Old 10-13-2013, 07:37 PM   #1
yellow69z28rs
Drives: 2013 ZL1 Convertible Black
Send a message via AIM to yellow69z28rs
Road Race Tires
I need some dedicated road race tires for my stock 20" wheels. Any recommendations?
JRE 750 HP package
Rag Top Rob
yellow69z28rs is offline   Reply With Quote
Old 10-13-2013, 08:01 PM   #2
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
http://www.camaro5.com/forums/forumdisplay.php?f=156
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 10-13-2013, 08:41 PM   #3
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Front
http://www.tirerack.com/tires/tires....R888&tab=Sizes
and Rear
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 10-14-2013, 12:07 PM   #4
gmdoctor
Drives: ZL1
I know theyre not road race tires, but has anyone tried the bfg rivals? Im looking to maintain 200treadwear for a time attack class
gmdoctor is offline   Reply With Quote
Old 10-14-2013, 01:19 PM   #5
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Toyo Proxes R888 for sure!!
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 10-14-2013, 02:11 PM   #6
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
If you are going to buy a dedicated set of tires for road racing then I assume you are going to buy another set of rims. I cannot imagine mounting and unmounting the individual tires on your stock rims. I think you are better off looking at some different rims to reduce weight and improve your tire choices. There are more tire options in the 19" rim than the 20". You can run a wider rim for a more square set-up on the front and better handeling. I'm running the toyo R888's right now and that is a better tire than the Goodyears. I think the Hoosier R6 is another step better, but it only fits 19" rims as far as I know.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 10-14-2013, 02:21 PM   #7
Synner
Drives: cars
Michelin super sports if you're worried about treadware rating, R888 if looking for max traction. The super sports in the widest 315 that'll fit is on national backorder right now. How disappointing for me since I ordered them a couple days ago...
Old 10-14-2013, 11:45 PM   #8
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
Yes, the backorder stuff with the Michelin's is a pain...I always keep an extra set around during racing season, as the wait can be long at times....
So Cal Camaro is offline   Reply With Quote
Old 10-15-2013, 10:55 PM   #9
yellow69z28rs
I have two sets of stock wheels, one of them has MT DRs on rear with the GY stocks on the front.
After you guys help I am going to try a set of the R88's on the other stock set.
I also have a couple of sets of 22" I use for daily driving.
Thanks
JRE 750 HP package
Rag Top Rob
Old 10-16-2013, 12:34 AM   #10
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Race tires for the stock (skinnies) will be hard to find. The Toyo R888 20" tires only come in 285 and 315 widths which need 10" and 11" wide rims respectively (minimum 9.5/10.5).
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 10-16-2013, 12:41 AM   #11
Synner
Drives: cars
He has a ZL1, 10/11" is stock for him.
Old 10-16-2013, 09:08 PM   #12
yellow69z28rs
R888 on the way! Heat cycling too!
JRE 750 HP package
Rag Top Rob
Old 10-16-2013, 11:44 PM   #13
sting808
Drives: 2010 SS RS
Nitto NT01 now come in 285/35/20 and can be shaved. The rear would be stretched on 11", but would be "sort of" squared setup. They are available, but dealers need to call for them. I went with R888s since my last check, the NT01 increased $37/tire from a month ago. It was about $200 more for a set over the R888s and couldn't justify that cost.
sting808 is offline   Reply With Quote
