Old 07-03-2009, 04:57 PM   #1
klove
klove's Avatar
Drives: black 2SS RS
Painting the Camaro Brake Calipers
Started painting the calipers last night. Got the front two done and working on the back two today. Ill post more pics when they're finished. Look pretty good so far, Wish i had a Brembo stencil though, i think it would look good with a black Brembo painted on the front.
klove is offline   Reply With Quote
Old 07-03-2009, 07:51 PM   #2
Tecca
Tecca's Avatar
Drives: ...
Are you using G2 or Dupli-Color. How many coats, I have been considering this but not sure yet, can't wait to see your finished.
Tecca is offline   Reply With Quote
Old 07-03-2009, 11:02 PM   #3
klove
klove's Avatar
Used duplicolor, and put 4-5 coats on each caliper depending on what it looked like. Finished result
Old 07-03-2009, 11:08 PM   #4
blackedout010
Drives: on order black 2010 2ss
not bad
blackedout010 is offline   Reply With Quote
Old 07-03-2009, 11:09 PM   #5
efpardo
Deep6
efpardo's Avatar
Drives: 2016 Camaro #182300 | 2SS | HBM
Send a message via Skype™ to efpardo
Nice Job
My Journals:
Erick's Mistress - Violet 2016 2SS
#182300 | 2SS | HBM |
Erick’s Mistress - 2010 2LT
#8212 | 2LT | RS | CGM | Litho #165 |
efpardo is offline   Reply With Quote
Old 07-04-2009, 12:27 AM   #6
2L8IWON
2L8IWON's Avatar
Drives: 2010 Chevy Camaro 2SS RS SIM
I see your K&N oil filter hiding back there. Cool! I thought there was an etched Brembo logo on the 2SS. Maybe it was not etched. Did you just paint over the logo? I usually use red G2 paint on my cars, but wasn't sure about covering up the Brembo logos on this one.
2010 Camaro 2SS RS 6M SIM - GFX, Sunroof, Carbon Fiber Dash Kit, ARH Headers, ADM Intake, ADM tune, NLP Dove Tail
2L8IWON is offline   Reply With Quote
Old 07-04-2009, 01:29 AM   #7
Tecca
Tecca's Avatar
Drives: ...
How long did it take you??? Was one kit enough to do all four calipers???
Old 07-04-2009, 01:39 AM   #8
abaci
Drives: HHR SS '09, Want Camaro 2ss/rs
you can buy the brembo stickers from ebay. here
'09 HHR SS
To Get List:
5th Gen Camaro
Ducati Monster
abaci is offline   Reply With Quote
Old 07-04-2009, 03:33 AM   #9
2L8IWON
2L8IWON's Avatar
I never realized. That's sweet! I even came across some metallic silver ones to go on red paint for my SIM. Thanks for giving me a time consuming mod for my future car. After my last two maskings and G2 painting, I said I would never do it again. I'm too much of a perfectionist for things like this. Becomes an entire day event to do the front and the backs with two coats of paint. Thanks for the info though. I will have to look at the stock calipers up close an personal on my SIM before I make the choice.
Old 07-04-2009, 03:46 AM   #10
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
Soooo did the actual process of doing this require you to take the calipers completely off ?
never painted my calipers before, always taken them off and had em powder coated.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 07-04-2009, 03:56 AM   #11
2L8IWON
2L8IWON's Avatar
Some paint without dismantling anything. I've painted them while only removing the brakes and clips. So only the two rear caliper bolts needed to be removed to remove the brake pads. I then clean what I can with wet paper towels then the G2 paint comes with a brake cleaner spray can which helps the paint adhere. I've had to mask everywhere around where I wanted to paint including the rotor area that is near so I didn't risk getting paint in unwanted areas. One thing I have learned is to not paint the inside of the caliper where the brake pads fit in. I did that the first time then had to dismantle the pads, scrape the paint out of those areas because my pads would not slide back and forth like they needed too.
Old 07-04-2009, 04:04 AM   #12
2L8IWON
2L8IWON's Avatar
Oh, I forgot to mention for your question, I laid the caliper part with attached brake line on a tall upside down bucket with newspaper under it and on the floor. I do it extreme - the masking and unmasking is the time consuming part. I've always done red, but now I'm thinking about silver with black decals for my SIM. It won't be as noticeable, but again, I need to get my ordered car in to see it in person and figure it out. By the way, the G2 paint kit also comes with a brush. The brush on paint is designed for calipers and ends up to be a very smooth rubber like coating. It does not show brush marks, but dries smooth. I've had a problem after a couple of years with a couple of chips out of my red paint. That sucks. I didn't want to by a new kit to match just to touch up so I put an entire new coat on them. I think eventually the chipping and cracking is inevitable which is why I still ponder doing it again. Can always scrape is all off a redo it every three years I guess.
Old 07-04-2009, 04:26 AM   #13
2L8IWON
2L8IWON's Avatar
I've looked a pictures and have decided not to paint my calipers on my SIM because I want it all silver and black with the GFX. If I had a black, white, or red camaro, I would definitely do it.
And the paint job on this thread looks nice. Might look more official by putting some black Brembo decals on them with that black paint.
Old 07-04-2009, 04:59 AM   #14
Vash
Drives: 00 Blazer
Not bad at all for a can job.
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 93 08-30-2021 05:56 PM
Winner, winner - Jalopnik compares the Big 3 Number 3 5th Gen Camaro SS LS LT General Discussions 31 04-17-2011 03:24 PM
Q&A with fbodfather (Scott Settlemire) regarding upcoming Camaro JustinZS 5th Gen Camaro SS LS LT General Discussions 22 05-20-2008 07:48 PM
