Denis's Avatar
Drives: 2010 SS
30 is still low if I remember correctly.
Wouldn't hurt to just try the filter but after that it's probably time to break out the latex gloves and dig in.
Old 07-07-2013, 07:33 PM   #11
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
The water pump has to come off, and the balancer pulley. Then you can take the front cover off to get to the oil pump.
Sent from my HTC One X using Tapatalk 2
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 07-07-2013, 07:40 PM   #12
Chevrolet Customer Svc
Drives: GM Vehicles
PQ,
Sorry to hear about the low oil pressure sensor. I understand the displeasure that this must have created. Please let me know if you may need additional assistance, otherwise any updates you can provide on this would be greatly appreciated.
William R.
Chevrolet Customer Care
Old 07-07-2013, 08:27 PM   #13
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
I have seen this happen with some non gm filters! Give a ac filter a shot!
Rhino79 is offline   Reply With Quote
Old 07-07-2013, 10:35 PM   #14
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Keep us posted, mine does the same thing as yours but no codes. Thought about changing to a melling oil pump.
MODS:
