Old 12-13-2013, 02:03 PM   #1
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
Haltech Sport 2000 EMS Installed - Piggybacked with Factory ECU Best Of Both Worlds!
We have 3 Haltech Sport 2000 systems now running in fifth generation Camaros. Two of which retain factory ECU for idle & dash controls. The third vehicle is running off of the Haltech standalone terminated harness with a Racepak Dashboard.
The Haltech has baro & air temp correction, so now you no longer have to tune the stock ECU for every single type of air/atmosphere when running different racing events. The Haltech also allows for engine protection features that can save the motor when fuel pumps fail, oil pressure goes low, etc.
We run the following features on most units:
- Haltech Sport 2000 EMS w/ Dual Wideband Control
- Add Haltech Boost Control Solenoid for Wastegate control; using for Boost By Gear, delayed ramp-in boost, and engine protection features.
- Tie in fuel pressure, wideband AFR warnings with engine protection features coupled with the wastegate/boost solenoid (i.e. fuel pressure drops below XXpsi, it will open the wastegate and dump boost, OR make a hard ignition cut -- rev limiter)
- Setup with factory PCM's in both cars, so factory dashboard, gauges, abs/tcs, OBD II plug in will still work for driver comfort and inspection.
Let's run down the features of the Haltech.
Although we have run numerous fast quarter mile times on the stock ECU, there are many draw backs to using the factory computer for this purpose. Simply put, the factory PCM focuses on Emissions and drive-ability, wide open throttle is some what a secondary function that is not as controlled as your cruising air fuel ratio is. We have found that with a high HP car that means monitoring these items regularly and making changes throughout the season to keep the car spot on.
ECU's like the Haltech Sport 2000 series, that have been built with running a high HP car as its primary focus, keep its mind set on maintaining WOT conditions. This is crucial to engine longevity, and safeties can be added to change maps in the program based off of, fuel pressure-air fuel ratio-EGT temps-oil pressure, whatever you choose.
Most Corvette or Camaro owners have no interest in gutting the car and rewiring it to a race car status (understandably so), without body modules etc leaving many factory components inoperable including the dash. We have had the pleasure of working with Haltech to integrate the Haltech Sport 2000 series ECU into your Corvette or Camaro to run all the engine controls, while still retaining all your factory components including plug-in OBD II port for safety/emissions inspections.
Haltech offers a completely plug and play patch loom to work with your factory ECU, cutting the installation time down tremendously over all other aftermarket ECU's that you need to splice or intercept connections. The unit is tucked up in the Corvettes or Camaros behind or near the glovebox, with the accessible USB cable in the glovebox to hookup to your laptop when ready.
Short list of what it will offer is;
- Dual wide band 02 inputs with Closed Loop WOT corrections
- Dual Fuel/Ignition/Boost Tables (For Race Gas & Pump Gas maps at the flip of a switch)
-Individual cylinder tuning
-EGT inputs with an over temp shut down you set if wanted.
-Sequential or Staged injector control for up to 16 injectors
-Built in Drivers for High impedance (Saturated) Injectors or Low Impedance (Peak& Hold) Injectors (no Injector driver box required)
-Wastegate boost control by RPM/Load/Vehicle Speed with Gear offsets (Boost by gear)
-Two step/antilag/launch control off Trans brake or Clutch pedal
-NOS controls (RPM & TPS activation window, Timing Retard, Fuel Enrich)
-VE Speed Density Tuning
-Engine Protection Functions based on various parameters
-High Resolution Internal Datalogging and Easy to use PC Based Datalogging
-Logger “Playback” function retraces run through ECU Manager software to show EXACTLY where make changes
-E85 Flex Fuel Sensor Compatibility (Turn your car into a True Flex Fuel Car and make BIG power on E85!)
Haltech Anti Lag
Haltech First Startup
(Normally laptop and all USB connections are inside vehicle, was just testing this setup before finalizing installation)
2010 Camaro SS
ERL 427ci Hydraulic Roller
~1200HP
Procharger F1X (21psi)
(Standalone Harness)
2012 Camaro SS
~1700HP
RHS 436ci Hydraulic Roller
Vortech XB110 Supercharger (33psi)
Haltech On Dyno
Crossing over the 1150rwhp range. Real Time Tuning
900+ RWHP, YSi 408ci, 2001 Corvette Z06
Haltech On The Track
Testing the new Ignition Ramp Timing; Can take out timing based off of a timer activation off of the transbrake, so if track prep is going away.
Matt @ FSP is offline   Reply With Quote
Old 12-14-2013, 07:45 AM   #2
Rockit_z28
www.1baddogracing.com
Drives: 2010 IOM 2SS/RS Auto
Matt - Great work here as always. I am going to ask the stupid question. Would it pass the "no electronics" rule in some of the footbrake/index classes in IHRA and NMCA?
Rockit_z28 is offline   Reply With Quote
Old 12-14-2013, 10:59 AM   #3
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
Very nice set-up.
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 12-14-2013, 11:49 AM   #4
Matt @ FSP
Matt @ FSP's Avatar
Well for footbrake class you cannot use the transbrake of course.
The Haltech is the ECU itself, so the Haltech is 100% class legal unless directed that you can only allow a stock ECU (Which I have not seen that in classes, but you never know).
Old 02-07-2014, 09:13 PM   #5
Bad Dad
Bad Dad's Avatar
Drives: 2010 2SS/RS , 2011 C6 Base Corvette
Matt please update
SUICIDE BY RACECAR
Bad Dad is offline   Reply With Quote
