Old 12-10-2013, 10:21 AM   #1
timtoolman24
timtoolman24's Avatar
Drives: 2012 LS3 2SS/RS
Need ya'll help, making M6 > 4l80 swap
I'm making the swap from M6 to 4l80 and I'm I have the link to the forum on th DIY and only problem I'm looking at is: I'm going with the full manual with a rachet shifter, and my question is how will I get the reverse lights to work and camera? Also how does the mph work? what other things do I need to know about since I'm not going auto with computer?
timtoolman24 is offline   Reply With Quote
Old 12-10-2013, 10:34 AM   #2
The_Blur
Moderator
The_Blur's Avatar
You could try converting the backup camera to manual with a switch. You'd probably need a harness and all the wiring and, of course, to get into the habit of flipping a switch every time you go into reverse.
warn 145:159 ban
Old 12-11-2013, 09:30 PM   #3
MaxKamai
Mad Ninja Skills
MaxKamai's Avatar
Drives: 2011 Camaro SS/RS M6
Doing same thing right now. Mine doesn't have reverse camera, but my shifter has a NSS and Backup Light Switch. What shifter are you using?
2011 Camaro SS/RS M6 - 633whp/679tq Gave to the wife
Custom stainless 2" primary headers / Custom stainless 3" header back exhaust / Hurst short shifter / ZEX nitrous kit / Vararam intake / Spohn chrome moly trailing arms / Sin City Performance Tune / SCP custom ground cam / SCP ported & polished heads
New Car 2007 Corvette Z06 - Headers / Vararam / Magnaflow Catback / SCP Tune / Nitrous / BTR Stg IV Cam and Springs
MaxKamai is offline   Reply With Quote
Old 12-12-2013, 04:45 AM   #4
timtoolman24
Either the B&M rachet shifter or the Hurst rachet shifter
Old 12-12-2013, 07:18 AM   #5
acowherd
acowherd's Avatar
Drives: 2010 2ss/RS 4l80. 2009 2500 HD
I haven't done mine yet...
I believe you could use gear selector thing that bolts on the side of the trans. It slides over the part where you hook the shifter to and it spins when you shift gears. Then just have to figure out the wiring. You will need your reverse lights and or camara power wire..hook those together and then power to the trans switch. When you shift to reverse the switch powers the lights and camara.
Typed in a hurry on phone...sorry for mistakes, but this should get you thinkinh and pointed in the right direction.
Follow along as we build and race this 2010 Camaro!
https://www.facebook.com/pages/FNSS-...75028626000379
FNSS Racing!
acowherd is offline   Reply With Quote
Old 12-12-2013, 07:22 AM   #6
acowherd
acowherd's Avatar
http://m.ebay.com/itm?itemId=231046594278
It should look like this...you have to find the right one for your trans.
FNSS Racing!
Old 12-12-2013, 11:54 AM   #7
timtoolman24
Thanks ya I read that the shifter comes with a reverse switch to hook up your lights! So I just have to hook up camera to that also and should be easy. I will take plenty of pics from start to finish. My trans is getting built right now, should be another week then I get to put it together!!!
Old 01-01-2014, 06:49 PM   #8
2sscamaro11
Drives: 2011 ss camaro
What wires did you tap or run to your shifter for the reverse lights?
2sscamaro11 is offline   Reply With Quote
Old 01-05-2014, 07:17 PM   #9
tkrupinski
Hugger Orange
tkrupinski's Avatar
Drives: 2010 Hugger Orange 2SS/ RS YSI/4l80
I'm using the P N D switch from RPM Transmission. It includes a wire pigtail with four wires. Two wires go to reverse lights and the other two go to your park to start. Installs over the shift shaft on the side of the trans. Easy install.
tkrupinski is offline   Reply With Quote
