Old 11-16-2013, 08:19 PM   #1
DWALEX
DWALEX's Avatar
Drives: Currently 2016-2SS, Future ZL1/Z28
How Add a camera to mylink radio
I know some cars with Mylink cames without backup camera
I would like to show how I did
this are the parts:
*Camera p/n 22767362
*Bracket p/n 22766257
*2013 CHEVY CAMARO SS RS ZL1 FACTORY REAR BUMPER WIRE HARNESS OEM (you can find it on ebay)
this is for the connector Femela Delphi 12-ways GT 150 series, sealed connectors
2 Femela Part No: 13530777
some Femela terminal sealed Part No: 12191818
some Cable seals Part No: 12191152
some Cavity Plug Part No: 15305171
you will need to some reprogramming I am sure your dealer can help with this. I don't think you want to spend thousands on a reprogramming tools.
when I installed my Mylink on my 2010 I had to program with this feature. NOW I KNOW IF YOU WANT TO ADD CAMERA TO MYLINK RADIO YOU NEED TO REPROGRAM. i will post more information how to do this
the first thing is remove the rear bumper fascia
and you will need to fixing the camera and for that you need cut your bumper.
second thing is add the wires to the main harness (Circuits in bold)
Right side
A. BK- Ground
B. BN/GY- Right Park Lamp Supply Voltage
C. D-GN/WH- Right Rear Turn Signal Signal Lamp Supply Voltage
D. BK- Ground
E. YE- Left Rear Corner Object Sensor Signal (Backup Sensor Option)
F. OG- Left Rear Middle Object Sensor Signal (Backup Sensor Option)
G. PU- Right Rear Corner Object Sensor Signal (Backup Sensor Option)
H. D-GN- Right Rear Middle Object Sensor Signal (Backup Sensor Option)
J. BK- Camera Drain Wire
K. PK- Camera Signal #2+
L. L-BU- Camera Signal#2-
M. Run/Crank Ignition 1 Voltage (this have to be wired up to connector) X204 Pin A8 Pink wire)
Left side
A. DG/YE- Rear License Lamp Control
B. BL/L-BU- Left Park Lamp Supply Voltage
C. YE/BK- Left Rear Turn Signal Lamp Supply voltage
D. L-GN- Backup Lamp Supply Voltage
E. D-BU Object Sensor Supply Voltage (Backup Sensor Option)
F. Not Used
G. GY- Object Sensor Low Reference
H. BK- Ground (this have to be wired up to ground)
J. Not Used
K. Not Used
L. Not Used
M. Not Used
The third thing is wiring up to A11 Radio X4 connector
Pin 5 PK- Camera Signal #2 (+)
Pin 15 L-BU Camera Signal #2 (-)
this is how this works
DWALEX is offline   Reply With Quote
Old 11-16-2013, 08:26 PM   #2
The Beard
The Beard's Avatar
Drives: 2013 2SS HWSE M6
The Beard is offline   Reply With Quote
Old 11-17-2013, 08:45 AM   #3
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
why dot you use the new 2014 camera, its not the same but close to the 13, and its only the camera that is new the rest use the same parts.
Old 11-17-2013, 10:32 AM   #4
DWALEX
DWALEX's Avatar
I don't have worked with the 2014 but if know the part No we can try
Old 11-18-2013, 11:07 AM   #5
2SSRS@Gen5diy
its a newer shape and one more connector on the camera the # is 22872078
Old 05-29-2014, 09:27 PM   #6
ZL1-PA
ZL1-PA's Avatar
Drives: 2014 ZL1
I would like to add a second camera to the front - same camera and wires - then just toggle between front and rear as needed to help parking, check curbs, etc.
ZL1-PA is offline   Reply With Quote
Old 06-10-2014, 11:46 AM   #7
YoungMulaBaby
Drives: Camaro 2014 2LT
Does anyone know if there is a way where you can toggle on/off the camera.
Like keep it on when you're not backing up, but can turn it off whenever you want, later on.
YoungMulaBaby is offline   Reply With Quote
Old 11-02-2015, 10:22 PM   #8
capitenjimmy
capitenjimmy's Avatar
Drives: 2013 camaro rs
hi there ..thank you for your info
Hi there thank you for taking your time and help us with this camera problem..
i have a 2013 camaro rs it have mylink .I don't have a backup camera.. on your camaro did you add the wiring harness from the back to the front of unit ?or rs have the harness .. Because I'm a little confused I have already a backup camera from eBay oem camaro..so can you please help me ,,thank you
capitenjimmy is offline   Reply With Quote
Old 11-03-2015, 06:03 AM   #9
DWALEX
DWALEX's Avatar
yes you have to add wires but is pretty easy with this:
http://www.gen5diy.com/Chevrolet/Cam...amera-harness/
Old 11-04-2015, 08:27 PM   #10
capitenjimmy
thank you boddy
