10-27-2013, 08:37 AM | #1 |
Drives: ZL1 Join Date: Sep 2013
Square tire setup
Anybody done a square tire setup similar to the 1le? I do a lot of road course tracking and just looking for options and thoughts on the setup. Not sure if the ZL1 will like smaller tires out back. But im thinking it might help with understeer.
10-28-2013, 09:48 PM | #2 |
Drives: 2013 Camaro ZL1 Join Date: May 2013
With correct wheel offset and size, I don't think there should be any issues. I run 295 squared all around 10.1" in width compared to the stock rear at 11.5". The car does feel more balanced. Less understeer squeal for sure.
I dropped 2.7 seconds in lap time in track condition of 8 degree C compared to oem goodyears 285/305 with 25 C.
LSA VR38DETT 4B11 2ZZ-GE-SC N55 B18C5 302
10-29-2013, 01:38 AM | #3 |
Drives: 2013 ZL1 Vert Auto IOM Join Date: May 2012
theres no benefit to reducing your rear tire size i would recommend 295/315
you may get the illusion of a more balanced car, but you would just be giving up rear end traction and make your car more prone to oversteer, the real benefit would come from improved front end traction but theres no reason to reduce the rear end traction |
10-30-2013, 12:23 PM | #4 |
i guess im gonna try and find a way to fit 305's in front
10-30-2013, 05:24 PM | #5 |
^ I won't recommend that unless you want your tires to stick out quite abit.
295 Michelin PSS is a good size for front tires.
10-30-2013, 06:11 PM | #6 |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
The ZL1 suspension was tuned to the staggered, not sure how a square setup will effect it.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
10-31-2013, 09:36 PM | #7 |
Drives: '67 Z28 Join Date: Sep 2013
Re: fitting 305s in front-
By dialing in some negative camber in front, the car should gain some room outboard for wider wheel/tire. For those that have max'd out negative camber in front (-2 or -2.5?) how much room is left inboard at that point? If there's still a 1/4" inboard, the camber should add 1/4" more room outboard, suggesting at least a 295 could fit on a 10.5" wheel without sticking out further (at the top) than stock. If you can get there, a 305 should be possible?
--Jason Rhoades http://www.rhoadescamaro.com/build
10-31-2013, 09:55 PM | #8 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
305/30 R19s on all 4 corners here with the ability to to -3.0 deg camber in front with just 4 bolts and 5 minutes. Justice Pete FTW
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
10-31-2013, 09:59 PM | #9 |
Call Forgeline, tell David you want the Pedders Camaro setup.
10-31-2013, 10:00 PM | #10 |
The car can get -3 with the stock adjusters?
What wheel width and offset or backspace did Pete use with the 305 19s?
11-01-2013, 11:09 AM | #11 | |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
The only benefit to putting on a narrower tire is the ability to rotatate the tires. Unless you can get a much stickier tread compound only in the narrow size. My track tires wear slightly faster in the rear and way faster on the right side of the car due to the dominant direction of track flow. I can rotate the tires left to right and get good wear out of all of the tires. I have just resigned that if I'm going to track the car I'm going to have to buy a lot of tire and brake parts. I'm 295 front and 315 rear. It works pretty well. I understeer if I brake to late and oversteer if I get on the throttle to early. It is very controllable.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
11-01-2013, 01:18 PM | #12 |
My camber is maxed out front. Reads -2.0 degrees both sides. Seems thats as far as the oem will allow
11-01-2013, 01:24 PM | #13 | |
[QUOTE=gmdoctor;7147992]
You have 5-7mm more clearance outboard now, add that to remaining inboard clearance, plus whatever factory outboard clearance was provided.
11-29-2013, 10:02 PM | #14 |
Sorry to bring this back from the dead.
Had a chance to measure wheel to strut clearance with maxed out camber(-2.0) at roughly 10mm. Aint much, looks like anyone wanting larger front wheels has to go out, no room left inboard. Makes sense when you compare the z28 sizes and offsets |
