12-15-2013, 05:34 PM | #1 |
6 point cage ordered from Trackspec
Just spoke to trackspec and decided on my cage options. Going with a mild steel, satin black, 6 point with both swing outs.
I'm STOKED!! THANKS TRACKSPEC!! Can't wait to see the final product!
12-15-2013, 06:36 PM | #2 |
Drives: 2013 SS Join Date: May 2013
Whats the weight on that thing?
12-15-2013, 06:53 PM | #3 |
Drives: 2013 1LE Join Date: May 2013
Wow, never thought a bolt in cage would be NHRA legal.
12-15-2013, 07:12 PM | #4 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
You should be going for the moly one, just to save weight.
12-15-2013, 07:17 PM | #5 |
Don't know exactly but it's not chromoly, it's a mild steel so it has some weight to it. I will get the answer to your question tho and let you know.
12-15-2013, 07:18 PM | #6 |
I considered it but wanted to save the money so went the other way.
12-15-2013, 07:32 PM | #7 | |
Moly is about 800.00 more. I'm getting the passenger side swing out, if I wasn't doing that I would consider Moly.
12-15-2013, 07:35 PM | #8 |
Wasn't planning on it. Why do you ask?
12-15-2013, 07:48 PM | #9 |
You can always call Tim at RPM
Tell him Big Al with the camaro vert sent you http://www.rpmrollbar.com/rollbars-gm.html |
12-15-2013, 07:50 PM | #10 | |
12-15-2013, 08:17 PM | #11 |
Emerald Coast Camaros
Drives: 2010 RS/SS Rally Yellow & 68 SS Join Date: Dec 2012
What ET is the 6 point cage good for.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135 AS OF 1/31/15 @ 633 RWHP=10.16@135 AS OF 1/29/16 @ 633 RWHP=10.10@136 TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF |
12-15-2013, 08:19 PM | #12 |
Drives: 2010 Camaro Join Date: Feb 2010
12-16-2013, 11:15 AM | #13 |
Looks like 2 bars on the passenger side because they took the driver side swingout bar off during the work and put it over there out of the way.
Also this is a chromemoly set up. |
12-17-2013, 08:15 PM | #14 |
Drives: 2012 LS3 2SS/RS Join Date: Jul 2012
9.99 needs a full cage???
Build Thread--> http://www.camaro5.com/forums/showthread.php?t=328966
