#1 | |
![]() Drives: Red 2010 Camaro 2SS L99 Join Date: Apr 2010
Extended Wheel Stud Information
After some research I came across a compilation of the various wheel studs that will work on our cars. This info came from a G8 forum but the studs are the same.
Hopefully this helps! Mods feel free to move this if necessary.
2010 Camaro 2SS/RS L99 6AT - 451 RWHP, 414 RWTQ
TSP VVT-3 Cam DOD/AFM Delete, Ported Stock Heads, Circle-D 2B Multi Disk Converter, Custom 3" Exhaust w/Burns Mufflers Exhaust Clip: http://youtu.be/c_quv8eoVNQ |
Guess I'm the only one that found this useful! haha
No, it's useful. but I think most guys here are just running thin spacers for the most part, like maybe 1/4" or so. Some of those studs above are very long, but certainly useful in special applications. But for most people, who don't need the super-long studs, there is better alternative.....
OEM (11588811) = Dorman Equivalent (610-434) GM (1/4" longer, 11588810) = Dorman Equivalent (610-428) As seen here: http://ls1tech.com/forums/cadillac-c...lac-cts-v.html Just more info for the masses..... |
this just saved me! Thanks for posting this!! Have you used any of these? im running a 15mm spacer wonder which would work better
13' Camaro SS 746WHP
LSA Supercharged, Built 416 Stroker, BTR Stage III Pd cam, M6, Corsa Exhaust, DMH Cutouts, Vip Modular Wheels, DSE Suspension, Squash Fuel System. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 SS/RS Join Date: Jul 2013
Exactly what I've been looking for
#6 |
![]() ![]() ![]() ![]() Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
Those long ones will likely require removal of the hub at least in the front to get them in. The truck studs will barely go in if you do some light grinding of the knuckle for a few more mm of clearance.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
#7 |
I think I'm gonna go with the one right next to the OEM one
#8 |
![]() Drives: 2014 2SS 1LE,RS,NPP,Recaros in SW Join Date: Apr 2012
I will try the 11588810 with a 7mm spacer. Now, where to get a 7mm spacer.....
#9 |
#10 |
#11 |
That part number is the same size as the stud you have now.
As for the spacer, you might find something here. http://www.ebay.com/sch/i.html?_nkw=...sPageName=GSTL |
#12 |
You're right I fouled up. The one I originally stated 11588810 is 65 mm long. The stock ones 111588811 are 58 mm long. Both GM parts.
#13 | |
#14 |
Oh I didn't think to check the bore size. I'll check again
